4 Run the Integrations
After you have activated the integrations and updated the integration property values, you can run the integrations.
This is the general process:
Run the Sync Aconex Issues with Unifier Integration
Synchronization Results
Running the Sync Aconex Issues with Unifier integration makes the following changes in Aconex and Primavera Unifier:
In Aconex:
- The Send to Unifier Issue field is set to Sent.
- The Unifier Project Number field is auto-populated.
- The Unifier Issue Record Number field is auto-populated.
In Primavera Unifier:
- A new issue is created or an existing issue is updated (if the issue status is not Closed).
- The issue description is updated.
- The first user-defined field, Issues Text 255 UDF 1, is auto-populated with the Aconex project ID.
- The second user-defined field, Issues Text 255 UDF 2, is auto-populated with the Aconex issue record number.
When the issue is created in Primavera Unifier, you can manually process and close it using the Primavera Unifier workflow.
You can also update an existing Aconex issue in Primavera Unifier (if the issue status is not Closed in Primavera Unifier) by changing the Send to Unifier Issue field to Yes and running the integration again.Process Issues in Primavera Unifier
You can manually process an issue in Primavera Unifier to review and close it.
To process an issue, you will use the workflow you defined during the initial configuration. After the issue is closed in Primavera Unifier, you can run the Sync Unifier Issues with Aconex integration to finally close the issue in Aconex.
Perform the following steps to process the issue in Primavera Unifier:
Send the Issue for Review
- Log in to Unifier and navigate to your project.
- Select Issues.
- Check the Record Number for the issue that was created through integration and notice that its Status is open.
- Select Tasks.
- On the Tasks page, select the Record Number link for the issue that needs to be processed.
- On the Issue dialog, do the following:
The status of the issue is changed to Awaiting Review.
Run the Sync Unifier Issues with Aconex Integration
After you have processed the issues in Primavera Unifier, you can run this integration.
After this integration runs successfully, the status of the Aconex issue is automatically changed to Closed and the Send to Unifier Issue field is set to Sent.
To update an existing Aconex issue in Primavera Unifier, first ensure that the issue status is not Closed in Primavera Unifier, then change the Send to Unifier Issue field in Aconex back to Yes, and finally run the integration process again.Monitor the Integrations
You can monitor instances and errors directly within the project workspace and also from the global observability pages.
