Installing Customer To Meter Components
The Oracle Utilities Customer to Meter installation includes:
Installing Oracle Utilities Operational Device Management V2.4.0.0.0
Installing Oracle Utilities Application Framework V4.5.0.0.0 Prerequisite Single Fixes
Note: This section is applicable only if there are any Oracle Utilities Application Framework prerequisites patches to install.
Oracle Utilities Application Framework patches must be installed prior to installing Oracle Utilities Customer To Meter.
The patches are available as a convenience roll-up inside the C2M-V2.9.0.0.0-FWPREREQ-MultiPlatform.zip file which is part of the downloaded media pack.
For a list of the patches included in this roll-up, refer to Application Framework Prerequisite Patches.
To install the application and database patches on top of Oracle Utilities Application Framework V4.5.0.0.0:
1. Copy the C2M-V29000-FW-PREREQ-MultiPlatform.jar file in the delivered package to a <TEMPDIR>.
2. Unjar the file.
jar -xvf C2M-V29000-FW-PREREQ-MultiPlatform.jar
3. Initialize the Oracle Utilities Application Framework environment that you want to install the patch roll-up into:
UNIX
$SPLEBASE/bin/splenviron.sh -e $SPLENVIRON
Windows
$SPLEBASE\bin\splenviron.cmd -e %SPLENVIRON%
4. Install application patches.
a. Navigate to the <temp location>/FW-V4.5.0.0.0-Rollup/Application folder.
b. Execute the group installation script.
UNIX/Linux
chmod a+x installSFgroup.sh
chmod a+x FW*/*.sh
./installSFgroup.sh
Windows
installSFgroup.cmd
Installing Oracle Utilities Customer Care and Billing V2.9.0.0.0
This section describes the steps to install Oracle Utilities Customer Care and Billing, including:
Copying and Decompressing Install Media
The installation file is delivered in jar format for both UNIX and Windows platforms.
Oracle Utilities Customer To Meter is delivered in a separate installation package for each supported Operating System. Refer to the Supported Platforms section in Supported Platforms and Hardware Requirements for version and installation details regarding the database and operating system versions. Also refer to Installing Application Server Prerequisite Software for the prerequisite third-party software installation instructions.
Download the installation package for your operating system and proceed with the following instructions.
1. Login to the host server as the Oracle Utilities Application Framework administrator user ID (default cissys). This is the same user ID that was used to install the Oracle Utilities Application Framework.
2. Create a <TEMPDIR> directory on the host server, which is independent of any current or other working Oracle Utilities Customer To Meter application environment. This can be the same <TEMPDIR> used during the installation of the Oracle Utilities Application Framework.
3. Copy the file CCB-V2.9.0.0.0-MultiPlatform.jar in the delivered package to a <TEMPDIR>. To use FTP to transfer this file, make sure to use the BINARY option.
4. Decompress the file:
cd <TEMPDIR>
jar -xvf CCB-V2.9.0.0.0-MultiPlatform.jar
Note: You will need to have Java JDK installed on the machine used to (un)jar the application server installation package. Please install the JDK that is supported for the install on your platform to be able to use the jar command. This is the location of Java packages: http://java.sun.com/products/archive/index.html.
For Windows installs, include the location of the JDK in your path before you execute the jar command.
For both Unix and Windows platforms, a sub-directory named CCB.V2.9.0.0.0 is created. The contents of the installation directory are identical for both platforms. The directory contains the install software for the application product.
Preparing for the Installation
1. Login as an Oracle Utilities Customer To Meter Administrator (default is “cissys”).
2. Initialize the Framework environment that you want to install the product into.
UNIX:
Windows:
3. Stop the environment if running.
Installing the Oracle Utilities Customer Care and Billing Application Component
To install the Oracle Utilities Customer Care and Billing application:
1. Change to the <TEMPDIR>/CCB.V2.9.0.0.0 directory.
2. Set the following path:
export PATH=<JAVA_HOME>/bin:$PATH
Note: The above command is only applicable on a Linux platform. <JAVA_HOME> is the location where the JDK has been installed.
3. Run the following script:
UNIX
ksh ./install.sh
Windows
install.cmd
Note: On UNIX, ensure that you have the proper execute permission on install.sh
4. Follow the messages and instructions that are produced by the install utility. Please note that some of the steps may take some time to complete.
5. If the install utility execution was not stopped due to errors and you did not interrupt the execution, you have finished the installation of the Oracle Utilities Customer To Meter Application product.
6. Run the following commands:
UNIX
splenviron.sh -e <ENV_NAME>
configureEnv.sh
Type P and <ENTER> (you don't need to change anything)
initialSetup.sh
Windows
splenviron.cmd -e <ENV_NAME>
configureEnv.cmd -e <ENV_NAME>
initialSetup.cmd
7. Start up the environment.
The final step of the installation process is the environment startup. The install utility executes the command spl.sh start (for UNIX) or spl.cmd start (for Windows) to start up the environment. You may start the environment by this command any time. Follow the messages on the screen and check the logs in $SPLSYSTEMLOGS (%SPLSYSTEMLOGS% on Windows) directory to ensure that the environment was started successfully. If the startup failed, identify the problem by reviewing the logs, and start up the environment manually while you are connected to the new environment in your online session.
Installing Oracle Utilities Customer Care and Billing V2.9.0.0.0 Post-release Patches
Note: This section is applicable only if there are any Oracle Utilities Customer Care and Billing prerequisites patches to install.
The Oracle Utilities Customer Care and Billing patches must be installed after installing Oracle Utilities Customer Care and Billing.
The patches are available as a convenience rollup inside the CCB-V2.9.0.0.0-Rollup- MultiPlatform.zip file, which is part of the downloaded media pack.
For a list of the patches included in this rollup, refer to Post-release Patches.
To install the application and database patches on top of Oracle Utilities Customer Care and Billing 2.9.0.0.0:
1. Copy the CCB-V29000-Rollup-MultiPlatform.jar file in the delivered package to a <TEMPDIR>.
2. Unjar the file.
jar -xvf CCB-V29000-Rollup-MultiPlatform.jar
3. Initialize the Oracle Utilities Customer Care and Billing environment where the Oracle Utilities Customer Care and Billing patch rollup has to be installed.
UNIX
Windows
a. Navigate to the <temp location>/CCB-V2.9.0.0.0-Rollup/Application folder.
b. Run the group installation script.
UNIX/Linux
chmod a+x CCB*/*.sh
./installSFgroup.sh
Windows
installSFgroup.cmd
5. Start the environment.
Installing Oracle Utilities Meter Data Management V2.5.0.0.0
This section describes how to install the Oracle Utilities Meter Data Management, including:
To proceed with the Oracle Utilities Meter Data Management installation you need to be connected to the target Oracle Utilities Application Framework environment.
Copying and Decompressing the Install Media
The Oracle Utilities Meter Data Management installation file is delivered in jar format for UNIX .
To copy and decompress the install media:
1. Login to the application server host with the Oracle Utilities Application Framework administrator user ID.
2. Download the Oracle Utilities Meter Data Management V2.5.0.0.0 Multiplatform.zip from Oracle Software Delivery Cloud.
3. Create a temporary directory such as c:\ouaf\temp or /ouaf/temp. (Referred to below as <TEMPDIR>)
Note: This directory must be located outside any current or other working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
4. Unzip Oracle Utilities Meter Data Management V2.5.0.0.0 Multiplatform.zip to get the file MDM_V2.5.0.0.0.zip from the delivered package and copy to the <TEMPDIR>. To use FTP to transfer this file, use the BINARY option.
5. Decompress the file:
cd <TEMPDIR>
unzip MDM_V2.5.0.0.0.zip
cd App
For UNIX and Windows platforms, a sub-directory named MDM.V2.5.0.0.0 is created. The contents of the installation directory are identical for both platforms. The directory contains the install software for the application product.
Installing the Oracle Utilities Meter Data Management Application Component
To install the Oracle Utilities Meter Data Management application component:
1. Login to the application server host as Oracle Utilities Application Framework Administrator (default cissys).
2. Change directory:
cd <install_dir>/bin
where <install_dir> is the location where the Oracle Utilities Application Framework application component is installed.
3. Initialize the environment by running the appropriate command:
UNIX
./splenviron.sh -e <ENV NAME>
Windows
splenviron.cmd -e <ENV NAME>
4. Navigate to <TEMPDIR>/MDM.V2.5.0.0.0 directory.
5. Run the install script.
Note: On UNIX, ensure that you have the proper execute permission on install.sh.
UNIX
ksh ./install.sh
Windows
install.cmd
6. Choose option P to proceed with the installation.
Note: The rest of the menu items can be ignored if you are installing only Oracle Utilities Meter Data Management.
The Oracle Utilities Meter Data Management installation is complete if no errors occurred during the installation.
Important! Note that the Oracle Utilities Operational Device Management installation is not different from that of Oracle Utilities Work and Asset Management installation. Installing Oracle Utilities Work and Asset Management will install Oracle Utilities Operational Device Management also.
In this release, Oracle Utilities Operational Device Management is included as part of Oracle Utilities Customer To Meter for all customers. However, the existing customers can disable the Oracle Utilities Operational Device Management functionality. Follow the manual post-installation steps to disable Oracle Utilities Operational Device Management inside the Oracle Utilities Customer To Meter stack. For instructions refer to Disabling/Enabling Oracle Utilities Operational Device Management inside Oracle Utilities Customer To Meter.
This section describes how to install the Oracle Utilities Work and Asset Management application component, including:
Copying and Decompressing the Oracle Utilities Work and Asset Management Install Media
The Oracle Utilities Work and Asset Management installation file is delivered in jar format for both UNIX and Windows platforms.
1. Login to the application server host as the administrator user ID (default cissys). This is the same user ID that was used to install the Oracle Utilities Application Framework.
2. Download the Oracle Utilities Work and Asset Management V2.4.0.0.0 Multiplatform zip file from Oracle Software Delivery Cloud.
3. Create a <TEMPDIR> directory on the host server, which is independent of any current or other working Oracle Utilities Work and Asset Management application environment.
4. Copy the WAM-V2.4.0.0.0-Multiplatform.jar file in the delivered package to a <TEMPDIR> on your host server. If you are using FTP to transfer this file, remember to use the BINARY option for the FTP transfer.
5. Decompress the file.
cd <TEMPDIR>
jar -xvf WAM-V2.4.0.0.0-Multiplatform.jar
For Windows installations, include the location of the JDK in your path before you execute the jar command.
A sub-directory W1.V2.4.0.0.0 is created for both UNIX and Windows platforms. The contents of the installation directory are identical for both platforms. The directory contains the install software for the application product.
Installing the Oracle Utilities Work and Asset Management Application Component
Follow these steps to install the Oracle Utilities Work and Asset Management application component:
2. Change the directory.
cd <install_dir>
where <install_dir> is the location where the Oracle Utilities Application Framework V4.5.0.0.0 base application component is installed.
3. Initialize the environment.
UNIX
Windows
4. Change to the <TEMPDIR>/W1.V2.4.0.0.0 directory where <install_dir> is the Oracle Utilities Work and Asset Management application component installation directory.
UNIX
ksh ./install.sh
Windows
install.cmd
5. Initialize the environment.
UNIX
Windows
6. Generate the appviewer.
Note: Before generating the appviewer, make sure that Oracle Utilities Operational Device Management is enabled or set to ON. This ensures that Data Dictionary and Javadocs are generated without errors.
a. Change the directory.
where <install_dir> is Oracle Utilities Work and Asset Management application component installation directory.
b. Generate the appviewer.
UNIX
ksh ./genappvieweritems.sh
Windows
genappvieweritems.cmd
Installing Oracle Utilities Customer To Meter V2.9.0.0.0
This section describes how to install Oracle Utilities Customer to Meter, including:
The Customer To Meter is delivered as a separate installation package that can be downloaded along with Oracle Utilities Customer To Meter V2.9.0.0.0.
Download the installation package and proceed as follows:
2. Create a <TEMPDIR> directory on the application server, which is independent of any current or other working Oracle Utilities Customer To Meter application environment. This can be the same <TEMPDIR> used during the installation of the Oracle Utilities Application Framework.
3. Copy the C2M.V2.9.0.0.0-MultiPlatform.jar file in the delivered package to a <TEMPDIR> on your application server. If you are using FTP to transfer this file, remember to use the BINARY option for the FTP transfer.
cd <TEMPDIR>
jar -xvf C2M-V2.9.0.0.0-MultiPlatform.jar
For UNIX platform, a sub-directory named C2M.V2.9.0.0.0 is created. The contents of the installation directory are identical for both platforms. The directory contains the install software for the application.
Installing the Oracle Utilities Customer To Meter Application Component
This section outlines the steps to install Oracle Utilities Customer to Meter.
1. Login as an Oracle Utilities Customer to Meter administrator (default cissys).
2. Initialize the Oracle Utilities Application Framework environment where the product should be installed.
UNIX
./splenviron.sh -e $SPLENVIRON
Windows
Installing the Application
1. Change to the <TEMPDIR>/C2M.V2.9.0.0.0 directory.
2. Run the following script.
UNIX
ksh ./install.sh
Windows
install.cmd
The Configuration menu for the Oracle Utilities Customer to Meter application appears.
3. Choose option P to proceed with the installation (you need not modify anything).
4. Start up the environment.
Follow the message on the screen and review the logs in the $SPLSYSTEMLOGS directory to ensure that the environment was started successfully.
If the startup failed, identify the problem by reviewing the logs. Resolve any issues before attempting to restart the environment.
Note: while starting the first time, log into the WebLogic console and provide system access to the ‘cisusers’ role. The WebLogic console application can be accessed through the following URL: http:// <hostname>:<portname>/console.
Installing Oracle Utilities Customer To Meter V2.9.0.0.0 Post-release Patches
The Oracle Utilities Customer To Meter patches must be installed after installing Oracle Utilities Customer To Meter.
The patches are available as a convenience rollup inside the C2M-V2.9.0.0.0-Rollup- MultiPlatform.zip file, which is part of the downloaded media pack.
To install the application and database patches on top of Oracle Utilities Customer To Meter 2.9.0.0.0:
1. Copy the C2M-V29000-Rollup-MultiPlatform.jar file in the delivered package to a <TEMPDIR>.
2. Unjar the file.
jar -xvf C2M-V29000-Rollup-MultiPlatform.jar
3. Initialize the Oracle Utilities Customer To Meter environment where the Oracle Utilities Customer To Meter patch rollup has to be installed.
UNIX
Windows
a. Navigate to the <temp location>/C2M-V2.9.0.0.0-Rollup/Application folder.
UNIX/Linux
chmod a+x C2M*/*.sh
./installSFgroup.sh
Windows
installSFgroup.cmd
