Batch Control Options
A batch control supports defining options. An option allows the product or your implementation to mark a batch control with additional information to be used for special processing or reporting.
Note. You can add new option types. Your implementation may want to add additional batch control option types. To do that, add your new values to the customizable lookup field BATCH_CTRL_OPT_FLG .
