Table | Name | Description |
D1_CONTACT_COMM* | Contact Communication | Used to store customer communications, usually as part of an enrollment or unenrollment process |
D1_CONTACT_COMM_CHAR* | Contact Communication Characteristics | Used to store characteristics associated with a customer communication |
D1_CONTACT_COMM_K* | Contact Communication Key | Used to store primary keys associated with a customer communication |
D1_CONTACT_COMM_LOG* | Contact Communication Log | Used to capture log details for a customer communication |
D1_CONTACT_COMM_LOG_PARM* | Contact Communication Log Parameters | Used to capture log parameters for a customer communication |
D1_CONTACT_COMM_REL_OBJ* | Contact Communication Related Object | Used to store related objects associated with a customer communication |
D1_DYN_OPT_QTY* | Dynamic Option Quantity | Used to store quantities related to dynamic options. |
D1_DYN_OPT_TYPE_QTY_TYPE* | Dynamic Option Type Quantity Type | Used to define type of quantities stored for dynamic option types. |
D1_IMD_CTRL_STAGE | IMD Control Staging | Used to stage IMD control records |
D1_IMD_CTRL_STAGE_K | IMD Control Staging Key | Used to store keys for staged IMD control records |
D1_IMD_TYPE | Initial Measurement Data Type | Used to capture details about types of initial measurement data |
D1_IMD_TYPE_ALG | Initial Measurement Data Type Algorithm | Used to capture algorithms related to types of initial measurement data |
D1_IMD_TYPE_L | Initial Measurement Data Type Language | Language table for Initial Measurement Data Type |
D1_MSRMT_AUDIT | Measurement Audit | Used to capture changes made to measurement data |
D1_RULE_PARM* | Rule Parameters | Used to capture parameters used by Digital Asset program rules |
D1_SPR_PROG* | Service Provider Program | Used to capture relationship between Digital Asset service providers and programs |
D1_DVC_ENTITY_GRP* | Device Entity Group | Used to define the relationship between a device and an entity group |
D1_ENTITY_GRP* | Entity Group | Used to capture groups of entities (such as service points or devices) |
D1_ENTITY_GRP_CHAR* | Entity Group Characteristics | Used to store characteristics related to a group of entities |
D1_ENTITY_GRP_CRIT* | Entity Group Criteria | Used to store criteria used to define a group of entities |
D1_ENTITY_GRP_CRIT_VAL* | Entity Group Criteria Value | Used to store criteria values used to define a group of entities |
D1_ENTITY_GRP_L* | Entity Group Language | Used to store labels for the Entity Group table |
D1_SP_ENTITY_GRP* | Service Point Entity Group | Used to define the relationship between a service point and an entity group |
Table_Name | Column_Name | Data Type | Data Length |
D1_DYN_OPT_EVENT | DYN_OPT_EXT_ID_VALUE* | VARCHAR2 | 120 |
D1_DYN_OPT_TYPE | DYN_OPT_CATEGORY* | VARCHAR2 | 254 |
D1_DYN_OPT_TYPE | DEVICE_REQD_FLG* | CHAR | 4 |
D1_EVT_PARTICIPATION | RESERVATION_START_DTTM* | DATE | 26 |
D1_EVT_PARTICIPATION | RESERVATION_END_DTTM* | DATE | 26 |
D1_EVT_PARTICIPATION | ILM_DT* | DATE | 10 |
D1_EVT_PARTICIPATION | ILM_ARCH_SW* | CHAR | 1 |
D1_SP | D1_INSTALL_DT* | DATE | 10 |
D1_DYN_OPT_QUESTION* | RESPONSE_REQ_FLG | CHAR | 4 |
D1_DYN_OPT_QUESTION* | QUESTION_CATEGORY | VARCHAR2 | 254 |
D1_DYN_OPT_TYPE* | LOCATION_REQD_SOURCE_FLG | CHAR | 4 |
D1_US* | PGM_ENRL_SRC_FLG | CHAR | 4 |
D1_USAGE* | EXTRACT_FLG | CHAR | 4 |
D1_USAGE_PERIOD_SQ | D1_PRICE* | NUMBER | 19 |
D1_DYN_OPT_QTY | DYN_OPT_ID* | CHAR | 12 |
D1_DYN_OPT_QTY | DYN_OPT_QTY* | NUMBER | 16,6 |
D1_DYN_OPT_QTY | DYN_OPT_QTY_TYPE* | VARCHAR2 | 254 |
D1_DYN_OPT_QTY | END_DTTM* | DATE | |
D1_DYN_OPT_QTY | START_DTTM* | DATE | |
D1_DYN_OPT_QTY | VERSION* | NUMBER | 5 |
D1_DYN_OPT_TYPE_QTY_TYPE | DYN_OPT_TYPE_CD* | VARCHAR2 | 30 |
D1_DYN_OPT_TYPE_QTY_TYPE | DYN_OPT_TYPE_QTY_TYPE* | VARCHAR2 | 254 |
D1_DYN_OPT_TYPE_QTY_TYPE | VERSION* | NUMBER | 5 |
D1_MEASR_COMP_SET | DISTRIBUTE_LOAD_FLG | CHAR | 4 |
D1_MEASR_COMP_SET | LOAD_DISTRIBUTION_FORMULA | VARCHAR2 | 254 |
D1_MEASR_COMP_SET | LOAD_DIST_MANAGED_BY_FLG | CHAR | 4 |
D1_MEASR_COMP_SET | NBR_OF_DIGITS_TO_USE | NUMBER | 1 |
D1_MEASR_COMP_TYPE | ANCHR_TIME | DATE | |
D1_US_TYPE | PROC_TIMETABLE_TYPE_CD | VARCHAR2 | 30 |
D1_CONTACT | ADDRESS1 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS1_UPPER | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS2 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS3 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS4 | VARCHAR2 | 1016 |
D1_CONTACT | CITY | VARCHAR2 | 360 |
D1_CONTACT | CITY_UPPER | VARCHAR2 | 360 |
D1_CONTACT | COUNTRY | CHAR | 12 |
D1_CONTACT | COUNTY | VARCHAR2 | 360 |
D1_CONTACT | GEO_CODE | CHAR | 44 |
D1_CONTACT | HOUSE_TYPE | CHAR | 8 |
D1_CONTACT | IN_CITY_LIMIT | CHAR | 4 |
D1_CONTACT | NUM1 | CHAR | 24 |
D1_CONTACT | NUM2 | CHAR | 16 |
D1_CONTACT | POSTAL | CHAR | 48 |
D1_CONTACT | STATE | CHAR | 24 |
D1_CONTACT_TYPE | CONTACT_USE_FLG | CHAR | 16 |
D1_DVC | DER_AGG_SPR_CD* | VARCHAR2 | 120 |
D1_IMD_CTRL_STAGE | ALG_CD | CHAR | 48 |
D1_IMD_CTRL_STAGE | D1_FROM_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | D1_TO_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | IMD_CTRL_DC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_MC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_CTRL_STAGE | IMD_STAGE_PAYLOAD_XML | CLOB | 4000 |
D1_IMD_CTRL_STAGE | IMD_STAGE_STATUS_FLG | CHAR | 16 |
D1_IMD_CTRL_STAGE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_CTRL_STAGE_K | ENV_ID | NUMBER | 22 |
D1_IMD_CTRL_STAGE_K | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_TYPE | BO_DATA_AREA | CLOB | 4000 |
D1_IMD_TYPE | BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_SEEDER_FLG | CHAR | 16 |
D1_IMD_TYPE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE | IMD_TYPE_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE | VERSION | NUMBER | 22 |
D1_IMD_TYPE_ALG | ALG_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | ERROR_BO_STATUS_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | IMD_TYPE_ALG_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_ALG | IMD_TYPE_SEVT_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | SEQ_NUM | NUMBER | 22 |
D1_IMD_TYPE_ALG | VERSION | NUMBER | 22 |
D1_IMD_TYPE_L | DESCR100 | VARCHAR2 | 400 |
D1_IMD_TYPE_L | DESCRLONG | VARCHAR2 | 16000 |
D1_IMD_TYPE_L | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_L | LANGUAGE_CD | CHAR | 12 |
D1_IMD_TYPE_L | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_L | VERSION | NUMBER | 22 |
D1_MSRMT_AUDIT | COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | LOG_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | MEASR_COMP_ID | CHAR | 48 |
D1_MSRMT_AUDIT | MSRMT_AUDIT_ENTRY_TYPE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | SEQNO | NUMBER | 22 |
D1_MSRMT_AUDIT | USER_ID | CHAR | 32 |
D1_NW_LOC | NETWORK_NODE_1 | CHAR | 56 |
D1_NW_LOC | NETWORK_NODE_2 | CHAR | 56 |
D1_RULE_PARM | CALC_FREQUENCY* | VARCHAR2 | 1016 |
D1_RULE_PARM | D1_SEASONAL_FLG* | CHAR | 16 |
D1_RULE_PARM | ELIG_ALG_CD* | CHAR | 48 |
D1_RULE_PARM | LINE_EXT_ID* | VARCHAR2 | 1016 |
D1_RULE_PARM | MIN_DAYS* | NUMBER | 22 |
D1_RULE_PARM | PRORATE_OPTION_FLG* | CHAR | 16 |
D1_RULE_PARM | RULE_CD* | VARCHAR2 | 120 |
D1_RULE_PARM | RULE_TYPE_CATEGORY* | VARCHAR2 | 1016 |
D1_RULE_PARM | SEASON_END* | CHAR | 16 |
D1_RULE_PARM | SEASON_START* | CHAR | 16 |
D1_RULE_PARM | SEQNO* | NUMBER | 22 |
D1_RULE_PARM | SETT_FREQ_FLG* | CHAR | 16 |
D1_RULE_PARM | USG_GRP_CD* | VARCHAR2 | 120 |
D1_RULE_PARM | VERSION* | NUMBER | 22 |
D1_SPR | ACTIVE_INACTIVE_FLG* | CHAR | 16 |
D1_SPR | CONTACT_ID* | CHAR | 48 |
D1_SPR | END_DT* | DATE | 7 |
D1_SPR | START_DT* | DATE | 7 |
D1_SPR_PROG | D1_SPR_CD* | VARCHAR2 | 120 |
D1_SPR_PROG | DYN_OPT_ID* | CHAR | 48 |
D1_SPR_PROG | END_DT* | DATE | 7 |
D1_SPR_PROG | SPR_LFDI* | VARCHAR2 | 1016 |
D1_SPR_PROG | START_DT* | DATE | 7 |
D1_USAGE | RULE_CD* | VARCHAR2 | 120 |
D1_USAGE | RULE_TYPE_CATEGORY* | VARCHAR2 | 1016 |
D1_DVC_ENTITY_GRP* | BO_DATA_AREA | CLOB | 4000 |
D1_DVC_ENTITY_GRP* | D1_DEVICE_ID | CHAR | 48 |
D1_DVC_ENTITY_GRP* | EFF_DTTM | DATE | 7 |
D1_DVC_ENTITY_GRP* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_DVC_ENTITY_GRP* | EXPIRATION_DTTM | DATE | 7 |
D1_DVC_ENTITY_GRP* | VERSION | NUMBER | 22 |
D1_ENTITY_GRP* | BO_DATA_AREA | CLOB | 4000 |
D1_ENTITY_GRP* | BUS_OBJ_CD | CHAR | 120 |
D1_ENTITY_GRP* | ENTITY_GRP_ASSGN_OPT_FLG | CHAR | 16 |
D1_ENTITY_GRP* | ENTITY_GRP_CATEGORY | VARCHAR2 | 1016 |
D1_ENTITY_GRP* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP* | ENTITY_GRP_DEACT_OPT_FLG | CHAR | 16 |
D1_ENTITY_GRP* | ENTITY_GRP_STAT_FLG | CHAR | 16 |
D1_ENTITY_GRP* | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CHAR* | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CHAR* | CHAR_TYPE_CD | CHAR | 32 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL | CHAR | 64 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CHAR* | SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CHAR* | SRCH_CHAR_VAL | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR* | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CRIT* | CRITERIA_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CRIT* | GRP_CRITERIA_SRC | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CRIT* | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL* | BO_DATA_AREA | CLOB | 4000 |
D1_ENTITY_GRP_CRIT_VAL* | CRITERIA_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL* | CRITERIA_VALUE | CHAR | 200 |
D1_ENTITY_GRP_CRIT_VAL* | CRITERIA_VAL_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CRIT_VAL* | GRP_CRITERIA_SRC | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CRIT_VAL* | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_L* | DESCR100 | VARCHAR2 | 400 |
D1_ENTITY_GRP_L* | DESCRLONG | VARCHAR2 | 16000 |
D1_ENTITY_GRP_L* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_L* | LANGUAGE_CD | CHAR | 12 |
D1_ENTITY_GRP_L* | VERSION | NUMBER | 22 |
D1_MEASR_COMP_TYPE | IMD_HANDLING_FLG | CHAR | 16 |
D1_MSRMT | PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT | PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT | PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT | PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT | USER_ID | CHAR | 32 |
D1_MSRMT_AUDIT | AFTER_COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | AFTER_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | AFTER_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | BEFORE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_READING_VAL | NUMBER | 22 |
D1_SPR_PROG | UTILITY_APPROVAL_REQD_FLG | CHAR | 16 |
D1_SP_ENTITY_GRP* | BO_DATA_AREA | CLOB | 4000 |
D1_SP_ENTITY_GRP* | D1_SP_ID | CHAR | 48 |
D1_SP_ENTITY_GRP* | EFF_DTTM | DATE | 7 |
D1_SP_ENTITY_GRP* | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_SP_ENTITY_GRP* | EXPIRATION_DTTM | DATE | 7 |
D1_SP_ENTITY_GRP* | VERSION | NUMBER | 22 |
D1_EVT_PARTICIPATION | EFF_DTTM | DATE | |
Table_Name | Column_Name | Old Length | New Length |
D1_DYN_OPT_QUESTION* | D1_ANSWER_CD | NOT NULL | NULLABLE |
D1_GTT4 | MAINT_OBJ_CD | NOT NULL | NULLABLE |
D1_GTT4 | D1_DEVICE_ID | NOT NULL | NULLABLE |
D1_GTT4 | D1_SP_ID | NOT NULL | NULLABLE |
D1_GTT4 | DEVICE_TYPE_CD | NOT NULL | NULLABLE |
D1_GTT4 | MSRMT_DTTM | NOT NULL | NULLABLE |
D1_GTT7 | D1_SP_ID | NOT NULL | NULLABLE |
D1_GTT7 | D1_SP_TYPE_CD | NOT NULL | NULLABLE |
D1_GTT7 | TIME_ZONE_CD | NOT NULL | NULLABLE |
D1_GTT7 | US_ID | NOT NULL | NULLABLE |
D1_GTT7 | US_TYPE_CD | NOT NULL | NULLABLE |
D1_GTT8 | D1_SP_ID | NOT NULL | NULLABLE |
D1_GTT8 | D1_QUANTITY1 | NOT NULL | NULLABLE |
D1_GTT8 | D1_QUANTITY2 | NOT NULL | NULLABLE |
D1_GTT8 | D1_QUANTITY3 | NOT NULL | NULLABLE |
D1_GTT8 | D1_QUANTITY4 | NOT NULL | NULLABLE |
D1_GTT8 | D1_QUANTITY5 | NOT NULL | NULLABLE |
D1_GTT8 | US_ID | NOT NULL | NULLABLE |
D1_USAGE_SCALAR_DTL | USE_PERCENT | Number (9,6) | Number (5,2) |
D1_US_SP | USE_PERCENT | Number (9,6) | Number (5,2) |
Table_Name | Index_Name |
D1_GTT4 | D1T407S0 |
D1_GTT7 | D1T554S0 |
D1_GTT8 | D1T555S0 |
D1_CONTACT_COMM* | D1T653P0 |
D1_CONTACT_COMM* | D1T653S1 |
D1_CONTACT_COMM_CHAR* | D1T655P0 |
D1_CONTACT_COMM_CHAR* | D1T655S1 |
D1_CONTACT_COMM_K* | D1T654P0 |
D1_CONTACT_COMM_LOG* | D1T656P0 |
D1_CONTACT_COMM_LOG_PARM* | D1T657P0 |
D1_CONTACT_COMM_REL_OBJ* | D1T658P0 |
D1_DYN_OPT_EVENT* | D1T230S1 |
D1_DYN_OPT_EVENT* | D1T230S2 |
D1_DYN_OPT_EVENT* | D1T230S3 |
D1_DYN_OPT_QTY | D1M659P0 |
D1_DYN_OPT_TYPE_QTY_TYPE | D1C660P0 |
D1_CONTACT | D1M180S0 |
D1_IMD_CTRL_STAGE | D1T661P0 |
D1_IMD_CTRL_STAGE | D1T661S0 |
D1_IMD_CTRL_STAGE | D1T661S1 |
D1_IMD_CTRL_STAGE_K | D1T663P0 |
D1_IMD_TYPE | D1C664P0 |
D1_IMD_TYPE_ALG | D1C666P0 |
D1_IMD_TYPE_L | D1C665P0 |
D1_MSRMT_AUDIT | D1T662P0 |
D1_RULE_PARM | D1C667P0 |
D1_SPR_PROG | D1C668P0 |
D1_DVC_ENTITY_GRP | D1M674P0 |
D1_DVC_ENTITY_GRP | D1M674S0 |
D1_ENTITY_GRP | D1C675P0 |
D1_ENTITY_GRP_CHAR | D1C670P0 |
D1_ENTITY_GRP_CRIT | D1C671P0 |
D1_ENTITY_GRP_CRIT_VAL | D1C672P0 |
D1_ENTITY_GRP_L | D1C669P0 |
D1_SP_ENTITY_GRP | D1M673P0 |
D1_SP_ENTITY_GRP | D1M673S0 |
D1_GTT4 | D1T407P0 |
D1_GTT7 | D1T554P0 |
D1_GTT8 | D1T555P0 |
Table_Name | Old_Index_Name | New_Index_Name |
D1_DYN_OPT_TYPE_QTY_TYPE | D1660CP0 | D1C660P0 |
Table_Name |
D1_GTT10 |
D1_GTT4 |
D1_GTT7 |
D1_GTT8 |
D1_GTT9 |
View_Name |
D1_MC_TYPE_PER_EST_EVAL_VW |
