ILM Database Administrator’s Tasks
For a database administrator, there are two key phases involved with managing your data using ILM.
• Preparation Phase: This phase covers the database level configuration that needs to be done before the ILM solution runs in a production environment.
• On-going Maintenance Phase: This phase covers the ongoing maintenance tasks.
Preparation Phase
Note: In order to successfully implement ILM as described here, the following DB Version and Patch are pre-requisites: database version 19.3.0.0 or newer.
The steps needed to enable ILM functionality differ depending on whether ILM is enabled as part of the initial implementation of the product or enabled ILM on an existing implementation where data already exists in the respective tables.
• Initial Install – For an initial installation, the section Module Specific ILM Implementation Details outlines the additional steps to be performed on base delivered ILM Enabled Tables to conform to ILM requirements. In addition, Appendix E: Sample SQL for Enabling ILM in C2M for MDM (Initial Install)Appendix E: Sample SQL for Enabling ILM for MDM (Initial Install) provides sample reference DDLs using two maintenance objects as examples.
• Transform NON-ILM implementation to ILM Enabled Implementation: The following steps provide a high level overview of steps that must be performed to implement ILM on enabled maintenance objects for an existing implementation. The Appendix F: Sample SQL For Enabling ILM in C2M for MDM (Existing Installation)Appendix F: Sample SQL For Enabling ILM for MDM (Existing Installation) provides detailed information using To Do Entry as an example. Also refer to Appendix C: Sample SQL for Enabling ILM with Sub Retention in MDM (Existing Installation)Appendix G: Sample SQL for Enabling ILM with Sub Retention in MDM (Existing Installation) or detailed information using D1_INIT_MSRMT_DATA as an example.
1. Rename the existing tables (Parent table followed by child table), and primary key index associated with ILM enabled maintenance objects by renaming the tables.
2. Save the DDLs for the secondary indexes as you will need to recreate them later.
3. Drop secondary indexes on the renamed tables.
4. Create Partitioned table with no secondary indexes for ILM enabled maintenance objects using a CTAS operation (Create Table as Select), which will also load the data into the partitioned table structure.
Functional Note: ILM enabled maintenance objects should have the ILM date (ILM_DT) populated when data is moved into the new partitioned table. Please refer to the Module Specific ILM Implementation Details section below for initial load details on which date column to use as the basis for populating the ILM date. Often it is based on Create Date (CRE_DTTM). ILM_ARCH_SW should initially be set to ‘N’.
Note: Certain ILM enabled maintenance objects, specifically IMD, Device Event, and Activity, support more than one retention period also known as sub retention periods. For these maintenance objects the table will be sub-partitioned based on the retention period. Furthermore, a more detailed approach will be required to set both the ILM date (ILM_DT) and the retention period (<field name>). If your implementation does not wish to leverage the ability to define multiple retention periods for these maintenance objects, this note can be ignored and the general guidelines for ILM enablement can be followed. If your implementation wishes to leverage the multiple retention period capability then please refer to the section Module Specific ILM Implementation Details For Sub Retention below.
5. Enable logging option.
6. Create Primary Key index.
7. Create Primary Key Constraint of parent table.
8. Create secondary indexes for the newly-created partitioned tables. This includes creating an index used specifically to benefit the ILM Crawler batch. The recommendation for this index name is to prefix it with “ILM”.
Note: This can be created specifying parallel index create; remember to turn off parallelism after the index is created.
9. Follow a similar operation for all child tables for this maintenance object, such as rename child table, and primary key index, generate DDL for secondary index, drop secondary index etc. Sample DDL for child tables their partitioning and indexes can be found in Appendix F: Sample SQL For Enabling ILM in C2M for MDM (Existing Installation)Appendix F: Sample SQL For Enabling ILM for MDM (Existing Installation). If sub retention is supported, sample DDL for child tables can be found in Appendix G: Sample SQL for ILM in C2M with Sub Retention (Existing Installation)Appendix G: Sample SQL for Enabling ILM with Sub Retention in MDM (Existing Installation). Please note that child table should be partitioned using reference partitioning of the parent table’s partitioning key.
10. Drop the original, renamed tables after verifying the newly created partitioned tables.
11. If sub-retention is not supported, create the ILM specific indexes from section Module Specific ILM Implementation Details.
Table Name
Index Name
CI_TD_ENTRY
CM_ILM_XT039S8
D1_ACTIVITY
CM_ILM_D1T319S1
D1_COMM_IN
CM_ILM_D1T386S1
D1_COMM_OUT
CM_ILM_D1T380S1
D1_COMPL_EVT
CM_ILM_D1T340S1
D1_DVC_EVT
CM_ILM_D1T400S4
D1_INIT_MSRMT_DATA
CM_ILM_D1T304S4
D1_USAGE
CM_ILM_D1T281S2
D1_USAGE_EXCP
CM_ILM_D1T443S1
D1_VEE_EXCP
CM_ILM_D1T308S2
D1_SP_SNAP_DL
CM_ILM_D1T434S1
D1_SP_UNR_USG_SNAP_DL
CM_ILM_D1T438S1
D1_SP_USG_SNAP_DL
CM_ILM_D1T436S1
D1_SP_VEE_EXCP_SNAP_DL
CM_ILM_D1T440S1
F1_BUS_FLG
CM_ILM_F1T681S2
F1_ERASURE_SCHED
CM_ILM_F1T756S1
F1_OBJ_REV
CM_ILM_FT035S6
F1_OUTMSG
CM_ILM_FT010S2
F1_PROC_STORE
CM_ILM_F1T747S1
F1_REMOTE_MSG
CM_ILM_F1T735S7
F1_STATS_SNPSHT
CM_ILM_F1C706S2
F1_SVC_TASK
CM_ILM_F1C474S3
F1_SYNC_REQ
CM_ILM_F1T014S4
F1_SYNC_REQ_IN
CM_ILM_F1T191S3
12. If sub-retention is supported, create the following ILM specific indexes from the Module Specific ILM Implementation Details section:
Table Name
Index Name
CI_TD_ENTRY
CM_ILM_XT039S8
D1_COMM_IN
CM_ILM_D1T386S1
D1_COMM_OUT
CM_ILM_D1T380S1
D1_COMPL_EVT
CM_ILM_D1T340S1
D1_USAGE
CM_ILM_D1T281S2
D1_USAGE_EXCP
CM_ILM_D1T443S1
D1_VEE_EXCP
CM_ILM_D1T308S2
D1_SP_SNAP_DL
CM_ILM_D1T434S1
CM_ILM_D1T438S1
D1_SP_USG_SNAP_DL
CM_ILM_D1T436S1
CM_ILM_D1T440S1
F1_BUS_FLG
CM_ILM_F1T681S2
F1_ERASURE_SCHED
CM_ILM_F1T756S1
F1_OBJ_REV
CM_ILM_FT035S6
F1_OUTMSG
CM_ILM_FT010S2
F1_PROC_STORE
CM_ILM_F1T747S1
F1_REMOTE_MSG
CM_ILM_F1T735S7
F1_STATS_SNPSHT
CM_ILM_F1C706S2
F1_SVC_TASK
CM_ILM_F1C474S3
F1_SYNC_REQ
CM_ILM_F1T014S4
F1_SYNC_REQ_IN
CM_ILM_F1T191S3
and the ILM subretention specific indexes from the Module Specific ILM Implementation Details For Sub Retention section:
Table Name
Index Name
D1_ACTIVITY
CM_ILM_D1T319S1
D1_DVC_EVT
CM_ILM_D1T400S4
D1_INIT_MSRMT_DATA
CM_ILM_D1T304S4
This section outlines each maintenance object that has been configured to support ILM. The parent table is noted. Other tables are child tables of the parent unless otherwise noted. In each case, the partitioning strategy is indicated.
All indexes are listed with a recommendation whether the index should be global or local and whether the index should be partitioned. In addition to the base delivered indexes, each parent table includes a recommended ILM specific local index to build with the ILM_DT, ILM_ARCH_SW and the primary key of the table. The recommended column that should be used to populate the ILM_DT is also shown.
This section details the following maintenance objects:
• VEE Exception
To Do Entry
This table describes the To Do Entry maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
CI_TD_ENTRY
(Parent)
RANGE (ILM_DT,
TD_ENTRY_ID)
CI_TD_ENTRY.
CRE_DTTM
XT039P0
TD_ENTRY_ID
Global
Partitioned
RANGE
(TD_ENTRY_ID)
XT039S2
ASSIGNED_TO,
TD_ENTRY_ID
Global
XT039S3
ENTRY_STATUS_FLG,
ASSIGNED_TO
Global
XT039S4
ROLE_ID, TD_TYPE_CD, ENTRY_STATUS_FLG, TD_PRIORITY_FLG, ASSIGNED_TO, CRE_DTTM
Global
XT039S5
BATCH_CD,
BATCH_NBR,
ENTRY_STATUS_FLG
Global
XT039S6
TD_ENTRY_ID,
ASSIGNED_TO,
ENTRY_STATUS_FLG
Global
XT039S7
COMPLETE_USER_ID,
COMPLETE_DTTM,
TD_ENTRY_ID
Global
CM_ILM_XT039S8
ILM_DT, ILM_ARCH_SW,
TD_ENTRY_ID
Local
Partitioned
CI_TD_ENTRY_CHA
Reference Partitioning
XT701P0
TD_ENTRY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
XT701S1
SRCH_CHAR_VAL,
CHAR_TYPE_CD,
TD_ENTRY_ID
Global
XT701S2
CHAR_VAL_FK1
Global
CI_TD_DRLKEY
XT037P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT037S1
KEY_VALUE,
TD_ENTRY_ID
Global
CI_TD_LOG
XT721P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT721S1
LOG_DTTM,USER_ID,
LOG_TYPE_FLG,
TD_ENTRY_ID
Global
CI_TD_MSG_
PARM (Child table of CI_TD_LOG)
XT040P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
CI_TD_SRTKEY
XT041P0
TD_ENTRY_ID,
SEQ_NUM
Global Partitioned
XT041S1
KEY_VALUE,
TD_ENTRY_ID
Global
Sync Request (Outbound)
This table describes the Sync Request (Outbound) maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SYNC_REQ
(Parent)
RANGE (ILM_DT, F1_SYNC_REQ_
ID)
RANGE
(F1_SYNC_REQ_ID)
F1_SYNC_REQ.CRE_DTTM
F1T014P0
F1_SYNC_REQ_ID
Global Partitioned
F1T014S1
BO_STATUS_CD,
BUS_OBJ_CD,
F1_SYNC_REQ_ID
Global
F1T014S2
BO_STATUS_
REASON_CD
Global
F1T014S3
MAINT_OBJ_CD, PK_VALUE1,
PK_VALUE2,
F1_SYNC_REQ_ID
Global
CM_ILM_F1T014S4
ILM_DT,
ILM_ARC_SW,
F1_SYNC_REQ_ID
Local
Partitioned
F1_SYNC_REQ_CHAR
F1T017P0
F1_SYNC_REQ_ID,
CHAR_TYPE_CD, SEQ_NUM
Global Partitioned
F1T017S1
SRCH_CHAR_VAL
Global
F1_SYNC_REQ_EXTRACT
F1T019P0
F1_SYNC_REQ_ID,
SEQ_NUM
Global Partitioned
F1_SYNC_REQ_LOG
F1T015P0
F1_SYNC_REQ_ID,
SEQNO
Global Partitioned
F1T015S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T015S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1T015S3
BO_STATUS_REASON_CD
Global
F1_SYNC_REQ_LOG_PARM
(Child Table of F1_SYNC_REQ_LOG_PARM)
F1T016P0
F1_SYNC_REQ_ID,
SEQNO,
PARM_SEQ
Global Partitioned
Note: It is recommended that data retention policies and rules for this object match the policies and rules implemented for the Inbound Sync Request on the target system to avoid data inconsistencies when auditing.
This table describes the Inbound Sync Request maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SYNC_REQ_IN
(Parent)
RANGE(ILM_DT, F1_SYNC_REQ_IN_ID)
RANGE
(F1_SYNC_REQ_IN_ID)
F1_SYNC_REQ_IN.CRE_DTTM
F1T191P0
F1_SYNC_REQ_
IN_ID
Global Partitioned
F1T191S1
BO_STATUS_CD,
BUS_OBJ_CD,
F1_SYNC_REQ_
IN_ID
Global
F1T191S2
MAINT_OBJ_CD, EXT_PK_VALUE1, NT_XID_CD, PK_VALUE1
Global
CM_ILM_F1T191S3
F1_SYNC_REQ_IN_ID
Local
Partitioned
F1_SYNC_REQ_
IN_CHAR
F1T193P0
F1_SYNC_REQ_IN_ID, CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T193S1
SRCH_CHAR_VAL
Global
F1_SYNC_REQ_
IN_EXCP
F1T197P0
F1_SYNC_REQ_IN_ID, SEQNO
Global Partitioned
F1_SYNC_REQ_
IN_EXCP_PARM
(Child Table of F1_SYNC_REQ_IN_EXCP)
F1T198P0
F1_SYNC_REQ_IN_ID, SEQNO,
PARM_SEQ
Global Partitioned
F1_SYNC_REQ_
IN_LOG
F1T194P0
Global Partitioned
F1T194S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T194S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_SYNC_REQ_IN_LOG_PARM
(Child Table of F1_SYNC_REQ_IN_LOG)
F1T195P0
F1_SYNC_REQ_IN_ID,
SEQNO, PARM_SEQ
Global Partitioned
F1_SYNC_REQ_IN_REL_OBJ
F1T192P0
F1_SYNC_REQ_IN_ID, MAINT_OBJ_CD, REL_OBJ_TYPE_FLG
Global Partitioned
Note: It is recommended that data retention policies and rules for this object match the policies and rules implemented for the Outbound Sync Request on the source system to avoid data inconsistencies when auditing.
Outbound Message
This table describes the Outbound Message maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_OUTMSG
(Parent)
RANGE (ILM_DT,
OUTMSG_ID)
RANGE (OUMSG_ID)
F1_OUTMSG.
CRE_DTTM
FT010P0
OUTMSG_ID
Global
Partitioned
FT010S1
OUTMSG_STATUS_FLG, OUTMSG_TYPE_CD
Global
CM_ILM_FT010S2
ILM_DT, ILM_ARC_SW,
OUTMSG_ID
Local
Partitioned
F1_OUTMSG_
ERRPARM
FT011P0
OUTMSG_ID, PARM_SEQ
Global
Partitioned
Service Task
This table describes the Service Task maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_SVC_TASK
(Parent)
RANGE (ILM_DT, F1_SVC_TASK_ID)
RANGE (F1_SVC_TASK_
ID_)
F1_SVC_TASK.
CRE_DTTM
F1C474P0
F1_SVC_TASK_ID
Global
Partitioned
F1C474S1
F1_STASK_TYPE_CD
Global
F1C474S2
BUS_OBJ_CD
Global
CM_ILM_F1C474S2
ILM_DT, ILM_ARC_SW,
F1_SVC_TASK_ID
Local
Partitioned
F1_SVC_TASK_
CHAR
F1C476P0
F1_SVC_TASK_ID, CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1C476S1
SRCH_CHAR_VAL
Global
F1_SVC_TASK_
LOG
F1C477P0
F1_SVC_TASK_ID,
SEQNO
Global Partitioned
F1C477S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1C477S2
CHAR_TYPE_CD, CHAR_VAL
Global
F1_SVC_TASK_
LOG_PARM
(Child Table of F1_SVC_TASK_
LOG)
F1C478P0
F1_SVC_TASK_ID, SEQNO,
PARM_SEQ
Global Partitioned
F1_SVC_TASK_
REL_OBJ
F1C479P0
F1_SVC_TASK_ID,
MAINT_OBJ_CD,
SEQ_NUM
Global Partitioned
F1C479S1
MAINT_OBJ_CD, PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5
Global
Object Revision
This table describes the Object Revision maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_OBJ_REV
(Parent)
RANGE (ILM_DT, REV_ID)
RANGE (REV_ID)
F1_OBJ_REV. STATUS_UPD_DTTM
FT035P0
REV_ID
Global
Partitioned
FT035S1
BO_STATUS_CD,
BUS_OBJ_CD,
REV_ID
Global
FT035S2
MAINT_OBJ_CD,
PK_VALUE1
Global
FT035S3
EXT_REFERENCE_ID,
MAINT_OBJ_CD
Global
FT035S4
USER_ID,
MAINT_OBJ_CD
Global
FT035S5
PK_VALUE1
Global
CM_ILM_
FT035S6
ILM_DT,
ILM_ARC_SW,
REV_ID
Local
Partitioned
F1_OBJ_REV_
CHAR
FT037P0
REV_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
FT037S1
SRCH_CHAR_VAL
Global
F1_OBJ_REV_
LOG
FT039P0
REV_ID, SEQNO
Global Partitioned
F1_OBJ_REV_
LOG_PARM
(Child Table of F1_OBJ_REV_
LOG)
FT040P0
REV_ID, SEQNO, PARM_SEQ
Global Partitioned
Note: This maintenance object is enabled for ILM, however it is not used in a production environment. It is typically used in a development or configuration environment. Your implementation should review its use of this functionality and consider whether or not it is a candidate for ILM and in which region.
Business Flag
This table describes the Business Flag maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_BUS_FLG
(Parent)
RANGE (ILM_DT,BUS_FLG_ID)
RANGE(BUS_FLG_ID)
F1_BUS_FLG.
CRE_DTTM
F1T681P0
BUS_FLG_ID
Global Partitioned
F1T681S1
BUS_OBJ_CD,
BO_STATUS_CD,
BUS_FLG_ID
Global
CM_ILM_
F1T681S2
ILM_DT,
ILM_ARCH_SW,
BUS_FLG_ID
Local Partitioned
F1_BUS_FLG_
CHAR
F1T684P0
BUS_FLG_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T684S0
SRCH_CHAR_VAL
Global
F1_BUS_FLG_
LOG
F1T685P0
BUS_FLG_ID,
SEQNO
Global Partitioned
F1T685S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T685S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_BUS_FLG_
LOG_PARM
F1T686P0
BUS_FLG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_BUS_FLG_
REL
F1T682P0
BUS_FLG_ID,
BUS_FLG_REL_
TYPE_FLG,
SEQ_NUM
Global Partitioned
F1_BUS_FLG_
REL_OBJ
F1T683P0
BUS_FLG_ID,
BUS_FLG_REL_
OBJ_TYPE_FLG,
SEQ_NUM
Global Partitioned
Remote Message
This table describes the Remote Message maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_REMOTE_
MSG (Parent)
RANGE
(ILM_DT,F1_REMOTE_MSG_ID)
RANGE(F1_REMOTE_MSG_ID)
F1_REMOTE_MSG.CRE_DTTM
F1T735P0
F1_REMOTE_MSG _ID
Global Partitioned
F1T735S1
CRE_DTTM
Global
F1T735S2
F1_MDT_ID
Global
F1T735S3
MAINT_OBJ_CD
Global
F1T735S4
PK_VALUE1
Global
F1T735S5
F1_DEVICE_MSG_ID
Global
F1T735S6
F1_MDT_ID,
F1_MSG_CLASS_
FLG,
F1_DELIVERY_
STATE_FLG
Global
CM_ILM_
F1T735S7
ILM_DT,
ILM_ARCH_SW,
F1_REMOTE_MSG_ID
Local Partitioned
F1_REMOTE_MSG_CHAR
F1T736P0
F1_REMOTE_MSG_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1T736S1
SRCH_CHAR_VAL
Global
F1_REMOTE_
MSG_LOG
F1T737P0
F1_REMOTE_MSG_ID, SEQNO
Global Partitioned
F1T737S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1T737S2
CHAR_TYPE_CD,
CHAR_VAL
Global
F1_REMOTE_
MSG_LOG_
PARM
F1T738P0
F1_REMOTE_MSG_ID,
SEQNO,
PARM_SEQ
Global Partitioned
Statistics Snapshot
This table describes the Statistics Snapshot maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_STATS_
SNPSHT(
Parent)
RANGE (ILM_DT,
SNAPSHOT_ID)
RANGE
(SNAPSHOT_ID)
F1_STATS_
SNPSHT.
CRE_DTTM
F1C706P0
SNAPSHOT_ID
Global Partitioned
F1C706S1
BUS_OBJ_CD,
BO_STATUS_CD,
SNAPSHOT_ID
Global
CM_ILM_
F1C706S2
ILM_DT,
ILM_ARCH_SW,
SNAPSHOT_ID
Local Partitioned
F1_STATS_
SNPSHT_CHAR
F1C707P0
SNAPSHOT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
F1C707S1
SRCH_CHAR_VAL
Global
F1_STATS_
SNPSHT_LOG
F1C708P0
SNAPSHOT_ID,
SEQNO
Global Partitioned
F1C708S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
F1C708S2
SNAPSHOT_ID,
SEQNO,
PARM_SEQ
Global Partitioned
F1_STATS_
SNPSHT_REL_
OBJ
F1C710P0
SNAPSHOT_ID,
STATS_SNPSHT_
REL_OBJ_TYPE_
FLG,
SEQ_NUM
Global Partitioned
Object Erasure
This table describes the Object Erasure maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_ERASURE_SCHED (Parent)
RANGE (ILM_DT, ERASURE_SCHED_ID)
F1_ERASURE_
SCHED.STATUS_UPD_DTTM
F1T756P0
ERASURE_SCHED_ID
GLOBAL Partitioned
RANGE (ERASURE_SCHED_ID)
CM_ILM_
F1T756S1
ILM_DT,
ILM_ARCH_SW,
ERASURE_SCHED_ID
LOCAL Partitioned
F1_ERASURE_SCHED_LOG
Reference partitioning
F1T757P0
ERASURE_SCHED_ID,
SEQNO
GLOBAL Partitioned
F1_ERASURE_SCHED_LOG_PARM
F1T758P0
ERASURE_SCHED_ID,
SEQNO,
PARM_SEQ
GLOBAL Partitioned
Process Flow
This table describes the Process Flow maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
F1_PROC_STORE (Parent)
RANGE(ILM_
DT, PROC_
STORE_ID)
F1_PROC_STORE.STATUS_UPD_DTTM
F1T747P0
PROC_STORE_ID
GLOBAL Partitioned
RANGE(PROC_
STORE_ID)
CM_ILM_
F1T747S1
ILM_DT,
ILM_ARCH_SW,
PROC_STORE_ID
LOCAL Partitioned
F1_PROC_STORE_DTL_ELEMENTS
F1T748P0
PROC_STORE_ID,
CHAR_TYPE_CD,
SEQ_NUM
GLOBAL Partitioned
F1_PROC_
STORE_LOG
F1T749P0
PROC_STORE_ID,
SEQNO
GLOBAL
Partitioned
F1_PROC_STORE_LOG_PARM
F1T750P0
PROC_STORE_ID
SEQNO,
PARM_SEQ
GLOBAL Partitioned
Activity
If sub retention periods will be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details For Sub Retention.
This table describes the Activity maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_ACTIVITY
(Parent)
RANGE (ILM_DT,
D1_ACTIVITY_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT, D1_ACTIVITY_ID) if not using sub-retention.
D1_ACTIVITY.
CRE_DTTM
D1T319P0
D1_ACTIVITY_ID
Global
Partitioned
RANGE
(D1_ACTIVITY_ID)
D1T319S0
BUS_OBJ_CD,
BO_STATUS_CD,
D1_ACTIVITY_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_ACTIVITY_ID)
CM_ILM_D1T319S1
ILM_DT,
ILM_ARCH_SW,
D1_ACTIVITY_ID
Local Partitioned
D1_ACTIVITY_
CHAR
REFERENCE (D1_ACTIVITY_
CHAR_FK)
D1T320P0
D1_ACTIVITY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T320S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_ACTIVITY_
IDENTIFIER
REFERENCE (D1_ACTIVITY_IDENTIFIER_FK)
D1T330P0
D1_ACTIVITY_ID,
ACTIVITY_ID_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T330S0
ACTIVITY_ID_TYPE_
FLG, ID_VALUE
Global
Partitioned
HASH(ACTIVITY_ID_TYPE_FLG, ID_VALUE)
D1T330S1
ACTIVITY_ID_TYPE_FLG, UPPER(ID_VALUE)
D1_ACTIVITY_
LOG
LOG_FK)
D1T321P0
D1_ACTIVITY_ID,
SEQNO
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T321S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_TYPE_CD, CHAR_VAL_FK1)
D1T321S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_TYPE_CD, CHAR_VAL)
D1_ACTIVITY_
LOG_PARM
LOG_PARM_FK)
D1T322P0
D1_ACTIVITY_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1_ACTIVITY_
REL
REL_FK)
D1T323P0
D1_ACTIVITY_ID,
ACTIVITY_REL_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T323S0
REL_ACTIVITY_ID
Global
Partitioned
HASH(REL_
ACTIVITY_ID)
D1_ACTIVITY_
REL_OBJ
REL_OBJ_FK)
D1T324P0
D1_ACTIVITY_ID,
MAINT_OBJ_CD,
ACTIVITY_REL_OBJ_
TYPE_FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T324S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Communication In
This table describes the Communication In maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMM_IN
(Parent)
RANGE(ILM_DT, D1_COMM_ID)
D1_COMM_IN.
CRE_DTTM
D1T386P0
D1_COMM_ID
Global
Partitioned
RANGE (D1_COMM_ID)
D1T386S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID
Global
Partitioned
HASH(BUS_OBJ_CD,
BO_STATUS_CD, D1_COMM_ID)
CM_ILM_D1T386S1
ILM_DT,
ILM_ARCH_SW,
D1_COMM_ID
Local Partitioned
D1_COMM_IN_
CHAR
REFERENCE (D1_COMM_IN_
CHAR_FK)
D1T387P0
D1_COMM_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE (D1_COMM_ID)
D1T387S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMM_IN_
IDENTIFIER
IDENTIFIER_FK)
D1T391P0
D1_COMM_ID,
COMM_ID_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T391S0
COMM_ID_TYPE_FLG, ID_VALUE
Global
Partitioned
HASH(COMM_ID_TYPE_FLG, ID_VALUE)
D1T391S1
COMM_ID_TYPE_FLG, UPPER(ID_VALUE)
D1_COMM_IN_
LOG
LOG_FK)
D1T388P0
D1_COMM_ID,
SEQNO
Global
Partitioned
RANGE(D1_COMM_ID)
D1T388S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T388S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMM_IN_
LOG_PARM
LOG_PARM_FK)
D1T389P0
D1_COMM_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_COMM_ID)
D1_COMM_IN_
REL_OBJ
REL_OBJ_FK)
D1T390P0
D1_COMM_ID,
MAINT_OBJ_CD,
COMM_REL_OBJ_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T390S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Communication Out
This table describes the Communication Out maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMM_OUT
(Parent)
RANGE(ILM_DT,D1_COMM_ID)
D1_COMM_
OUT.
CRE_DTTM
D1T380P0
D1_COMM_ID
Global
Partitioned
RANGE (D1_COMM_ID)
D1T380S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID
Global
Partitioned
HASH(BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID)
CM_ILM_D1T380S1
ILM_DT,
ILM_ARCH_SW,
D1_COMM_ID
Local Partitioned
D1_COMM_OUT_CHAR
REFERENCE (D1_COMM_OUT_CHAR_FK)
D1T381P0
D1_COMM_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE (D1_COMM_ID)
D1T381S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMM_OUT_IDENTIFIER
REFERENCE (D1_COMM_OUT_IDENTIFIER_
FK)
D1T385P0
D1_COMM_ID,
COMM_ID_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T385S0
Global
Partitioned
D1T385S1
D1_COMM_
OUT_LOG
REFERENCE (D1_COMM_OUT_LOG_FK)
D1T382P0
D1_COMM_ID,
SEQNO
Global
Partitioned
RANGE(D1_COMM_ID)
D1T382S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T382S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMM_OUT_LOG_PARM
REFERENCE (D1_COMM_OUT_LOG_PARM_FK)
D1T383P0
D1_COMM_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_COMM_ID)
D1_COMM_OUT_REL_OBJ
REFERENCE (D1_COMM_OUT_REL_OBJ_FK)
D1T384P0
D1_COMM_ID,
MAINT_OBJ_CD,
Global
Partitioned
RANGE(D1_COMM_ID)
D1T384S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Device Event
This table describes the Device Event maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_DVC_EVT
(Parent)
RANGE(ILM_DT, DVC_EVT_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT,DVC_EVT_ID) if not using sub-retention.
D1_DVC_EVT.
CRE_DTTM
D1T400P0
DVC_EVT_ID
Global
Partitioned
RANGE (DVC_EVT_ID)
D1T400S1
BUS_OBJ_CD,
BO_STATUS_CD,
DVC_EVT_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID)
D1T400S2
D1_DEVICE_ID,
DVC_EVT_DTTM
Global
Partitioned
HASH(D1_DEVICE_ID, DVC_EVT_DTTM)
D1T400S3
BUS_OBJ_CD,
BO_STATUS_CD,
D1_DEVICE_ID,
DVC_EVT_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID)
CM_ILM_D1T400S4
ILM_DT,
ILM_ARCH_SW,
DVC_EVT_ID
Local Partitioned
D1_DVC_EVT_
CHAR
REFERENCE (D1_DVC_EVT_
CHAR_FK)
D1T401P0
DVC_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T401S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_DVC_EVT_
IDENTIFIER
IDENTIFIER_FK)
D1T405P0
DVC_EVT_ID,
DVC_EVT_ID_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T405S0
DVC_EVT_ID_TYPE_FLG, ID_VALUE
Global
Partitioned
HASH(DVC_EVT_ID_TYPE_FLG, ID_VALUE)
D1T405S1
DVC_EVT_ID_TYPE_FLG, UPPER(ID_VALUE)
D1_DVC_EVT_
LOG
LOG_FK)
D1T402P0
DVC_EVT_ID,
SEQNO
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T402S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T402S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_DVC_EVT_
LOG_PARM
LOG_PARM_FK)
D1T403P0
DVC_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(DVC_EVT_ID)
D1_DVC_EVT_
REL_OBJ
REL_OBJ_FK)
D1T404P0
DVC_EVT_ID,
MAINT_OBJ_CD,
DVC_EVT_REL_OBJ_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T404S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Completion Event
This table describes the Completion Event maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMPL_EVT
(Parent)
RANGE(ILM_DT,COMPL_EVT_ID)
D1_COMPL_
EVT.
CRE_DTTM
D1T340P0
COMPL_EVT_ID
Global
Partitioned
RANGE (COMPL_EVT_ID)
D1T340S0
D1_ACTIVITY_ID
Global
Partitioned
HASH(D1_
ACTIVITY_ID)
CM_ILM_D1T340S1
ILM_DT,
ILM_ARCH_SW,
DVC_EVT_ID
Local Partitioned
D1_COMPL_EVT_CHAR
REFERENCE (D1_COMPL_
EVT_CHAR_FK)
D1T341P0
COMPL_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T341S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMPL_EVT_LOG
REFERENCE (D1_COMPL_EVT_LOG_FK)
D1T342P0
COMPL_EVT_ID,
SEQNO
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T342S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T342S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMPL_EVT_LOG_PARM
REFERENCE (D1_COMPL_EVT_LOG_PARM_FK)
D1T343P0
COMPL_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1_COMPL_EVT_REL_OBJ
REFERENCE (D1_COMPL_EVT_REL_OBJ_FK)
D1T344P0
COMPL_EVT_ID,
MAINT_OBJ_CD,
COMPL_EVT_REL_OBJ_TYP_FLG
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T344S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Initial Measurement Data
This table describes the Initial Measurement Data maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_DATA
(Parent)
RANGE (ILM_DT,MEASR_COMP_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT,MEASR_COMP_ID) if not using sub-retention.
D1_INIT_MSRMT_DATA.
CRE_DTTM
D1T304P0
INIT_MSRMT_DATA_ID
Global
Partitioned
RANGE (INIT_MSRMT_DATA_ID)
D1T304S1
MEASR_COMP_ID, D1_TO_DTTM
Global Partitioned
RANGE (MEASR_COMP_
ID)
CM_ILM_D1T304S4
ILM_DT,
ILM_ARCH_SW,
INIT_MSRMT_DATA_ID
Local Partitioned
D1_INIT_MSRMT_DATA_CHAR
REFERENCE (D1_INIT_MSRMT_DATA_CHAR_FK)
D1T305P0
INIT_MSRMT_DATA_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(INIT_MSRMT_DATA_ID)
D1T305S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_INIT_MSRMT_DATA_LOG
REFERENCE (D1_INIT_MSRMT_DATA_LOG_FK)
D1T306P0
INIT_MSRMT_DATA_ID,
SEQNO
Global
Partitioned
PARM
REFERENCE (D1_INIT_MSRMT_DATA_LOG_PARM_FK)
D1T307P0
INIT_MSRMT_DATA_ID,
SEQNO
PARM_SEQ
Global
Partitioned
Usage Transaction
This table describes the Usage Transaction maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_USAGE
(Parent)
RANGE(ILM_DT, D1_USAGE_ID)
D1_USAGE.
CRE_DTTM
D1T281P0
D1_USAGE_ID
Global
Partitioned
RANGE (D1_USAGE_ID)
D1T281S0
US_ID,
START_DTTM
Global
Partitioned
RANGE (US_ID)
D1T281S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_USAGE_ID
Global
Partitioned
HASH(BUS_OBJ_
CD, BO_STATUS_CD, D1_USAGE_ID)
CM_ILM_D1T281S2
ILM_DT,
ILM_ARCH_SW,
D1_USAGE_ID
Local Partitioned
D1T419S1
USG_EXT_ID,
D1_USAGE_ID
Global
Partitioned
RANGE (USG_EXT_ID)
D1_USAGE_
CHAR
REFERENCE (D1_USAGE_
CHAR_FK)
D1T285P0
D1_USAGE_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1T285S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_USAGE_LOG
REFERENCE (D1_USAGE_LOG_FK)
D1T286P0
D1_USAGE_ID,
SEQNO
Global
Partitioned
RANGE(D1_USAGE_ID)
D1T286S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T286S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_USAGE_LOG_PARM
REFERENCE(D1_USAGE_LOG_
PARM_FK)
D1T287P0
D1_USAGE_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE (D1_USAGE_ID)
D1_USAGE_
PERIOD
REFERENCE(D1_USAGE_PERIOD_FK)
D1T283P0
D1_USAGE_ID,
PERIOD_SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_
PERIOD_ITEM_DET
REFERENCE(D1_USAGE_PERIOD_ITEM_DET_FK)
D1T431P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
ITEM_SEQ_NUM
Global
Partitioned
RANGE(D1_USAGE_ID)
D1_USAGE_
PERIOD_SQ
REFERENCE(D1_USAGE_PERIOD_SQ_FK)
D1T284P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
SQ_SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_PERIOD_SQ_DATA
REFERENCE(D1_USAGE_PERIOD_SQ_DATA_FK)
D1T497P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
SQ_SEQ_NUM,
SQ_DATA_DTTM
Global Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_REL
REFERENCE (D1_USAGE_REL_FK)
D1T316P0
D1_USAGE_ID,
USAGE_REL_TYPE_FLG
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1T316S0
REL_USAGE_ID,
USAGE_REL_TYPE_FLG,
D1_USAGE_ID
Global
Partitioned
HASH(REL_USAGE_ID,
USAGE_REL_TYPE_FLG,
D1_USAGE_ID)
D1_USAGE_
SCALAR_DTL
REFERENCE(D1_USAGE_SCALAR_DTL_FK)
D1T282P0
D1_USAGE_ID,
D1_SP_ID,
SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
Usage Transaction Exception
This table describes the Usage Transaction Exception maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_USAGE_
EXCP
(Parent)
RANGE (ILM_DT,
USAGE_EXCP_
ID)
D1_USAGE_
EXCP.
CRE_DTTM
D1T443P0
USAGE_EXCP_ID
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
CM_ILM_D1T443S1
ILM_DT,
ILM_ARCH_SW,
USAGE_EXCP_ID
Local Partitioned
D1_USAGE_
EXCP_CHAR
EXCP_CHAR_
FK)
D1T446P0
USAGE_EXCP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
D1T446S1
SRCH_CHAR_VAL
Global Partitioned
HASH
(SRCH_CHAR_
VAL)
D1_USAGE_
EXCP_PARM
EXCP_PARM_
FK)
D1T445P0
USAGE_EXCP_ID,
PARM_SEQ
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
VEE Exception
This table describes the VEE Exception maintenance object.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_VEE_EXCP
(Parent)
RANGE(ILM_DT, VEE_EXCP_ID)
D1_VEE_EXCP.
CRE_DTTM
D1T308P0
VEE_EXCP_ID
Global
Partitioned
RANGE (VEE_EXCP_ID)
D1T308S1
INIT_MSRMT_DATA_ID
Global
Partitioned
HASH(INIT_
MSRMT_DATA_ID)
CM_ILM_D1T308S2
ILM_DT,
ILM_ARCH_SW,
VEE_EXCP_ID
Local Partitioned
D1_VEE_EXCP_CHAR
REFERENCE (D1_VEE_EXCP_
CHAR_FK)
D1T310P0
VEE_EXCP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(VEE_
EXCP_ID)
D1T310S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_VEE_EXCP_PARM
PARM_FK)
D1T309P0
VEE_EXCP_ID,
PARM_SEQ
Global
Partitioned
RANGE(VEE_
EXCP_ID))
This section outlines each maintenance object that has been configured to support ILM as well as sub retention periods. This differs from the standard ILM enabled tables in that the partitioning strategy is inclusive of an additional column that defines the retention period for each record. In each case, the recommendation of the initial load of the ILM_DT and the <field name for retention period> for existing records is noted. The CTAS operation for these tables includes an extra step of generating a temporary mapping table that will allow the select for the ILM_DT to also identify the appropriate <retention period field name> for each record.
This section details the following maintenance objects that support ILM as well as sub retention periods:
Activity
If sub retention periods will not be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_ACTIVITY
(Parent)
RANGE (ILM_DT, RETENTION_
PERIOD)
D1_ACTIVITY.
CRE_DTTM
D1T319P0
D1_ACTIVITY_ID
Global
Partitioned
RANGE
(D1_ACTIVITY_ID)
D1T319S0
BUS_OBJ_CD,
BO_STATUS_CD,
D1_ACTIVITY_ID
Global
Partitioned
CM_ILM_D1T319S1
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
D1_ACTIVITY_ID
Local Partitioned
D1_ACTIVITY_
CHAR
CHAR_FK)
D1T320P0
D1_ACTIVITY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T320S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_ACTIVITY_
IDENTIFIER
D1T330P0
D1_ACTIVITY_ID,
ACTIVITY_ID_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T330S0
ACTIVITY_ID_TYPE_
FLG, ID_VALUE
Global
Partitioned
D1T330S1
D1_ACTIVITY_
LOG
LOG_FK)
D1T321P0
D1_ACTIVITY_ID,
SEQNO
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T321S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
D1T321S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
D1_ACTIVITY_
LOG_PARM
LOG_PARM_FK)
D1T322P0
D1_ACTIVITY_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1_ACTIVITY_
REL
REL_FK)
D1T323P0
D1_ACTIVITY_ID,
ACTIVITY_REL_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T323S0
REL_ACTIVITY_ID
Global
Partitioned
HASH(REL_
ACTIVITY_ID)
D1_ACTIVITY_
REL_OBJ
REL_OBJ_FK)
D1T324P0
D1_ACTIVITY_ID,
MAINT_OBJ_CD,
ACTIVITY_REL_OBJ_
TYPE_FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T324S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
PK_VALUE3,
PK_VALUE4)
Query for Setting the Retention Period
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Activity to identify the retention period for each record.
Please refer to Appendix G: Sample SQL for ILM in C2M with Sub Retention (Existing Installation)Appendix G: Sample SQL for Enabling ILM with Sub Retention in MDM (Existing Installation) for detailed information using Initial Measurement Data as an example.
Note: A pre-requisite to executing this query is configuring the appropriate retention periods in the ILM master configuration in the Oracle Utilities Meter Data Management application.
/*****ACTIVITY*****/
CREATE TABLE ILM_ACTIVITY_RETENTION_TMP
AS
select acty.activity_type_cd
/*retrieve the retention period for Activity Types in this order of precedence:
1. The category based retention period from the MDM master configuration
2. The MO level retention period from the MO options
3. The installation level retention period from the FW master configuration
, CAST(coalesce(catMap.retPeriod --Category level
, (select maint_obj_opt_val
from ci_md_mo_opt mmo
where maint_obj_cd = 'D1-ACTIVITY'
and maint_obj_opt_flg ='FLRP'
and seq_num =
(select max(seq_num)
and maint_obj_opt_flg ='FLRP')) --MO level
, extractvalue( xmlparse(content fw_mcfg.mst_config_data)
,'generalMasterConfiguration/defaultRetentionPeriod') --Install level
) as NUMBER(5)) retPeriod
from d1_activity_type acty
, (select extractvalue(value(p),
'activityTypeCategoryRetentionPeriodList/activityTypeCategory'
)ACTIVITY_TYPE_CAT_FLG
, extractvalue(value(p),
'activityTypeCategoryRetentionPeriodList/retentionPeriod'
)retPeriod
from f1_mst_config mdm_mcfg ,
table(xmlsequence(extract(xmlparse(content mdm_mcfg.mst_config_data),
'activityRetentionPeriod/activityTypeCategoryRetentionPeriods/activityTypeCategoryRetentionPeriodList'
))) p
where mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig')catMap
, f1_mst_config fw_mcfg
where fw_mcfg.bus_obj_cd = 'F1-ILMMSConfig'
and acty.ACTIVITY_TYPE_CAT_FLG = catMap.ACTIVITY_TYPE_CAT_FLG (+)
order by 1;
Device Event
Note: If sub retention periods will not be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details.
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_DVC_EVT
(Parent)
RANGE(ILM_DT, RETENTION_
PERIOD)
D1_DVC_EVT.
CRE_DTTM
D1T400P0
DVC_EVT_ID
Global
Partitioned
RANGE (DVC_EVT_ID)
D1T400S1
BUS_OBJ_CD,
BO_STATUS_CD,
DVC_EVT_ID
Global
Partitioned
D1T400S2
D1_DEVICE_ID,
DVC_EVT_DTTM
Global
Partitioned
D1T400S3
BUS_OBJ_CD,
BO_STATUS_CD,
D1_DEVICE_ID,
DVC_EVT_ID
Global
Partitioned
CM_ILM_D1T400S4
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
DVC_EVT_ID
Local Partitioned
D1_DVC_EVT_
CHAR
CHAR_FK)
D1T401P0
DVC_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T401S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_DVC_EVT_
IDENTIFIER
IDENTIFIER_FK)
D1T405P0
DVC_EVT_ID,
DVC_EVT_ID_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T405S0
Global
Partitioned
D1T405S1
D1_DVC_EVT_
LOG
LOG_FK)
D1T402P0
DVC_EVT_ID,
SEQNO
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T402S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T402S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_DVC_EVT_
LOG_PARM
LOG_PARM_FK)
D1T403P0
DVC_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(DVC_EVT_ID)
D1_DVC_EVT_
REL_OBJ
REL_OBJ_FK)
D1T404P0
DVC_EVT_ID,
MAINT_OBJ_CD,
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T404S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Device Event to identify the retention period for each record.
CREATE TABLE ILM_DVC_EVT_RETENTION_TMP
AS
select det.dvc_evt_type_cd
/*retrieve the retention period for Device Event Types in this order of precedence:
where maint_obj_cd = 'D1-DVCEVENT'
and seq_num = (select max(seq_num)
fw_mcfg.mst_config_data),
from d1_dvc_evt_type det
'deviceEventCategoryRetentionPeriodList/deviceEventCategory') dvc_evt_cat_flg
'deviceEventCategoryRetentionPeriodList/retentionPeriod') retPeriod
'deviceEventRetentionPeriod/deviceEventCategoryRetentionPeriods/deviceEventCategoryRetentionPeriodList'
))) p
and det.dvc_evt_cat_flg = catMap.dvc_evt_cat_flg (+)
order by 1;
Table
Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_DATA
(Parent)
PERIOD)
D1_INIT_MSRMT_DATA.
CRE_DTTM
D1T304P0
INIT_MSRMT_DATA_ID
Global
Partitioned
RANGE (INIT_MSRMT_
DATA_ID)
D1T304S1
MEASR_COMP_ID,
D1_TO_DTTM
Global
Partitioned
RANGE (MEASR_COMP_
ID)
CM_ILM_D1T304S4
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
INIT_MSRMT_DATA_ID
Local Partitioned
D1T305P0
INIT_MSRMT_DATA_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
D1T305S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1T306P0
INIT_MSRMT_DATA_ID,
SEQNO
Global
Partitioned
PARM
D1T307P0
INIT_MSRMT_DATA_ID,
SEQNO
PARM_SEQ
Global
Partitioned
Initial Measurement Snapshot
This table below describes the Initial Measurement Snapshot maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_SNAP (Parent)
Range(ILM_DT, INIT_MSRMT_
SNAP_ID)
D1T622P0
INIT_MSRMT_SNAP_ID
Global Partitioned
Range(INIT_
MSRMT_SNAP_ID)
D1_INIT_MSRMT_SNAP.CRE_
DTTM
CM_ILM_D1T622L0
ILM_DT,
ILM_ARCH_SW,
INIT_MSRMT_SNAP_ID
Local Partitioned
D1_INIT_MSRMT_SNAP_CHAR
D1T624P0
INIT_MSRMT_SNAP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
D1_INIT_MSRMT_SNAP _LOG
D1T625P0
INIT_MSRMT_SNAP_ID,
SEQNO
Global Partitioned
D1_INIT_MSRMT_SNAP _LOG_PARM
D1T626P0
INIT_MSRMT_SNAP_ID,
SEQNO,
PARM_SEQ
Global Partitioned
Measurement Data Snapshot Interval
This table below describes the Measurement Data Snapshot Interval maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_MDSI
(Parent)
Range(ILM_DT, D1_MDSI_ID)
D1T565P0
D1_MDSI_ID
Global Partitioned
Range(D1_MDSI_
ID)
D1_MDSI_
START_DTTM
CM_ILM_D1T565L0
ILM_DT,
ILM_ARCH_SW,
D1_MDSI_ID
Local Partitioned
Measurement Data Snapshot Scalar
This table below describes the Measurement Data Snapshot Scalar maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_MDSS
(Parent)
Range(ILM_DT, D1_MDSS_ID)
D1T594P0
D1_MDSS_ID
Global Partitioned
Range(D1_MDSS_ID
D1_MDSS_
START_DTTM
CM_ILM_D1T594L0
ILM_DT,
ILM_ARCH_SW,
D1_MDSS_ID
Local Partitioned
Snapshot Tables
This table below describes the snapshot tables.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_SP_SNAP_DL
RANGE(ILM_DT,
SP_SNAP_ID)
D1_SP_SNAP_DL.SNAPSHOT_DTTM
D1T434P0
SP_SNAP_ID
Global
Partitioned
RANGE(SP_SNAP_ID)
D1T434S0
D1_SP_ID,
SNAPSHOT_DTTM,
SNAPSHOT_TYPE_FLG
Global Partitioned
D1T434S1
CM_ILM_ILM_DT,
ILM_ARCH_SW,
SP_SNAP_ID
Local Partitioned
D1_SP_UNR_
USG_SNAP_DL
RANGE(ILM_DT,
SP_UNR_USG_
SNAP_ID)
D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_DTTM
D1T438P0
SP_UNR_USG_SNAP_ID
Global
Partitioned
RANGE(SP_UNR_USG_SNAP_ID)
D1T438S0
D1_SP_ID,
SNAPSHOT_DTTM,
UNR_USG_SNAPSHOT_
TYPE_FLG,
SNAPSHOT_TYPE_FLG
Global
Partitioned
CM_ILM_D1T438S1
ILM_DT,
ILM_ARCH_SW,
SP_UNR_USG_SNAP_ID
Local Partitioned
D1_SP_USG_
SNAP_DL
D1_SP_USG_
SNAP_DL
D1_SP_USG_SN
AP_DL.SNAPSH
OT_DTTM
D1T436P0
SP_USG_SNAP_ID
Global
Partitioned
RANGE(SP_USG_
SNAP_ID)
D1T436S0
D1_SP_ID,
SNAPSHOT_DTTM,
MEASR_COMP_ID,
USG_SNAPSHOT_TYPE_FLG,
D1_TOU_CD,
MSRMT_COND_FLG,
SNAPSHOT_TYPE_FLG
Global
CM_ILM_D1T436S1
ILM_DT,
ILM_ARCH_SW,
SP_USG_SNAP_ID
Local Partitioned
RANGE(ILM_DT,
SP_VEE_EXCP_
SNAP_ID)
D1_SP_VEE_
EXCP_SNAP_
DL.SNAPSHOT_
DTTM
D1T440P0
SP_VEE_EXCP_SNAP_ID
Global Partitioned
RANGE(SP_VEE_EXCP_SNAP_ID)
D1T440S0
D1_SP_ID,
SNAPSHOT_DTTM,
MEASR_COMP_ID,
EXCP_TYPE_CD,
D1_IMD_TYPE_FLG,
EXCP_SEVERITY_FLG,
VEE_GRP_CD,
VEE_RULE_CD,
SNAPSHOT_TYPE_FLG
CM_ILM_
D1T440S1
ILM_DT,
ILM_ARCH_SW,
SP_VEE_EXCP_SNAP_ID
Local Partitioned
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Initial Measurement Data to identify the retention period for each record.
Please refer to Appendix B: Sample SQL for Enabling ILM in MDM (Existing Installation)Appendix F: Sample SQL For Enabling ILM for MDM (Existing Installation) for detailed information using Initial Measurement Data as an example.
CREATE TABLE ILM_IMD_RETENTION_TMP
AS
select mct.measr_comp_type_cd
/*retrieve the retention period for MC Types in this order of precedence:
1. The UOM based retention period from the MDM master configuration
2. The interval IMD retention period from the MDM master configuration
3. The MO level retention period from the MO options
4. The installation level retention period from the FW master configuration
, CAST(coalesce( (select retPeriod
from (select 'D1IN' interval_scalar_flg
, extractvalue(value(p),'uomRetentionPeriodList/uom') D1_UOM_CD
, extractvalue(value(p),'uomRetentionPeriodList/retentionPeriod') retPeriod
, table(xmlsequence(extract(xmlparse(content
'imdRetentionPeriod/intervalImdRetentionPeriods/uomRetentionPeriods/uomRetentionPeriodList'))) p
union
select 'D1SC' INTERVAL_SCALAR_FLG
'imdRetentionPeriod/scalarImdRetentionPeriods/uomRetentionPeriods/uomRetentionPeriodList'))) p
where mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig') uomMap
where uomMap.interval_scalar_flg = mct.interval_scalar_flg
and trim(mctvi.d1_uom_cd) = trim(uomMap.d1_uom_cd))--UOM
, DECODE(mct.interval_scalar_flg
,'D1IN'
,extractvalue( xmlparse(content mdm_mcfg.mst_config_data),
'imdRetentionPeriod/intervalImdRetentionPeriods/intervalRetentionPeriod') --interval IMD
'imdRetentionPeriod/scalarImdRetentionPeriods/scalarRetentionPeriod') --scalar IMD
where maint_obj_cd = 'D1-IMD'
and maint_obj_opt_flg ='FLRP')) --IMD
, extractvalue( xmlparse(content fw_mcfg.mst_config_data),
from d1_measr_comp_type mct
, d1_mc_type_value_identifier mctvi
, f1_mst_config mdm_mcfg
where mct.measr_comp_type_cd = mctvi.measr_comp_type_cd
and mctvi.value_id_type_flg = 'D1MS'
and fw_mcfg.bus_obj_cd = 'F1-ILMMSConfig'
and mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig'
order by 1;
The following steps provide a high level overview of what needs to be done for on-going maintenance for ILM on enabled MOs.
Please refer to the Appendix H: Sample SQL for Periodic Maintenance for MDM DataAppendix H: Sample SQL for Periodic Maintenance for MDM Data for detailed information using To Do Entry(Without LOB), F1_SYNC_REC_IN(With LOB-Tablespace per Partition), Initial Measurement Data (With LOB-Tablespace per Subpartition), and the D1_MSRMT table (Partition Compression) as examples.
1. Add the partition.
a. Create Tablespace to be used for the new parent table partition.
b. Since, we define MAXVALUE Partition; new partition can only be created using “SPLIT” operation. Identify and use next HIGH_VALUE Partition for the split operation.
c. All the child table(s) partition(s)\LOB(s) must be altered to use the same tablespace as that of the parent table’s partition.
d. Enable advanced compression on all child table(s).
e. Copy partition level statistics from the previous partition.
2. Archive the partition/subpartition.
a. Make the tablespace that will be archived READ ONLY.
b. Check that no records have ILM_ARCH_SW = ‘N’.
• If record count is zero, then proceed for further steps.
• If record count is not zero, then change the tablespace back to READ WRITE MODE as Archive is not Feasible at the time.
c. Create an archive tablespace for the partition/subpartition that needs to be archived.
d. Create staging tables using the new archive tablespace. Load data for all child tables first.
e. Create staging table using the new archive tablespace and load data for the parent table.
f. Export tablespace using TRANSPORT_TABLESPACES method.
Make Sure Tablespace datafile required for further import is preserved.
g. Drop the partition, partition the tablespace and archive the tablespace (as it is already exported).
3. Restore the partition:
a. Create a new tablespace to restore the partition/subpartition.
b. Add partition using split operation on next greater high value partition.
If the table contains LOBS, there will an additional statement in split partition DDL indicating tablespace where the LOBs will be stored.
c. Enable advanced compression on all child table(s).
d. Import Tablespace using TRANSPORT_TABLESPACES method.
e. Load data into the parent table first from the staging table.
f. Load data into the child table from the staging table.
g. Drop the archive tablespace after import and data loading is successful.
4. Compress D1_MSRMT table Partition:
a. Create new compressed tablespace.
b. Create a table using CTAS for each subpartition of the partition being compressed in the new compressed tablespace.
c. Create a unique primary index for each subpartition of the partition being compressed in the new compressed tablespace. Then alter table to create the primary key.
d. Exchange the subpartition of the D1_MSRMT table with the newly created table for each subpartition.
e. Drop the original uncompressed tablespace.
f. Alter the partition level metadata to reflect the new compressed tablespace.
g. Rename the new compressed tablespace to the original tablespace name.
5. Move Data between different storage tiers:
The ILM facilities can be used within the database to implement storage savings, as follows:
• Use ILM Assistant to define the data groups to be used for the individual objects. Assign those data groups to partitions and storage devices to implement the storage savings. Remember to assign transportable tablespaces for the archive/dormant data stage to allow for safe removal of the data.
• Use ILM assistant to generate the necessary commands to implement the data changes manually or use Automatic Storage Management (ASM) to automate the data storage policies.
• Optionally, use Automatic Data Optimization to provide further optimizations.
For more information about ILM refer to the following:
