Bug Number | Description |
Oracle Utilities Customer Care and Billing | |
36908541 | Account SA History portal payment archived error encountered |
37152645 | Copy - C1-PECRL not syncing ineligible Pay IDs with the Non-eligible Pay Event creating partition gaps |
37156409 | Copy - To Do Alert creates on the wrong account when a customer is linked to multiple accounts |
37183647 | CXPERSONS REST API CREATING DUPLICATE RECORD FOR PRIMARY FLAG CHANGE |
37198952 | Copy - C1-COMMHIST IS CAUSING SIGNIFICANT PERFORMANCE ISSUE |
37200607 | Copy - IWS C1-Bill searchBill Operation is using multiple Date formats for field output field BillDate |
37203136 | Copy - Incorrect Order of Account Financial History Current Balance |
37209760 | Copy - 24A MP6.5.1 start/stop error requiring email person contact on paperless account * email exists |
37215216 | Copy - Program ¿CIPRQMAX¿ not handling the computation overflow error and gives system error. |
37224396 | Copy - Changing Premise's Time Zone causes (3, 65009) error when SAs linked to the Premise have their End Dates populated (Pending Stop, Stopped or Closed) |
37227448 | Copy - Payment Arrangement Request going into Error |
37233885 | Copy - PAYMENT PAGE 'SHOW MESSAGE' BUTTON FOR ERROR MESSAGE DOESN'T WORK |
37242242 | Copy - Case characteristic search for service point does not check for cis division restriction |
37252259 | Copy - ERROR WHEN GENERATING A BO SCHEMA OR UPDATING EXISTING BO BASED ON SP MO |
37255580 | Copy - Batch C1-TAPCT - ORA-01840-input value not long enough for date format coming from the Select SQL of Algorithm: C1-TPCT-SR. |
37255883 | Copy - When adding any type of characteristic to case, the page occasionally does not produce any text field |
37256924 | Copy - Decimal values in Blank days before bill due on self service task causing error at bill completion |
37268246 | Copy - BILL MO Information algorithm C1BILLMOINFO does not produce "fullyMatched" and other messages despite retrieving related information |
37281007 | Copy - C1-BILL IWS operation getBill is not returning some fields |
37285244 | Copy - Poor Performance of Usage and Billing & Financial History zones on Customer 360. |
37285779 | Copy - Characteristic Values Not Loading |
37287964 | Copy - Unable to complete bill after reopening if it is linked to a statement |
37293296 | Copy - Issue introduced by Bug 36362474; to be able to change the Main Customer on account, user has to manually update multiple customer contacts |
37297243 | Copy - Patch 36891153 partially working wrapper class for algorithm spot 'DCSC' is still not exposed for use on custom script |
37314249 | Copy - Maintenance Object ineligible for data export using GDE |
37337973 | Copy - JOB ANLYZSAR PERFORMANCE ISSUES |
37344077 | Copy - Customer Contact Search by Account orders results by Person ID; in some cases showing on top old Customer Contacts |
37349276 | Copy - LEVEL PAY ENROLLMENT / NBB MONTHLY PAYMENT DISCREPANCY |
37349608 | Copy - Patch 37033926 does not cover scenario with an ineligible Payment Event linked to more than 100 Pay IDs |
37364452 | Copy - SQLs appearing millions of executions in the PerfHub - should these be cached? |
37370373 | Copy - Account Balance not aligned for Accounts with large number of FT |
37378671 | Copy - SA Financial History All Dates Zone has incorrect calculation of current and payoff balance |
37382166 | Copy - Customer still Unable to Start/Stop due to Email Person Contact Message after Patch 37144556 |
37389202 | Copy - C1-BLCMP does not trigger the SA Type Pre-Bill Completion algorithm |
37390072 | Copy - EXPIRE SA UPDATING ALL 'SEVERANCE ACTIVITY' FIELD ACTIVITY TYPE TO 'STOP ACTIVITY |
37391412 | Copy - CASE PORTAL MAIN ZONE NOT DISPLAYING ANY DETAILS WHEN A WARNING MESSAGE IS THROWN. |
37397098 | Copy - Device Test (C1DVTEST) FK Reference not working - Unable to retrieve Portal Zone Metadata |
37412637 | Copy - CCS is not updating the correct bill cycle on the account on stopping the SA |
37425725 | Copy - After applying 24B MP5.3.1, rate engine skips eligibility criteria configured on calc rules, except for the last eligibility criterion configured |
37453272 | Copy - When the SA start option is changed, additional characteristics on SA is getting deleted |
37456335 | Copy - Field Activity Portal links are not navigating to the correct Page |
37458458 | Copy - CCB SERVICE POINT SYNC CREATING DUPLICATE SYNC/SP RECORDS IN MDM |
37463808 | Copy - Post Patch 37252668 - Continuing Issues with Financial History |
37480090 | Copy - Base algorithm C1-DSOV-SAID is not invoked when creating a prepay payment event |
37481748 | Copy - PERSON CONTACT - START STOP ISSUES AFTER 35594446 |
37481980 | Update script version for C1-ValUoToSq script to version 3.0 |
37490665 | Copy - IWS C1-CustomerContact operation "createCustomerContact" return incorrect error message |
37510501 | Copy - When payment is Distributed amount is distributed incorrectly even with deployment of patch 36472099 |
37526904 | Copy - System is not able to balance Auto Pay open Tender Control by C1-BLAPC batch |
37529206 | Copy - CCB Unified Search "Search by Contact Details" is slow and returns results in 30 seconds |
37529800 | Copy - SA Financial History All Dates has incorrect calculation of current and payoff balance post 37279917 fix |
37544850 | Copy - With multiple Bill Segment Headers, next Header's Simple Summary calc line value includes Simple Summary values from previously calculated Headers |
Oracle Utilities Meter Data Management | |
36410199 | TECH DEBT: UPDATE SCRIPT ENGINE TO V3 - SYNC SCRIPTS - PART 2 |
36679189 | Text box against Value was not properly aligned while adding new factor value for Manage Parameter |
36755849 | COPY OF Bug 36755846 - COPY OF Bug 36722465 - D1-SyncIMDScalar IMDs stay in ERROR state in spite of allowed retries limit has been exceeded |
36773235 | Copy - Master Configuration information is not reflecting on the EDIT page |
36775381 | Remove unused pom.xml files from SGG Composites |
36776460 | COPY OF Bug 36776455 - COPY OF Bug 36776453 - COPY OF Bug 36492761 - D2-IntervalSPHistory throwing error |
36779901 | Copy - Billing is throwing an error If any new SA is created |
36786305 | COPY OF Bug 36387471 - DESCENDING FORCE COMPLETE LEAD TO WRONG MEASUREMENTS CALCULATION |
36793467 | COPY OF Bug 36793464 - IMD ML DATA ON POSTVEE REMOVED AFTER WAITING FOR ML |
36796061 | COPY OF Bug 36796059 - COPY OF Bug 36771297 - ALL_SERVICES_READ USER GROUP is able to Add Usage Calc Rule |
36798711 | Copy of 36798708 - Cut For Non-Payment Activities Getting Stuck in "In Progress" Status |
36806959 | Copy - New device stuck in Connected/Pre Commissioned state after Electric meter exchange |
36819937 | COPY - MSCS Connects/Disconnects not syncing to CC&B |
36826973 | Copy of 36826964 - Copy of 36826955 - Copy of 36818147 - Ongoing consumption extract Run throws null pointer exception from RetrieveMeasurements_Impl program |
36852319 | TECH DEBT: UPDATE SCRIPT ENGINE TO V3 - SYNC SCRIPTS - PART 3 |
36855853 | COPY - Invalid Item Types Shown on Multi-Item Service Points |
36859030 | WPTG_TSN:TUGBU:536796:translatable words in DNT (Do Not Translate) format |
36862795 | COPY OF Bug 36810239 - NullPointerException when processing IMD for uninstalled device |
36863191 | Copy of 36863184 - Copy of 36863179 - Copy of 36863170 - Copy of 36863168 - Copy of 35182686 - PRODUCT USE METRIC - DEVICE AND CHANNEL COUNT DASHBOARD TAKES A LONG TIME REFRESH |
36863343 | Copy of 36760382 - Remote Commands are not being triggered when a device is in the status of Disconnected/Commissioned (off) during transfer service (Back-to-Back) |
36863398 | COPY OF Bug 36727935 - LIVE INSTANCE TESTING: "KEY" |
36864294 | Copy of 36822762 - after invoking the new BS D1-FNDSCHLDS, its still using the old BS D1-FNDCHLDCO Xpath |
36868696 | Copy of 36868686 - Copy of 36863050 - Copy of 36823181 - The Specialized Measurement and IMD batches D1-SIMDI and D1-SMDIE are ended in Error |
36869980 | Copy of 36635184 - Customer Info in Outbound is updated with Old customer details for Enable and Back to Back Activity |
36879788 | Copy of 36879786 - Copy of 36879778 - Copy of 36875298 - To Do Type specified in the Algorithm D1-CTDECEBOE parameters does not exist in the system |
36882168 | COPY - Overlapping Multi-Item Configuration Periods Error on Service Point Edit |
36893491 | ML: Batch Job D1-IMDML did not update IMD in Waiting for ML status |
36908518 | Copy of 36908509 - Copy of 36908493 - Copy of 36851635 - C1-Account migration Plan includes D1-TOUMAP which is not processed by F1-MGOPB and F1-MGOAB |
36924554 | Copy - Device Configuration is getting updated to Current Date time when the Asset is moved to InStore |
36934874 | COPY - Remove algorithm D1-CHKCMDELG from D1-CancelCommand BO |
36942923 | Copy of 36942920 - Copy of 36942915 - Copy of 36942910 - Copy of 36942902 - Copy of 36555911 - Fix (36459643) works for CENTRAL opco during daylight savings time, but not for EASTERN opco. |
36953732 | Copy of 36953729 - Copy of 36858516 - Enable Accumulate All Instances for MDM batch jobs |
36974045 | Copy of 36974025 - Copy of 36974004 - Copy of 36958371 - D1-COMM monitor batch is unable to execute due to missing base MO config |
36974171 | UGBUPD-17019 IMD Type Table and MO |
36974179 | UGBUPD-17020: NextGen MDM (InMem): Staging/Control table |
36974182 | UGBUPD-17021: NextGen MDM (InMem): Measurement Audit Table/MO |
36978449 | COPY - Missing fkRef constraint for Processing Timetable Type in D1_US_TYPE table |
36993696 | Copy - Measurement not extracted when created with dttm as on 30th day prior to last extracted dttm |
36996169 | Copy - Measuring component is not loading properly if tried to opened from Device Char with chartype- D1-MC |
37001161 | Copy - Bundle Import is failing for Usage Rule Bundle |
37007342 | Copy - MDM - Premise Information Device Configuration link is not working |
37007631 | Copy - Command Activities should transition to the next state when polling completes |
37015907 | Device Chars zone Maint Page generates NPE ERROR - Unable to retrieve Zone Metadata |
37018216 | OUMDM-38639 - UGBUPD-17019 IMD Type BOs |
37028842 | UGBUPD-17019 IMD Type BOs - Additional Changes |
37044364 | UGBUPD-16345 - Plug in spots (pre-processing/All other) |
37045256 | Copy - Algorithm "D1-TDPRCRE" is not adding SP characteristic 'D1-SP' to To Dos |
37049345 | Copy - Add new batch id override class option for D1-IMDV2 to address the device configuration ID issue |
37049366 | Extend Data Area of C2M Extendable Lookup: D2-CCBRateScheduleLookup |
37049858 | OUMDM-38641 - Tighten D1-UpdateSP logic for disconnect location |
37056497 | Copy - System not displaying the current date for Disconnect - MDM Change |
37072395 | Copy - Usage Calc SP/Device filter not working as expected. |
37080304 | Copy - Device Query zone displays both English and Japanese Device Types after Japanese is enabled |
37085482 | Copy - Performance issue with D1-IMDSD batch selection query |
37089444 | Copy - Load IMD BOs contain Invalid Values in the State Condition of the different lifecycle stages |
37089951 | Copy - Scalar IMD Transition from VEEEXCP to VERIFYDATES uses new transition condition |
37094123 | UGBUPD-16345 - Processing Method - D1-HowToCreateMCInformation |
37113149 | Copy of Bug 36931665 - Limited Character Entry when Completing FA (via Inbound Communication) |
37118954 | Select Type popup window displays with Device Type drop-down menu misplaced |
37143296 | UGBUPD-16345 - Hide In Memory IMD Changes |
37483877 | SAAS LICENSE SUBSCRIPTION - UTILITIES CCB CLOUD JAVA DEVELOPMENT 24C MP2.3.0 |
37483882 | SAAS LICENSE SUBSCRIPTION - UTILITIES C2M CLOUD JAVA DEVELOPMENT 24C MP2.3.0 |
37563000 | SAAS LICENSE SUBSCRIPTION - UTILITIES CCB CLOUD JAVA DEVELOPMENT 24C MP3.1.0 |
37563026 | SAAS LICENSE SUBSCRIPTION - UTILITIES C2M CLOUD JAVA DEVELOPMENT 24C MP3.1.0 |
Oracle Utilities Operational Device Management | |
36045259 | SHIFT SCHEDULE DETAILS SCREEN INCORRECTLY DERIVES AVAILABLE HOURS FOR EMPLOYEE FROM CREW TYPE WHEN LABOR PROFILE IS POPULATED |
36632198 | Should not be able to revise the Unit of Measure on an ARR where the Stock Item Detail Class is Inventory |
36849739 | Unable to delete CU with material resources on construction location of CWA. |
37111722 | Entering Project Number in Purchase Requisition generates "not found" error |
37145840 | Copy - Construction Location Details performance issue |
37156913 | Copy - Performance issue creating Construction WO from Work Design |
37159837 | C2MO - Invalid FK References to table F1_SCHEMA for script W1RctBchStat |
37215714 | ERP Subproject/Task Number Incorrectly Mapped to ERP Project Number Column |
37215793 | Send Asset Information Update Button Remains Enabled After Information is Sent to ERP Without Further Changes |
37222723 | Copy - Enabling Pagination in Query Data Explorer - Multi Query Zone is getting Javascript error |
37237324 | Copy - Clicking Add Service history button on the Maintenance tab on the Asset retrieves the wrong asset id |
37254348 | Blanket Contract Used Amount calculations does not include Credit for Price Adjustment |
37254698 | Update PO Line to display Unit Price's full precision and right align Unit Price on BC, PO and PR lines |
37289695 | Copy - Provide updated endpoint content for Storeroom and StockItemDetail endpoints |
37338344 | Copy - Closing CWA generates a system error |
37341141 | Copy - PERFORMANCE ISSUE: TIMEOUT WHEN SAVING WORK ACTIVITY DETAILS WHILE CREATING WORK ORDERS FROM WORK DESIGN |
37345225 | W1-StockItemSync - List has 3 references with the same keys (Manufacturer Code) |
37361127 | Not able to Replicate or Duplicate an Asset if the Fixed Asset Number is populated |
37376494 | Repetitive error is displayed while removing asset in a CWM Activity |
37601196 | Item Detail List not updating under existing ARR in CWA/WD |
Oracle Utilities Customer to Meter | |
36346847 | ADD BUTTON IS MISSING ON PROGRAM INITIATIVE QUERY PAGE |
36872444 | DER REGISTRATION PROGRAM THROWING ERROR WHEN A SPECIFICATION(MIXED CASE) IS ATTACHED |
37172634 | Copy - Performance issues related to Device tab |
37207803 | Copy - Cross Installed Meter Process marking reads as Do Not Use or doesn't find them due to Daylight Saving |
37215596 | Copy - Bundle Enrollment WO/Activities Creation Issue |
37222475 | Copy - Batch created bill segments stay in Freezable status after Usage has been sent back |
37225113 | Program Settlement Query Zone (UGBUPD-16517) - Invalid Dropdown Status (BACK button) |
37238838 | Newly created device location is not being reused for related program when main and related have the same device location type |
37260060 | Copy - UGBUPD-16517 DACS FR Items- Part 1 (C2M changes) |
37260169 | Bug 37260169 - Bugs found during QA for UGBUPD-16982 - C2M Changes |
37266814 | Copy bug for 37189898 Issues with Customer Insight Portal + Bundle Enrollment |
37284568 | Copy - Bug 37235759 - Bugs found during QA for UGBUPD-144991 |
37292925 | COPY - X1-MIGSP Is not able to synch the Correct SP Source Status Flag |
37322419 | Error appears when cross installed two meters related to script X1CMGetIns & X1CRSMTRINS |
37327946 | Copy - UT Performance Improvements (C2MO changes) |
37365893 | Copy - Reserve device operation should update Reservation Start and End on Event Participation instead of Participation Start and End |
37366165 | Bundle Export is failing for Program rule IFT - ERROR - Business Object field missing |
37389466 | DACS: unable to add Event Participation from ADD button - Primary Key 1 is missing error pops up |
37414852 | Copy - Attempts to create IFT generates an error when the variable of type Value is used + Business Flag fails |
37429018 | Copy - SA Type - Billing Initial Start Date Option Not Applied for Scalar Processing |
37449918 | Bugs found during DEMO for UGBUPD-16079 |
37459270 | In c2m, the bill cycle menu item for Usage must be suppressed |
37475042 | Copy - C1-MDM2SPSyncRequest Plugged-in in Service Point MO |
37479523 | "F1 Value is missing" error is thrown on DER Aggregator Deletion |
37482878 | Update script version for X1-TRNRELPPB script to version 3.0 |
37507413 | Copy - Global Context/Current Context shows Smallest Account Number for Person with Multiple Accounts |
37520991 | Limit contact in the DER aggregator to the Point of Contact Only |
37575923 | Program Rules of same category cannot overlap on a program |
37576472 | Bugs found during DEMO for UGBUPD-14989 |
37582095 | When a Program Rule is changed, an outbound message still goes out for deactivated Program |
