Upgrade Procedure
The upgrade installation procedure consists of:
Upgrading the Database Component
Upgrading the Oracle Utilities Customer to Meter database component must be complete before you can upgrade the application component.
Refer to the Upgrade Install section in the Oracle Utilities Customer to Meter Database Administrator’s Guide for instructions to upgrade the database component.
Upgrading the Application Component
A successful upgrade consists of the following steps:
Upgrading Oracle Utilities Customer Care and Billing to Oracle Utilities Customer to Meter V25.4
This section assumes that only Oracle Utilities Customer Care and Billing exists on top of Oracle Utilities Application Framework. Make sure to perform the following for upgrade.
Upgrading Oracle Utilities Application Framework
To upgrade, use the following command:
Unix:
ksh ./install.sh -u
Windows:
install.cmd -u
Installing Oracle Utilities Application Framework V25.4 Prerequisite Single Fixes
Upgrading Oracle Utilities Customer Care and Billing V25.4
Installing Oracle Utilities Customer Care and Billing V25.4 Post-release Patches
Installing Oracle Utilities Meter Data Management V25.4
Installing Oracle Utilities Meter Data Management V25.4 Post-release Patches
Installing Oracle Utilities Operational Device Management V25.4
Installing Oracle Utilities Operational Device Management V25.4 Post-release Patches
Installing Oracle Utilities Customer to Meter V25.4
Installing Oracle Utilities Customer to Meter V25.4 Post-release Patches
Upgrading Oracle Utilities Meter Data Management to Oracle Utilities Customer to Meter V25.4
This section assumes that only Oracle Utilities Meter Data Management exists on top of Oracle Utilities Application Framework.
Perform the following to upgrade Oracle Utilities Meter Data Management to Oracle Utilities Customer to Meter.
To upgrade, follow the command:
Unix:
ksh ./install.sh -u
Windows:
install.cmd -u
Note: The upgrade install does not clean files of libraries that were removed from the latest version.
Upgrading Oracle Utilities Meter Data Management V25.4
Upgrading Oracle Utilities Operational Device Management to Oracle Utilities Customer to Meter V25.4
This section assumes that only Oracle Utilities Operational Device Management exists on top of Oracle Utilities Application Framework.
Perform the following to upgrade Oracle Utilities Operational Device Management to Oracle Utilities Customer to Meter.
Unix:
ksh ./install.sh -u
Windows:
install.cmd -u
Installing the Oracle Utilities Meter Data Management V25.4
Upgrading Oracle Utilities Operational Device Management V25.4
Upgrading Oracle Utilities Customer to Meter to Oracle Utilities Customer to Meter V25.4
This section assumes that only Oracle Utilities Customer to Meter exists on top of Oracle Utilities Application Framework.
Perform the following to upgrade Oracle Utilities Customer to Meter to Oracle Utilities Customer to Meter.
Unix:
ksh ./install.sh -u
Windows:
install.cmd -u
Upgrading Oracle Utilities Customer to Meter V25.4
Creating WebLogic Domain
With Oracle Utilities Application Framework V25.4 a WebLogic native installation is required. Refer to the Oracle WebLogic Configuration Guide for Oracle Utilities Application Framework (Doc ID 2413918.1) document on My Oracle Support for more information.
