Defining Converted COBOL Program Options
The topics in this section describe the transaction that allows you to define the metadata for converted COBOL programs within the current environment's database.
CAUTION:
Updating converted COBOL Programs requires technical knowledge of the system. This is an implementation and delivery issue and should not be attempted if you do not have previous experience.
