Quotes
A quote allows you to show a customer how their bill segments will look if a given set of pricing terms is applied to a given amount of consumption. If the customer accepts a quote, one or more real service agreements are created.
Fastpath:
Refer to Defining Quotation Options for how to setup the system to enable quotation functionality.
Separate module. Please note that the quoting functionality is part of the Contract Management module. If this module is not applicable to your business you may turn it off. Refer to Turn Off A Function Module for more information.
The topics in this section describe the quotation functionality.
