Configuring Bill Cycles
This portal is used to display and maintain a Bill Cycle.
You can access the portal from other objects such as Measurement Cycles.
  • Bill Cycle List: displays all of the Bill Cycles so you can choose the one you want to display in more detail.
  • Bill Cycle: shows the specific configuration for the selected Bill Cycle.
  • Bill Cycle List: lists the bill cycle schedules of the current bill cycle.
Meter Data Management bill cycles are created from Customer Care and Billing bill cycles via Customer To Meter Master Data Synchronization. Bill cycles should only be updated via the Customer Care and Billing Bill Cycle portal.
