Configuring Head End Systems
This portal is used to display and maintain Head End Systems.
Refer to Understanding Head-End Systems for more information.
You can access the portal by selecting Admin, then Device, then Head End System.
- Head End System List: This zone lists all Head End System records. Broadcast a record to display the details of the selected record.
 - Head End System: This zone provides information about the selected Head End System.
 - Processing Method List: This zone provides the list of processing methods defined for the Head End System.
 - Translation Methods List: This zone provides the list of translation methods defined for the Head End System.
 - Inbound BOs Send By Service Provider: This zone lists inbound Business Objects that are sent by this Head End System. The identification is driven by the Business Object having a Business Object Option of type "Sent By Service Provider" that references the current Head End System.
