Setting Up Plug-In Scripts
The following points describe how to implement a plug-in script:
- Compose your plug-in script, associating it with the appropriate algorithm entity (plug-in spot).
 - Create a new algorithm type for the respective algorithm entity, referencing your plug-in script as the program to carry out the algorithm type's function. Only plug-in scripts associated with the algorithm entity may be referenced on the algorithm type.
 - Set up an algorithm for the respective algorithm type and plug it in where applicable. Refer to Setting Up Algorithm Types for more information.
