Master Configuration - Migration Assistant
The Migration Assistant Configuration master configuration record defines system wide configuration used in both the source environment and the target environment.
As described in Importing Data that References a User, if you have records being imported that may reference a user does not exist (and shouldn't exist) in the target environment, define a Default User here.
In both the source environment and the target environment, the system needs to know the location of the export directory and the import directory along with the expected file suffix. For these fields, implementations may also rely on the system defaults. If no Migration Assistant Configuration record is found, the system assumes that there is an entry defined in the system's substitution variable list for F1_​CMA_​FILES. Further it defaults the values as follows:
  • Export directory is the value for this variable plus "\export".
  • Import directory is the value of this variable plus "\import".
  • File suffix is set to cma
Refer to Referencing URIs for more information about the substitution variable list.
For additional information about specific fields in the master configuration, refer to the embedded help.
This record can be updated at any time to change details. The new configuration takes effect on all subsequent exports and imports.
