Migration Transaction Portal
This page appears after drilling into a specific migration transaction from the migration data set portal or from the migration object portal.
Refer to Importing and Applying a Migration for an overview of the import process.
The following zones are visible on the main tab:
Migration Transaction. This zone contains display-only information about the selected record. Please see the zone’s help text for information about this zone’s fields.
Migration Transaction Objects. This zone lists the objects that are related to the data set. To see more information about a specific migration object, click the hypertext for its ID. This brings you to the Migration Object portal. A user may choose to update the status of one or more records by checking the records and clicking Approve, Reject or Needs Review accordingly.
Entity Summary. This zone provides a summary count of all migration objects included in the current transaction across the various statuses.
