Understanding Data Export
The application supports the following classes of export methods
for a maintenance object:
Generalized. This method may be used for maintenance objects that are low to medium in volume and update activity. Most maintenance objects are eligible for this method.
Specialized. This method should be used for maintenance objects that are high in volume or very frequently updated.
It is your organization's responsibility for designing the process by
which these files are imported to one or more target environments.
This section discusses concepts and guidelines related to data export features.
