BO Algorithm Execution Summary
This table highlights the processing steps that occur when adding or changing a record that is governed by a business object.
Invoke BO | |
Event | Comments |
BO Pre-processing algorithms executed |
These algorithms are only executed when Invoke BO is used. The business object in the Invoke BO is the one whose rules are executed. |
MO Processing | |
Event | Comments |
Determine if status has changed. |
The system keeps a note of the new status value but initially proceeds with the old value. |
MO Processing. |
Standard MO processing, including MO validation is executed. |
Determine BO algorithm executed. |
The MO level algorithm is executed to determine the identifying BO. |
BO Validation algorithms executed. |
State transition rules are performed if the status has changed. |
BO Status Exit algorithms for the “old” status executed. |
Status updated to the new value. |
BO Status Enter algorithms for the “new” status executed. |
If no error — MO Transition algorithms are executed. Fastpath:
Refer to State Transitions are Audited for more information. |
If error and there are “save points” the MO Transition Error algorithms are executed. Fastpath:
Refer to Keeping An Entity In Its Last Successful State for more information. Otherwise, the error is reported. |
BO Status Monitor algorithms are executed. |
If the record transitions again, the prior step (State transition rule step) is repeated for the new transition. |
BO Post-processing algorithms are executed. |
BO Audit algorithms are executed. |
These algorithms are only executed if the system detects a change in elements that are not marked with “no audit”. |
