Customer and Premise Data Extracts: Business Objects and Algorithms
If the Generic Change Data Capture (F1-GCHG-CDCP) algorithm type (provided in the base package) is used, the synchronization requests are based on the Sync Request BO maintenance object options.
Alternatively, if the base package supplied Maintenance Object – Audit algorithm types, which are outlined in the Customer and Premise Data Extracts: Maintenance Object Audit Algorithms section are used, the synchronization requests are based on the Sync Request BO defined in the algorithm parameters.
Customer Data
Customer Data Extract for DataConnect (C1-ExternalRepoPlusCusDataSync): used to extract service agreement / account / person related information. This business object should be defined as a value for the Sync Request BO option on the Service Agreement maintenance object.
SA/SP Data Extract for DataConnect (C1-ExternalRepoPlusSASPSync): used to extract service agreement service point information. This business object should be defined as a value for the Sync Request BO option on the Service Agreement maintenance object.
Mailing Address Data for DataConnect (C1-ExternalRepoPlusMailAddSync): used to extract mailing address information. This business object should be defined as a value for the "Sync Request BO" options on the Person maintenance object.
SP/Meter Sync for DataConnect (D1-ExternalRepositorySPMtrSync): used to extract service point and meter information. This business object should be defined as a value for the "Sync Request BO" options on the Service Point, Device Configuration, and Device maintenance objects.
SA/Account/Person Sync for Legacy DataConnect (C1-ExternalRepoSASync): used to extract service agreement / account / person related information. This business object should be defined as a value for the Sync Request BO option on the Service Agreement maintenance object. (Used with v1)
SP Sync for Legacy DataConnect (D1-ExternalRepositorySPSync): used to extract service point information. This business object should be defined as a value for the "Sync Request BO" options on the Service Point maintenance object. (Used with v1)
Install Event Sync for Legacy DataConnect (D1-ExternalRepositoryIESync): used to extract install event information. This business object should be defined as a value for the "Sync Request BO" options on the Install Event maintenance object. (Used with v1)
Capture Customer Data's Initial Snapshot for DataConnect(C1-CEXTRCSAD)
Capture SA/SP Data's Initial Snapshot (C1CAPSASPI)
Capture Mailing Address Data Initial Snapshot (C1CAPMLADDI)
Capture SP/Meter Initial Snapshot for Legacy DataConnect (D1-SPMINISNP)
Capture SP Initial Snapshot for Legacy DataConnect (D1-SPEINISNP)
Capture SA-Based Initial Snapshot for Legacy DataConnect (C1-CEXTRCSAI)
Capture Install Event Initial Snapshot for Legacy DataConnect (D1-IEEINISNP)
These algorithms specify the batch control used for the extract process (see below).
The Sync Request Monitor batch control (F1-SYNRQ) monitors synchronization requests in the Pending state and executes Monitor algorithms that check for other pending related synchronization requests, and, if none, transitions them to the Determine if Sync Needed state.
Capture SA-Based Final Snapshot for DataConnect(C1-CEXTRPSAF)
Capture SA/SP Data's Final Snapshot (C1CAPSASPF)
Capture Mailing Address Data’s Final Snapshot (C1CAPMLADDF)
Capture SP and Meter Data's Final Snapshot for DataConnect (C1-CEXTRSPMF)
Capture SP/Meter Final Snapshot for DataConnect (D1-SPMFINSNP)
Capture SA-Based Final Snapshot for Legacy DataConnect (C1-CEXTRCSAF)
The Prepare Delimited Extract Data (Ignore Custom Sync Records) Enter algorithm (C1-PRPEXDNCU/C1-PRTBDEXDT) or the Prepare Delimited Extract Data Enter algorithm (D1-PRPEXTDTA) on the Send Request state prepares and formats the data for extraction, and creates a general process record for the synchronization request (based on the batch control defined by the pre-processing algorithm).
Premise Data
SP/Meter Sync for DataConnect (D1-ExternalRepositorySPMtrSync): used to extract service point and device related information. This business object should be defined as a value for the Sync Request BO option on the Service Point, Device Configuration, and Device maintenance objects.
