Billable Charge Service Quantity Upload Staging Layout
You must create a billable charge service quantity upload record for each service quantity to be uploaded. The name of this table is CI_​BCHG_​UP_​SQ. The following table describes each column on this table. Refer to "pass through" charges for more information about how this type of information is used.
Column Name
Length
Req'd
Data Type
Comments
BCHG_​UP_​ID
30
Y
Char
This is the foreign key to the billable charge upload staging record.
SEQ_​NUM
3
Y
N
Sequence of the service quantity within the Billable Charge Upload
UOM_​CD
30
N
Varchar
The unit of measure of the Billable Charge Upload SQ row. If specified, it must reference a valid value on CI_​UOM. Note, at least one of the following fields should be specified: SQI_​CD, TOU_​CD, UOM_​CD.
TOU_​CD
30
N
Char
The time of use of the Billable Charge Upload SQ row. If specified, it must reference a valid value on CI_​TOU. Note, at least one of the following fields should be specified: SQI_​CD, TOU_​CD, UOM_​CD.
SQI_​CD
30
N
Varchar
The service quantity identifier of the Billable Charge Upload SQ row. If specified, it must reference a valid value on CI_​SQI. Note, at least one of the following fields should be specified: SQI_​CD, TOU_​CD, UOM_​CD.
SVC_​QTY
12.6
N
N
Quantity of the service used for the UOM / TOU / SQI combination
