Billable Charge Upload - Read Details
Optionally, you may specify meter read details associated with a billable charge. These are most commonly used when you need to print the read details that were used to calculate the bill lines that appear on the main tab.
Using these reads to derive billable consumption. The base package bill segment creation algorithm (BSBS-BC) simply sweeps billable charge read details onto the related bill segment's read detail. This algorithm does NOT use these reads to derive billable consumption. This is intentional as most implementations that import reads also import billable consumption and therefore deriving billable consumption is unnecessary (and also error prone). If your implementation needs to derive billable consumption from these reads, you can develop your own bill segment creation algorithm to do just this.
Open Menu > Financial > Billable Charge Upload Staging > Search and navigate to the Read Details page to view this information.
Description of Page
Fastpath:
Refer to Billable Charge Read Details Upload Staging for more information about these fields.
