Configuring Exception Types
This portal is used to display and maintain an Exception Type.
Refer to Understanding Exception Types for more information.
You can access the portal by selecting Admin, then VEE, then Exception Type.
- Exception Type List: displays all of the Exception Types so you can choose the one you want to display in more detail
- Exception Type: shows the specific configuration for the selected Exception Type
There are two different options to use when creating an Exception Type:
Name |
Details |
Business Object |
VEE Exception |
This will create a "normal" VEE Exception that is attached to an IMD for tracking of conditions triggered in the VEE process. |
D1-VEEException |
VEE Exception - Monitor Service Point |
In addition to tracking the failure in the VEE process, this VEE Exception generates a Service Issue Monitor. This allows for cumulative tracking of VEE Exceptions that can be configured to result in a Service Investigative Order (field work) for the Service Point. |
D2-VEEExceptionServiceMonitor |
