Configuring Time of Use Map Types
This portal is used to display and maintain a TOU Map Types.
Refer to Understanding Time of Use Map Types for more information.
You can access the portal by selecting Admin, then Usage, then TOU Map Type.
- TOU Map Type List: This zone lists all TOU Type records. Broadcast a record to display the details of the selected record.
- TOU Map Type: This zone provides information about the selected TOU Map Type.
