Configuring the Service Order Management Dashboards
This section describes the process for configuring the Service Order Operational Dashboard and the Service Order Trends Dashboard.
Refer to the Using the Service Order Operational Dashboard and Using the Service Order Trends Dashboard sections of the Business User Guide for more information on this functionality.
Configuring the Service Order Operational Dashboard and Service Order Trends Dashboard includes the following:
Configure Activity Type
Configure the following payload statistics activity type:
  • Activity Statistics Aggregator Creator
Use the following procedure to create this activity type:
  1. Select Admin, then Communication, then Activity Type. The Activity Type portal and Activity Type List zone open.
  2. Click the Add/Edit icon for the "Activity Statistics Aggregator Creator" activity type in the Activity Type List zone.
  3. Specify the following:
    • Create Aggregators for Field Activity Statistics: Yes
    • Create Aggregators for Command Activity Statistics: Yes
    • Activity-Requesting Service Providers: The external system(s) that sends service requests
    • Exception Handling: To Do Type, To Do Role, and other values as appropriate for your implementation.
  4. Click Save.
See  Configuring Activity Types   for more information.
Configure Measuring Component Types
Configure the following measuring component types for each service type in your implementation:
  • Activity Processing Accumulation Aggregator
  • Activity Aging Snapshot Aggregator
  • Activity Processing Snapshot Aggregator
  • Activity Processing Derived Snapshot Aggregator
The tables below provide details for these measuring component types based on the "Electric" service type from the demonstration database.
Sub-Aggregator Measuring Component Types:
Field
ACT_​PROC_​SNAP_​AGG
ACT_​PROC_​DER_​SNAP_​AGG
Description
Measuring Component Type Business Object
Activity Statistics Sub-Aggregator Type
Measuring Component Business Object
Activity Derived Snapshot Aggregator
Measurement Business Object
Measurement
Measurement
Service Type
Electric
Electric
Interval Size
24:00:00
24:00:00
Fallback Time Zone
US Eastern Time
US Eastern Time
Consumptive/Subtractive
Consumptive
Consumptive
Activity Aggregator Type
Aggregation
Aggregation Horizon: 7
Aggregation Lag: 2
Aggregation Cut-Off Time: 12:00:00
Aggregation Lag: 1
Value Identifiers
Value Identifier Type
Short Hand Description
Unit of Measure
Measurement
Created
Count
Value 01
Completed
Count
Value 02
Error
Count
Value 03
Discarded
Count
Unit of Measure
Measurement
Total
Count
Value 10
Discarded
Count
Value 01
Completed
Count
Value 02
Error Total
Count
Value 03
Error in Field
Count
Value 04
Error in Command
Count
Value 05
Error in Orchestrator
Count
Value 06
In Progress Total
Count
Value 07
In Progress in Field
Count
Value 08
In Progress in Command
Count
Value 09
In Progress in Orchestrator
Count
Sub-Aggregator Types
N/A
N/A
Display Configuration
Hours of Chart Data to Display: 480
Default Measurement Condition: Regular
Master Aggregator Measuring Component Types:
Field
ACT_​PROC_​ACC_​AGG
ACT_​AGN_​SNAP_​AGG
Description
Activity Statistics Master Aggregator Type
Measurement
Measurement
Service Type
Electric
Electric
Interval Size
24:00:00
24:00:00
Fallback Time Zone
US Eastern Time
US Eastern Time
Consumptive
Consumptive
Activity Processing
Aggregation
Aggregation Horizon: 5
Aggregation Lag: 2
Aggregation Lag: 2
Value Identifiers
Unit of Measure
Measurement
Activity Count
Count
Value 10
Discarded Count
Count
Value 01
Completed Count
Count
Value 02
Error Count
Count
Value 03
Error in Field
Count
Value 04
Error in Command
Count
Value 05
Count
Value 06
In Progress Count
Count
Value 07
Count
Value 08
Count
Value 09
Count
Unit of Measure
Measurement
Average Completion Time
Count
Value 01
Completed Within Tolerance
Count
Value 02
12-19 Hours Late
Count
Value 03
20-27 Hours Late
Count
Value 04
28+ Hours Late
Count
N/A
Hours of Chart Data to Display: 720
Create Activity Aggregator Measuring Components
Create an activity aggregator measuring component for each activity type you wish to capture for each measuring component type you created above. For example, if you wanted to capture statistics for request orchestration activity types (such as Enable Service, Disable Service, and so on) for the above measuring component types, you would create a total of 24 measuring components, as follows:
Aggregation Dimensions — Activity Type
Aggregation Dimensions — Service Type
Back to Back Orchestrator
Electric
Electric
Electric
Electric
Cut for Non Payment Orchestrator
Electric
Electric
Electric
Electric
Disable Service
Electric
Disable Service
Electric
Disable Service
Electric
Disable Service
Electric
Enable Service
Electric
Enable Service
Electric
Enable Service
Electric
Enable Service
Electric
Exchange Meter
Electric
Exchange Meter
Electric
Exchange Meter
Electric
Exchange Meter
Electric
Reconnect Service for Payment Orchestrator
Electric
Electric
Electric
Electric
If you wanted to also capture statistics for smart meter commands or field task types, you would need to create activity aggregator measuring components for each individual command or field task type for each measuring component type.
If you are creating service order activities from multiple initiating systems (such as a customer information system and a network management system), you would need to create separate sets of activity aggregator measuring components for each initiating system.
Configure the Service Order Management Master Configuration
You can access the Master Configuration portal by selecting Admin, then General, then Master Configuration.
Select the Service Order Management Master Configuration.
Use the Add button beside the record to configure for the first time. If a record has already been added, then click the Edit button instead. Use the embedded help to guide you through the meaning of each configuration field.
Create an Activity for each Measuring Component Type
Create an activity for each measuring component type created above. Based on the example above (from the demonstration database) you would create an activity for each of the following measuring component types for each service type:
For example, if you configured measuring component types for both "Electric" and "Water" service types, you would create eight activities (two of each of the types listed above).
Use the following procedure to create these activities:
  1. Select Menu, then Communication, then Activity, then Add. The  Select Type  page opens.
  2. Select "Activity Statistics Aggregator Creator" from the Activity Type drop-down list and click OK. The Activity Statistics Aggregator Creator page opens.
  3. Select the appropriate measuring component type from the Aggregator Measuring Component Type drop-down list.
  4. Select the appropriate service type ("E, "Water", and so on) from the Service Type drop-down list.
  5. Click Save.
See Maintaining Activities  in the Business User Guide for more information about creating and maintaining activities.
Aggregation and Batch Processing
The Service Order Management dashboards are based on aggregated data, and are configured to be refreshed daily. To refresh the data used in the dashboard, the following aggregation and batch processes should be processed in sequence each day.
Dimension Scanning
  • D1-ADS (Aggregation Dimension Scanner Monitor): Used to transition "Activity Statistics Aggregator Creator" activities (created above) to the "Scan" state which checks for aggregator measuring components based on each measuring component type for each combination of dimensions. If needed, this process creates additional aggregator measuring components.
Use the following parameters when running this batch process:
  • Measuring Component Maintenance Object (maintenanceObject): D1-ACTIVITY
  • Restrict by Batch Code (isRestrictedByBatchCode): true
  • Restrict to Business Object (restrictToBusinessObject): D1-ActivityStatsAggtorCreator
  • Restrict by Status Code (restrictToBOStatus): ACTIVE
Note: Dimension scanning can also be performed manually by clicking Scan on the individual activities in the Activity portal.
Aggregation
  • D1-ACTAG (Activity Statistics Aggregation Monitor):  Used to aggregate activity data (via aggregator measuring components) to be displayed in the Service Order Management dashboards.
  • Restrict to Business Object (restrictToBusinessObject): Aggregator Measuring Component business object, based on the measuring component types configured earlier:
    • D1-ActivityAgingSnapAggtor (Activity Aging Snapshot Aggregator)
    • D1-ActivityProcsAggregator (Activity Processing Accumulation Aggregator)
    • D1-ActivityProcDerivedSnapAgg (Activity Derived Snapshot Aggregator)
    • D1-ActivityProcSnapAggtor (Activity Processing Snapshot Aggregator)
  • Override Maximum Errors (maxErrors): 1000
Note: Aggregation can also be performed manually by clicking Update Statistics on the Activity Statistics dashboard zone.
