Maintaining Measuring Component Comparison Periods
You use the Measuring Component Comparison Period portal to maintain measuring component comparison periods.
Refer to About Measuring Component Comparison Periods for additional functional information.
You can access the portal from Menu > Device > Measuring Component Comparison Period. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Measuring Component Comparison Period: This zone displays the basic attributes of the measuring component comparison period.
