Defining Work Calendar
This portal is used to view and maintain information about a work calendar. Work calendars are used to ensure system-calculated dates fall on a workday.
You can access the portal from Admin > General > Work Calendar. You are brought to a query portal with options for searching for a specific calendar. Once a calendar has been selected you are brought to the maintenance portal to view and maintain the selected record.
The following zones will appear as part of the portal's Main tab page
  • Work Calendar. This zone provides information about the selected calendar.
  • Work Calendar Holidays. This zone lists the holidays observed by your organization for this calendar. Use the zone actions to add, maintain or duplicate a work holiday entry.
