Turn Off A Function Module
The base package is provided with a Module Configuration Feature Configuration that allows your organization to turn off base package function modules.
To turn off any of the base package function modules add a Turned Off option to this feature configuration referencing that module. Refer to the MODULE_​FLG lookup field for the complete list of the application's function modules.
Any module not referenced on this feature configuration is considered turned on, i.e. accessible. To turn on a module, simply remove its corresponding Turned Off option from this feature configuration.
You may view your module configuration setup on the installation options page.
Note: Only one. The system expects only one Module Configuration feature configuration to be defined.
