UI Map Help
A tool tip can be used to display additional help information to the user. This applies to section elements as well as individual elements on a map zone or UI Map. Refer to the tips context sensitive zone associated with the UI Map page for more information. The Custom Look And Feel Feature Configuration provides options to control the following:
  • Whether UI Map Help functionality is turned on or off. By default it is turned on.
  • Override the default help image with a custom image
  • The location of the help image, either before or after the element.
Fastpath: Refer to the feature configuration for a detailed description of each option.
