Captured Information
When auditing is enabled for a field, the following information is recorded when the field is changed, added and/or deleted (depending on the actions that you are auditing for that field):
  • User ID
  • Date and time
  • Table name
  • Row's prime key value
  • Field name
  • Before image (blank when a row is added)
  • After image (blank when a row is deleted)
  • Row action (add, change, delete)
