Defining Analytics Options
Refer to Understanding Operational Analytics for an overview of the operational analytics functionality.
Your specific product may require some system wide configuration to be defined when using operational analytics.
Navigate to the Extendable Lookup portal. Search for and select the Analytics Options business object.
Use the embedded help to review information about the options to define.
