Creating a Physical Business Object
The physical business object's schema represents the complete physical structure of the maintenance object, and includes elements for all fields in the maintenance object's tables. There are several processes in the system that may use a maintenance object's physical BO.
To create a physical business object for the maintenance object:
  1. Navigate to Business Object and specify the maintenance object.
  2. Click Generate in the BO Schema dashboard zone to generate a schema that looks like the physical structure of the maintenance object.
  3. Save the physical business object.
  4. Navigate to Maintenance Object and search for the maintenance object.
  5. On the Option tab, add a new option with the type Physical Business Object. The value is the name of the physical business you just created.
