Defining Organization Types
You use the Organization Type portal is used to display and maintain organization types.
Refer to Understanding Organization Types for more information.
You can access the portal by selecting Admin, then Location, then Organization Type.
- Organization Type List: This zone lists all organization type records. Broadcast a record to display the details of the selected record.
- Organization Type: This zone provides information about the selected organization type.
