How Are Cut Processes Cancelled?
A user may cancel a cut process at their discretion, online / real-time using Cut Process - Main.
The system will automatically cancel a cut process when the overdue process is cancelled.
Regardless of what triggers the cancellation, the Cancel Cut Process algorithm plugged in on the cut process's template handles the cancellation.
If a cut process is canceled and the cut process's events created field activities, the cancel logic embodied in the algorithm can be quite sophisticated. Refer to Field Activities To Cut And Reconnect Service for an example.
