Non-Interval 'Plain' XML to IMD Mapping
The following table outlines how non-interval data in the "plain" XML format is mapped to the InitialLoadIMD format when the Landis+Gyr record type is set to "EMED01" (non-interval usage).
| "Plain" XML Element | InitialLoadIMD element | Notes |
| RecordType | N/A |
| Premise | N/A |
| ESIID | N/A |
| Provisioned | N/A |
| MeterID | dvcIdN | as is |
| kWh | enQty | as is |
| uom | KWH | |
| TimeStamp | enDt | Convert to OUAF date/time format This should be mapped to enDt. Relevant only to non-interval data. |
| Peak | enQty | as is A separate IMD Seeder will be created with  |
| PeakDateTime | enDt | Convert to OUAF date/time format |
| Dmd | enQty | as is  A separate IMD Seeder will be created with  |
| TouA | enQty | as is A separate IMD Seeder will be created with  |
| TouB | enQty | as is A separate IMD Seeder will be created with  |
| TouC | enQty | as is A separate IMD Seeder will be created with  |
| TouD | enQty | as is A separate IMD Seeder will be created with  |
| TouE | enQty | as is A separate IMD Seeder will be created with  |
| Volts | enQty | as is  A separate IMD Seeder will be created with  |
| PF | enQty | as is  A separate IMD Seeder will be created with  |
| N/A | imdType | D1IL |
| Origin | externalId | the origin element in "Plain" XML (incoming file name) |
| N/A | serviceProviderExternalId | L+G This is a constant. There is no such field in incoming structure. |
| RawData | rawData | Vendor-specific "raw" data When the "populateRawIMD" parameters in the EnvironmentSettings.xq file is set to true. |
