External System
External systems represent external applications with which the Smart Grid Gateway will exchange messages or data. In the case of the Smart Grid Gateway adapters, external systems represent the head-end systems with which the adapters communicate.
An external system that represents the Sensus RNI must be present in your system. If this is not present in your configuration, add it, along with the following Outbound Message Types. Refer to the Oracle Utilities Application Framework documentation for more information about creating external systems.
External System - Sensus:
External System: Sensus
Description: Sensus
Outbound Message Types:
| Outbound Message Type | Description | Message Sender |
| D6-CONDISCON | Sensus Initiate Connect Disconnect | D6-CONDISCON |
| D6-INITMTR | Initiate Meter Read By Meter ID | D6-InitMID |
| D6-INTOUTDET | Initiate Outage Detection Request | D6- INTOUTDET |
Note: The following apply to all of the above outbound message types:
Processing Method: Real-time
Message XSL: D6-Request xsl
Response XSL: D6-Response.xsl
