FileParser Interface
This section provides the source code of the FileParser interface used by the Java class delivered with the Java package described earlier in this section.
package com.splwg.d1.sgg.osb.common;
import java.io.IOException;
import java.io.InputStream;
/** <p>
 *  FileParser component is responsible for processing the input
 *  stream and returning a Plain XML containing all data from
 *  incoming transaction in a shape expected by the following
 *  Oracle Service Bus message flow.
 * </p>
public interface FileParser {
     * Returns the next message in Plain XML format
     * or null if there are no more messages
     * @return next message as InputStream
    InputStream getNextStream() throws IOException;
     * Returns the current position in the currently
     * parsed source input stream
     * @return the position in source input stream after
     * last incoming row was read and parsed
    long getPosition();
     * Sets source stream
     * @param input the Input Stream that should be parsed
    void setInputStream(InputStream input);
     * Sets "owner" FileProcessor
     * @param owner the Instance of FileProcessor that will
     * be notified about current processing via call to
     * utility methods (saveInvalidRow and setParseFinishNote)
    void setProcessor(FileProcessor owner);
     * Sets the position from which the parsing of source
     * stream should be started.
     * It is necessary if last time the processing of
     * current file has been interrupted
     * @param position the starting position
    void setStartPosition(long position);
     * Returns the byte array that contains a portion of an incoming
     * file that most recently has been read and converted to Plain XML.
     * It should be in the same format as incoming file. The header and
     * tail records, if there are, should be included and updated according
     * to the content
    byte[] getCurrentInputPortion();
     * Returns type of currently generated transaction - USAGE or EVENT
    FileProcessor.TransactionType getCurrentTransactionType();
     * Returns the number of successfully generated transactions of given type
    int getTransactionCount(FileProcessor.TransactionType type);
     * Returns the number of expected transactions in input stream
     * Returns -1 if information not available
    int getTotalExpected();
