Manage Run Logs
The Manage Run Logs page provides an automatically generated log that describes the run process and corresponding tasks.
On this page:
Fields and Buttons
The top section of the Manage Run Logs page allows you to search for run logs matching criteria in the fields:
- Run ID field: System-assigned, unique identifier.
- Run Log ID field: System-assigned, unique identifier.
- Refresh Rate field: Frequency, in seconds, that the results should be automatically update.
- Get Logs: Initiates a search for logs matching criteria set in the fields.
Data Table
The data table contains the following columns and links:
Table Columns
- Run Log ID: Run log’s system-generated, unique identifier.
- Server Process: Server node that processed the run.
- Run Start Time: Date and time that the run started.
- Run End Time: Date and time that the run ended.
Links
- View: Opens the View Run Logs dialog box, which displays the run’s processing information such as start and end time, status code, and run progress.
- Run Summary: Opens the Run Summary dialog box, which displays processing information about each task that was processed within the run.
- Task Log: Navigates to the Manage Task Logs page and displays the current context to provide further information.
View Run Logs Information
The View Run Logs dialog box is accessed from the View link, which is found in the data table on the Manage Run Logs page. This feature offers additional information to what is displayed in the data table for Manage Run Log.
Fields and Buttons
The Run Logs contain the following fields and buttons:
- Run Log ID: Run log system-generated, unique identifier.
- Run ID: Run system-generated, unique identifier.
- Execution Type: Identifies the method that the run was initiated.
- Success Email: Address to send a notice when the run completes.
- Failure Email: Address to send a notice in case the run fails.
- Run Mode: Run processing category.
- Data Start Time: Earliest date and time of the data that was included in the run.
- Data End Time: Latest date and time of the data that was included in the run.
- Status Code: Indicates if the run is In Progress, ran Successfully, or had a Fatal error.
- Run Progress: Indicates the run’s current status.
- Run Priority: Indicates the run’s priority on the node.
- Create Time: Date and time that the run was created.
- Create Transaction ID: Transaction ID when the run was created.
- Update Time: Date and time that the run was most recently updated.
- Cancel: Closes the dialog box.
View Run Summary Information
The Run Summary link in the Manage Run Logs data table launches the View Run Summary dialog box and supplies additional information.
Columns and Buttons
- Task Lookup: Secondary description given to the task when it was added.
- Data Start Date: Earliest date and time of the data that was included in the task
- Data End Date: Latest date and time of the data that was included in the task.
- Elapsed Time: Total amount of time that it took for the task to run.
- Task Start Time: Date and time when the task initiated.
- Task End Time: Date and time when the task completed (either succeeded or failed).
- Transaction Name: System-assigned name of the transaction associated to this task.
