Upgrade Source Applications
- Before proceeding with source upgrade, ensure you have a proper backup plan to revert the changes in case of any failure.
- Upgrade the source applications to be compatible with Oracle Utilities Analytics Warehouse v25.10.0.0.0.
Upgrade Network Management System (NMS) Source Application
- Perform the following steps only if the source application is Oracle Utilities Network Management System, and you are upgrading to version 2.6.0 or later.
- If the source application is Oracle Utilities Network Management System and version is below 2.6.0, perform the steps mentioned in the Upgrade Other Source Applications section.
Ensure the source application is down.
Ensure the database is up and running in both the source and the target.
- Upgrade the NMS source application only—without executing NMS UTC data conversion migration scripts, and without executing the normal setup process which runs other migrations involving DDL changes.
After a successful upgrade, do not release the source applications to end users. Ensure that you stop the source applications but keep the source databases up and accessible.
If the source database is not in UTC, then do the following:
Stop all Golden Gate Processes (EXTRACTS and REPLICATS in the source and the target).
Execute the NMS UTC data conversion migration script as part of the upgrade to NMS 2.6.0 or later before changing the source database time zone to UTC.
Update the source database time zone to UTC as part of the upgrade to NMS 2.6.0 or later.
If the source database is in UTC and the source Application is not in UTC, perform the following steps:
- Alter the initial checkpoint of the Golden Gate EXTRACT & PUMP processes using BEGIN NOW in the source.
GGSCI > ALTER EXTRACT <NMS1>AAX BEGIN NOW GGSCI > ALTER EXTRACT <NMS1>AAP BEGIN NOW Note: Here the product context code is <NMS1>. -
Ensure the source application is still down, and then start all Golden Gate Processes (EXTRACTS and REPLICATS) in the source and target.
If the source database and source Application are in UTC, ensure the source application is still down, and then start all Golden Gate Processes (EXTRACTS and REPLICATS) in the source and target.
Execute the normal setup process which runs other migrations involving DDL changes as part of upgrade to NMS 2.6.0 or later.
Ensure that the table NMS_ACCOUNTS_HISTORY is created in the source database.
Ensure Incremental Changes (DDL and DML changes during the upgrade) are synced. The Lag for Chkpt and Time Since Chkpt in both the source and target databases should be 0.
Stop all Golden Gate Processes (EXTRACTS, REPLICATS, PMSRVR, JAGENT, MANAGER) in the source and the target.
Perform the following steps if the upgraded source applications are Meter Data Management (MDM), Customer Care and Billing (CCB), Customer to Meter (C2M), Work and Asset Management (WAM), and Network Management System (NMS) (if you are upgrading to a version below 2.6.0).-
Start all Golden Gate Processes (EXTRACTS, REPLICATS, PMSRVR, JAGENT, MANAGER) in the source and the target.
Make sure the data in the source is in sync with the replication tables. The Lag for Chkpt and Time Since Chkpt in both the source and target databases should be 0.
Upgrade the source application.
Ensure Incremental Changes (DDL and DML changes during the upgrade) are synchronized. Make sure the data in the source is in synchronization with the replication tables. The Lag for Chkpt and Time Since Chkpt in both the source and target databases should be 0.
