Property | Details |
Description | A device is “available” if it's disposition is “in-store”, indicating that the device is available to be installed. This analysis shows the 15-month trend of the device counts that are installed and the devices that are available. It indicates the replacement capability of the utility. |
Purpose | Business users can analyze the trend of their installed devices as against the device available in-store. This will show the utility's capacity to replace any faulty device installed on the field. This would be a key factor in improving customer satisfaction and also the ability the accurately track usage. For example: If 10 devices installed at various customer locations become dysfunctional, there should be at least 10 devices available in the storeroom to replace them. It is not a good sign if the replacement capacity is less. |
Representation | The bar graph shows the trend in available devices and installed devices. The X-axis represents the months. The Y-axis represents the device count. Hover over the bars for specific values. The table shows the installed and available devices in each month. It also shows the replacement capability per installed device, which is the capacity to replace installed devices in case of repair. Replacement Capability per Installed Device = Available Devices / Installed Devices Note: If the number of installed devices is zero, then replacement capability per installed device is same as the number of available devices. |
Drill Down | No drill down |
Source Object | Operational Device Snapshot Fact |
OAS Subject Area | ODM - Operational Device Snapshot |
Metrics | Installed Devices, Available Devices, % Installed |
Description | “Installed age” indicates the duration a device has been installed on the field. This analysis shows the number of devices sliced by the various installed age buckets. The data is shown for the selected month. |
Purpose | This analysis helps customers to get an insight into the installed ages of devices of various device types. It provides an indication of how long the devices have been installed on the field. The information is also shown model wise. It helps to decide if the older devices that are installed for very long duration should be replaced with newer ones. |
Representation | The bar graph shows various age buckets and the installed devices count for each of the buckets. The X-axis represents the installed age. The Y-axis represents the device count. Hover over the bars for respective values. The Installed Age drop down slices the data by various age buckets, such as 0-30 days, 31-60 days, 61-89 days, and >90 days. The table displays the number of installed devices and the average installed age (in days) for the selected month. It also shows the model and manufacturer details for each of the device. |
Drill Down | The Installed Devices column link drills down to the Installed Details dashboard page for more specific details. |
Metrics | Installed Devices, Average Installed Age (In Days) |
Description | This analysis shows a list of top 100 devices sorted by their installed ages. The data is displayed for the selected month. |
Purpose | Business users can analyze the top 100 best performing devices and determine the device types, manufacturers, and models producing better devices with maximum installed ages. |
Representation | The table displays the type of device, its manufacturer, model number, address, and installed age (in days) for each of the devices. It also shows the rank for each device. |
Drill Down | The Device column link drills back to the Asset page in the Oracle Utilities Operational Device Management system. The Address column link drills back to the Location page in the Oracle Utilities Operational Device Management system. |
Metrics | Installed Age (In Days) |
