Installation Types
The first step in the installation procedure is to determine the installation type that meets your business requirements. The possible installation types are as follows:
• Initial Installation: A base installation, typically used for a production environment.
• Upgrade: An upgrade installation from:
• 2.8.0.0.1 to 2.8.0.1.0
• Demo Installation: A base installation with pre-populated demo data, typically used for demonstration or training purposes.
The following sections describe these installation types in detail.
This type is applicable for a new Oracle Utilities Analytics Warehouse installation. For an initial installation, you must install all of the following components:
• Oracle Utilities Analytics Warehouse Database
• Oracle Utilities Analytics Warehouse ELT
• Oracle Utilities Analytics Warehouse Administration
• Oracle Utilities Analytics Warehouse Dashboards
Following is a high-level workflow of the installation process:
• Step 1: Install the database components.
• Oracle Database
• WebLogic
• Oracle Data Integrator with JavaEE
• Oracle Utilities Analytics Warehouse ODI-Based ELT
• Step 2: Install the dashboard components.
• Oracle Client
• Oracle Analytics Server
Refer to the Oracle Utilities Analytics Warehouse Installation and Configuration Guide in the Oracle Utilities Analytics Warehouse documentation for the prerequisite software required to install each of the components and the respective component installation steps.
Upgrade
This installation type is applicable while upgrading Oracle Utilities Analytics from the following upgrade paths:
• V2.8.0.0.1 to V2.8.0.1.0
For an upgrade, you must upgrade all of the following components:
Following is a high-level workflow of the upgrade process:
• Step 1: Upgrade the database components in the order below:
• Oracle Database
• Step 2: Install/upgrade the dashboard components as below:
• Oracle Client
Refer to the Oracle Utilities Analytics Warehouse Installation and Configuration Guide in Oracle Utilities Analytics Warehouse documentation for the prerequisite software required to install each of the components and the respective installation steps.
Demo Installation
This installation type is applicable when installing a database component for Oracle Utilities Analytics Warehouse Dashboards for demonstration or training purposes. For a demo installation, install the following components:
• Oracle Utilities Analytics Warehouse Demo Database
Following is a high-level workflow of the demo installation process:
• Step 1: Install the database components in the order below:
• Oracle Database
• Import demo data
• Step 2: Install the dashboard components as below:
• Oracle Client
Refer to the Oracle Utilities Analytics Warehouse Installation and Configuration Guide in Oracle Utilities Analytics Warehouse documentation for the prerequisite software required to install each of the components and the respective component installation steps.
