Dimensions
This section lists all the dimension tables that belong to the Oracle Utilities Network Management System star schemas only and are populated only from the Oracle Utilities Network Management System source product.
Following is a list of dimensions included in this document:
City
Crew
Event
Feeder
Meter
Phase
Storm
Account Type
Captures account type details from the source system.
Properties
Property
Value
Target Table
CD_ACCT_TYPE
Table Type
Dimension
SCD Type
Type 1
Source System Driver Table
CU_ACCOUNT_TYPE
ODI Package
B1_PKG_CD_ACCT_TYPE
ETL View
B1_D_ACCT_TYPE_VW
Fields
Target Field
Description
Source Field
Transformation Logic
Surrogate Key
ACCT_TYPE_KEY
Account Type Dimension
Populated with the B1_ACCT_TYPE_SEQ sequence.
Natural Keys
SRC_ACCT_TYPE_CD
Account Type Code
CU_ACCOUNT_TYPE. ACCTYP_ACCOUNT_
TYPE
Attributes
There are no attributes in this dimension.
User Defined Attributes
UDF1_CD
User Defined Field 1 Code
UDF1_DESCR
User Defined Field 1 Description
UDF2_CD
User Defined Field 2 Code
UDF2_DESCR
User Defined Field 2 Description
UDF3_CD
User Defined Field 3 Code
UDF3_DESCR
User Defined Field 3 Description
UDF4_CD
User Defined Field 4 Code
UDF4_DESCR
User Defined Field 4 Description
UDF5_CD
User Defined Field 5 Code
UDF5_DESCR
User Defined Field 5 Description
UDF6_CD
User Defined Field 6 Code
UDF6_DESCR
User Defined Field 6 Description
UDF7_CD
User Defined Field 7 Code
UDF7_DESCR
User Defined Field 7 Description
UDF8_CD
User Defined Field 8 Code
UDF8_DESCR
User Defined Field 8 Description
UDF9_CD
User Defined Field 9 Code
UDF9_DESCR
User Defined Field 9 Description
UDF10_CD
User Defined Field 10 Code
UDF10_DESCR
User Defined Field 10 Description
Data Load Attributes
DATA_LOAD_DTTM
Data Load Date/Time
Populated with the load timestamp value.
UPDATE_DTTM
Update Date and Time
DATA_SOURCE_IND
Data Source Indicator
CES_PARAMETER.
VALUE
Populated with the DSI value on the source product instance configuration.
The table is populated as part of the initial setup and the DSI value is extracted from the source system.
JOB_NBR
Job Number
Populated with the ODI job execution session number.
Alarm Log
Captures attributes related to DDS alarm logs from the source system.
Properties
Property
Value
Target Table
CD_ALARM_LOG
Table Type
Dimension
SCD Type
Type 1
DDS_ALARM_LOG
ODI Package
B1_PKG_CD_ALARM_LOG
ETL View
B1_D_ALARM_LOG_VW
Fields
Target Field
Description
Source Field
Surrogate Key
ALARM_LOG_KEY
Alarm Log Dimension Surrogate Key
Populated with the sequence from B1_ALARM_LOG_SEQ.
Natural Keys
SRC_ALARM_CLS
Alarm Class
DDS_ALARM_LOG.
ALARM_CLS
SRC_ALARM_IDX
Alarm Index
DDS_ALARM_LOG.ALARM_IDX
Attributes
ALARM_TYPE
Alarm Type
DDS_ALARM_LOG.ALARM_TYPE
DESCR
Description
DDS_ALARM_LOG.DESCRIPTION
PRIORITY
Priority
DDS_ALARM_LOG.ALARM_PRIORITY
SOURCE
Source
DDS_ALARM_LOG.SOURCE
PHASE
Phase
DDS_ALARM_LOG.PHASE
CURR_STATE
Current State
DDS_ALARM_LOG.STATE
NOMINAL_STATE
Nominal State
DDS_ALARM_LOG.NOMINAL
DEVICE
Device
DDS_ALARM_LOG.DEVICE
DEVICE_ATTRIBUTE
Device Attribute
DDS_ALARM_LOG.ATTRIBUTE
DEVICE_ATTRIBUTE_
UNIT
Device Attribute Unit
DDS_ALARM_LOG.ATTRIBUTE_UNIT
DEVICE_ATTRIBUTE_
DESCR
Device Attribute Description
DDS_ALARM_LOG.ATTRIBUTE_DESC
DEVICE_QUALITY
Device Quality
DDS_ALARM_LOG.QUALITY
TERM_STATION
Terminal Station
DDS_ALARM_LOG.TERM_STATION
ACTIVE_IND
Active Indicator
DDS_ALARM_LOG.ACTIVE
ALARM_IND
Alarm Indicator
DDS_ALARM_LOG.IS_ALARM
RTI_ALIAS
RTI Name
DDS_ALARM_LOG.RTI_ALIAS
EXTERNAL_ID
External ID
DDS_ALARM_LOG.EXTERNAL_ID
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Call Info
Extracts the call details (along with the caller information) created in the source system.
Properties
Property
Value
Target Table
CD_CALL_INFO
Table Type
Dimension
SCD Type
Type 1
INCIDENTS
ODI Package
B1_PKG_CD_CALL_INFO
ETL View
B1_D_CALL_INFO_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CALL_INFO_KEY
Call Info Dimension Surrogate Key
Populated with the sequence from SPL_CALL_INFO_SEQ.
Natural Keys
SRC_INCIDENT_ID
Call Number
INCIDENTS.NUMB
Attributes
CALLER_NAME
Caller Name
INCIDENTS.CUSTOMER_NAME
PHONE_NBR
Phone Number
INCIDENTS.CUSTOMER_PHONE
COMPLAINT
Complaint Description
INCIDENTS.
COMPLAINT
COMMENTS
Call Comments
INCIDENTS.OP_COMMENT
ADDRESS
Address
INCIDENTS.ADDRESS
ALTERNATE_PHONE
Alternate Phone
INCIDENTS. ALTERNATE_PHONE
APPT_RANGE
Appointment Range
INCIDENTS. APPT_RANGE
APPT_TYPE
Appointment Type
INCIDENTS. APPT_TYPE
BITMASK
Bit Mask
INCIDENTS. BITMASK
CANCEL_IND
Call Cancelled Indicator
INCIDENTS. CALL_CANCEL
CUSTOMER_TYPE
Customer Type
INCIDENTS. CUSTOMER_TYPE
CALLBACK_REQUEST
Callback Request
INCIDENTS. CALLBACK_REQUEST
CALLBACK_STATUS
Callback Status
INCIDENTS. CALLBACK_STATUS
CALLBACK_LATE_IND
Callback Late Indicator
INCIDENTS. CALLBACK_LATE
CALLBACK_CANC_
REASON
Callback Cancel Reason
INCIDENTS. CB_CANCEL_REASON
CALLBACK_TRANSF_
IND
Callback Transfer Indicator
INCIDENTS. CB_TRANSFERRED
CALLBACK_USERNAME
Callback Agent Name
INCIDENTS. CB_USERNAME
CLUE_IND
Clue
INCIDENTS. CLUE
EXTERNAL_ID
External Id
INCIDENTS. EXTERNAL_ID
LIFE_SUPPORT_IND
Life Support Indicator
INCIDENTS. LIFE_SUPPORT
MEET_CODE
Meet Code
INCIDENTS. MEET_CODE
MESSAGE_IND
Message Indicator
INCIDENTS. MESSAGES
ORDER_NBR
Order Number
INCIDENTS. ORDER_NUMBER
AFFECTED_PHASES
Affected Phases
INCIDENTS. PHASES
PRIORITY
Priority
INCIDENTS. PRIORITY
TOTAL_PRIORITY
Total Priority
INCIDENTS. TOTALPRIORITY
TROUBLE_LOC
Trouble Location
INCIDENTS. TROUBLE_LOC
TROUBLE_QUEUE
Trouble Queue
INCIDENTS. TROUBLE_QUEUE
USER_NAME
User Name
INCIDENTS. USER_NAME
ACTIVE_IND
Call Active Indicator
INCIDENTS.ACTIVE
COMPLETE_IND
Complete Indicator (Y/N)
INCIDENTS.COMPLETE
DESCRIPTION
Trouble Code Short Description
INCIDENTS.SHORT_
DESC
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
TE_STATUSES.JRN_UPDATE_DTTM
TE_STATUS_GROUPS.JRN_UPDATE_DTTM
Populated with the updated timestamp value.
DELETE_IND
INCIDENTS.JRN_FLAG
Populated with “1” for deleted records, and “0” for new/modified records.
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
City
Extracts distinct city information from the CU_SERVICE_LOCATIONS table. The columns that identify the distinct city records are SRC_STATE, SRC_COUNTRY, SRC_CITY, and DATA_SOURCE_IND.
Properties
Property
Value
Target Table
CD_CITY
Table Type
Dimension
SCD Type
Type 1
ODI Package
B1_PKG_CD_CITY
ETL View
B1_D_CITY_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CITY_KEY
City Dimension Surrogate Key
Populated with the sequence from SPL_CITY_SEQ.NEXTVAL.
Natural Keys
There are no natural keys in this dimension.
Attributes
SRC_STATE
State
CU_SERVICE_LOCATIONS.SERV_STATE
SRC_CITY
City
CU_SERVICE_LOCATIONS.SERV_CITY
SRC_COUNTRY
Country
CU_SERVICE_LOCATIONS.SERV_COUNTRY
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
CU_SERVICE_LOCATIONS.LAST_UPDATE_TIME
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Control Zone
Captures the network model structure from the source system via its control zone records and also stores the hierarchy structure between them.
Properties
Property
Value
Target Table
CD_CTRL_ZONE
Table Type
Dimension
SCD Type
Type 2
CONTROL_ZONE_STRUCTURES
CONTROL_ZONES
ODI Package
B1_PKG_CD_CTRL_ZONE
ETL View
B1_D_CTRL_ZONE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CTRL_ZONE_KEY
Control Zone Dimension Surrogate Key
Populated with the sequence from SPL_CTRL_ZONE_SEQ.NEXT VAL.
Natural Keys
SRC_NCG_ID
CONTROL_ZONES.NCG_ID
CONTROL_ZONE_STRUCTURES.CHILD_NCG_ID
Attributes
HIERARCHY_TYPE
Hierarchy Type
“CIR”
CTRL_ZONE_NAME
Control Zone Name
CONTROL_ZONES.
NAME
PARENT_NCG_LVL1_ID
Parent NCG Level 1 ID
CONTROL_ZONES. NCG_ID
Primary hierarchy root NCG
PARENT_NCG_LVL1_
NAME
Parent NCG Level 1 Name
CONTROL_ZONES.
NAME
Name of primary hierarchy root NCG
PARENT_NCG_LVL2_ID
Parent NCG Level 2 ID
Control zone one-level below the root NCG
PARENT_NCG_LVL2_
NAME
Parent NCG Level 2 Name
CONTROL_ZONES.
NAME
Name of the control zone one-level below root NCG
PARENT_NCG_LVL3_ID
Parent NCG Level 3 ID
Control zone two-levels below the root NCG
PARENT_NCG_LVL3_
NAME
Parent NCG Level 3 Name
CONTROL_ZONES.
NAME
Name of the control zone two-levels below root NCG
PARENT_NCG_LVL4_ID
Parent NCG Level 4 ID
Control zone three-levels below the root NCG
PARENT_NCG_LVL4_
NAME
Parent NCG Level 4 Name
CONTROL_ZONES.
NAME
Name of the control zone three-levels below root NCG
PARENT_NCG_LVL5_ID
Parent NCG Level 5 ID
Control zone four-levels below the root NCG
PARENT_NCG_LVL5_
NAME
Parent NCG Level 5 Name
CONTROL_ZONES.
NAME
Name of the control zone four-levels below root NCG
PARENT_NCG_LVL6_ID
Parent NCG Level 6 ID
Control zone five-levels below the root NCG
PARENT_NCG_LVL6_
NAME
Parent NCG Level 6 Name
CONTROL_ZONES.
NAME
Name of the control zone five-levels below root NCG
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
Effective Start Date/Time
EFF_END_DTTM
Effective End Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Control Zone Secondary
Captures details of the second control zone hierarchy if it is setup in the source system.
Properties
Property
Value
Target Table
CD_CTRL_ZONE_SEC
Table Type
Dimension
SCD Type
Type 2
CONTROL_ZONES
ODI Package
B1_PKG_CD_CTRL_ZONE_SEC
ETL View
B1_ D_CTRL_ZONE_SEC_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CTRL_ZONE_SEC_KEY
Control Zone (Secondary) Dimension Surrogate Key
Populated with the sequence from B1_CTRL_ZONE_SEC_
SEQ.
Natural Keys
SRC_NCG_ID
Source NCG ID
All leaf level NCG (i.e. NCG's are not parent) and second parent hierarchy NCG's will be populated into this dimension.
If an NCG has more than one parent NCG, then maximum parent NCG from CONTROL_ZONE_STRUCTURES table will be treated as second hierarchy.
Attributes
CTRL_ZONE_NAME
Control Zone Name
CONTROL_ZONES.NAME
PARENT_NCG_LVL1_ID
Parent NCG ID Level 1
Second hierarchy root NCG
PARENT_NCG_LVL1_
NAME
Parent NCG Name Level 1
CONTROL_ZONES.
NAME
Name of secondary hierarchy root NCG
PARENT_NCG_LVL2_ID
Parent NCG ID Level 2
PARENT_NCG_LVL2_
NAME
Parent NCG Name Level 2
CONTROL_ZONES.
NAME
PARENT_NCG_LVL3_ID
PARENT_NCG_LVL3_
NAME
CONTROL_ZONES.
NAME
PARENT_NCG_LVL4_ID
PARENT_NCG_LVL4_
NAME
CONTROL_ZONES.
NAME
PARENT_NCG_LVL5_ID
PARENT_NCG_LVL5_
NAME
CONTROL_ZONES.
NAME
PARENT_NCG_LVL6_ID
PARENT_NCG_LVL6_
NAME
CONTROL_ZONES.
NAME
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Crew
Extracts crew records from both Mobile Workforce Management and Network Management System source database tables CREWS and CREW_TYPES.
Properties
Property
Value
Target Table
CD_CREW
Table Type
Dimension
SCD Type
Type 2
CREWS
ODI Package
B1_PKG_CD_CREW
ETL View
B1_D_CREW_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CREW_KEY
Crew Dimension Surrogate Key
Populated with the sequence from SPL_CREW_SEQ.
Natural Keys
SRC_CREW_ID
Crew ID
CREWS.CREW_KEY
Attributes
ACTIVE
Active
CREW_CD
Crew Code
CREWS.CREW_ID
CREW_DESCR
Crew Description
CREW_TYPES.CREW_
NAME
CREW_CENTER
Crew Center
CREW_CONTACT
Crew Contact
CREWS.CONTACT
CREW_SIZE
Crew Size
CREWS.CREW_SIZE
CREW_TYPE_CD
Crew Type Code
CREWS.CREW_TYPE
CREW_TYPE_DESCR
Crew Type Description
CREW_TYPES.CREW_
TYPE
MOBILE_NUM
Mobile Number
CREWS.MOBILE_NUM
ORG_UNIT1_CD
Organization Unit 1 Code
ORG_UNIT1_DESCR
Organization Unit 1 Description
ORG_UNIT2_CD
Organization Unit 2 Code
ORG_UNIT2_DESCR
Organization Unit 2 Description
ORG_UNIT3_CD
Organization Unit 3 Code
ORG_UNIT3_DESCR
Organization Unit 3 Description
PAGER_NUM
Page Number
CREWS.PAGER_NUM
VEHICLE_ID
Vehicle ID
VEHICLE_NBR
Vehicle Number
VEHICLE_TYPE
Vehicle Type
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Crew Type
Captures crew type details from the source system.
Properties
Property
Value
Target Table
CD_CREW_TYPE
Table Type
Dimension
SCD Type
Type 1
CREWS
ODI Package
B1_PKG_CD_CREW_TYPE
ETL View
B1_ D_CREW_TYPE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CREW_TYPE_KEY
Crew Type Dimension Surrogate Key
Populated with the sequence from B1_CREW_TYPE_SEQ.
Natural Keys
SRC_CREW_TYPE_ID
Crew Type ID
CREW_TYPES.TYPE_
NUM
Attributes
CREW_TYPE
Crew Type
CREW_TYPES.CREW_
TYPE
MDT_IND
MDT Type Indicator
CREW_TYPES.MDT_
TYPE
SKILL
Skills
CREW_TYPES.SKILLS
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Customers Out
Captures customer size ranges. This is a bucket dimension.
Properties
Property
Value
Target Table
CD_CUST_OUT
Table Type
Dimension
SCD Type
Type 1
B1_RANGE_LOOKUP
ODI Package
B1_PKG_CD_CUST_OUT
ETL View
B1_D_CUST_OUT_VW
Fields
Target Field
Description
Source Field
Surrogate Key
CUST_OUT_KEY
Customers Out Dimension Surrogate Key
Populated with the sequence from B1_CUST_OUT_SEQ.
Natural Keys
RANGE_START
Customers Out Start Range
B1_RANGE_LOOKUP.
START_RANGE
RANGE_END
Customers Out End Range
B1_RANGE_LOOKUP.
END_RANGE
Attributes
CUST_OUT_DESCR
Description
B1_RANGE_LOOKUP.
DESCR
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Damage Assessment
Captures various attributes of a damage report as available from the source system.
Properties
Property
Value
Target Table
CD_DAMAGE_ASMT
Table Type
Dimension
SCD Type
Type 2
DAMAGE_REPORT
ODI Package
B1_PKG_CD_DAMAGE_ASMT
ETL View
B1_ D_DAMAGE_ASMT_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DAMAGE_ASMT_KEY
Damage Assessment Dimension Surrogate Key
Populated from the B1_DAMAGE_ASMT_SEQ sequence.
Natural Keys
SRC_DAMAGE_ASMT_ID
Damage Assessment ID
DAMAGE_REPORT.
REPORT_ID
Attributes
SECTION
Affected Section Type
DAMAGE_REPORT.
SECTION
PHASE
Affected Phase
DAMAGE_REPORT.
PHASE
ASSESOR
Assessor
DAMAGE_REPORT.
CREW_ID
MOBILE_NBR
Mobile Number
DAMAGE_REPORT.
RADIO_NUM
ADDRESS
Address
DAMAGE_REPORT.
ADDRESS
CITY
City
DAMAGE_REPORT.CITY
LATITUDE
Latitude
DAMAGE_REPORT.
LATITUDE
LONGITUDE
Longitude
DAMAGE_REPORT.
LONGITUDE
ZONE
Zone
DAMAGE_REPORT.
ZONE
GRID
Grid
DAMAGE_REPORT.
GRID
HAZARDOUS_IND
Hazardous Indicator
DAMAGE_REPORT.
HAZARDOUS
LOAD
Load
DAMAGE_REPORT.
LOAD
LOCATION
Location
DAMAGE_REPORT.
LOCATION
ROAD_BLOCK_IND
Road Blocked Indicator
DAMAGE_REPORT.
ROAD_BLOCKED
STREET_LIGHT_IND
Street Light Indicator
DAMAGE_REPORT.
STREET_LIGHT
COMMENT1
Comment1
DAMAGE_REPORT.
COMMENT1
COMMENT2
Comment2
DAMAGE_REPORT.
COMMENT2
UDF1_CD
UDF1_DESCR
UDF1
UDF2_CD
UDF2_DESCR
UDF2
UDF3_CD
UDF3_DESCR
UDF3
UDF4_CD
UDF4_DESCR
UDF4
UDF5_CD
UDF5_DESCR
UDF5
UDF6_CD
UDF6_DESCR
UDF6
UDF7_CD
UDF7_DESCR
UDF7
UDF8_CD
UDF8_DESCR
UDF8
UDF9_CD
UDF9_DESCR
UDF9
UDF10_CD
UDF10_DESCR
UDF10
UDF11_CD
User Defined Field 11 Code
UDF11_DESCR
User Defined Field 11 Description
UDF11
UDF12_CD
User Defined Field 12 Code
UDF12_DESCR
User Defined Field 12 Description
UDF12
UDF13_CD
User Defined Field 13 Code
UDF13_DESCR
User Defined Field 13 Description
UDF13
UDF14_CD
User Defined Field 14 Code
UDF14_DESCR
User Defined Field 14 Description
UDF14
UDF15_CD
User Defined Field 15 Code
UDF15_DESCR
User Defined Field 15 Description
UDF15
UDF16_CD
User Defined Field 16 Code
UDF16_DESCR
User Defined Field 16 Description
UDF16
UDF17_CD
User Defined Field 17 Code
UDF17_DESCR
User Defined Field 17 Description
UDF17
UDF18_CD
User Defined Field 18 Code
UDF18_DESCR
User Defined Field 18 Description
UDF18
UDF19_CD
User Defined Field 19 Code
UDF19_DESCR
User Defined Field 19 Description
UDF19
UDF20_CD
User Defined Field 20 Code
UDF20_DESCR
User Defined Field 20 Description
UDF20
UDF21_CD
User Defined Field 21 Code
UDF21_DESCR
User Defined Field 21 Description
MISC_TEXT1
UDF22_CD
User Defined Field 22 Code
UDF22_DESCR
User Defined Field 22 Description
MISC_TEXT2
UDF23_CD
User Defined Field 23 Code
UDF23_DESCR
User Defined Field 23 Description
MISC_TEXT3
UDF24_CD
User Defined Field 24 Code
UDF24_DESCR
User Defined Field 24 Description
MISC_TEXT4
UDF25_CD
User Defined Field 25 Code
UDF25_DESCR
User Defined Field 25 Description
MISC_TEXT5
UDF26_CD
User Defined Field 26 Code
UDF26_DESCR
User Defined Field 26 Description
MISC_OPTION1
UDF27_CD
User Defined Field 27 Code
UDF27_DESCR
User Defined Field 27 Description
MISC_OPTION2
UDF28_CD
User Defined Field 28 Code
UDF28_DESCR
User Defined Field 28 Description
MISC_OPTION3
UDF29_CD
User Defined Field 29 Code
UDF29_DESCR
User Defined Field 29 Description
MISC_OPTION4
UDF30_CD
User Defined Field 30 Code
UDF30_DESCR
User Defined Field 30 Description
MISC_OPTION5
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Damage Assessment Status
Captures possible statuses that a damage report can be in.
Properties
Property
Value
Target Table
CD_DAMAGE_ASMT_STATUS
Table Type
Dimension
SCD Type
Type 1
TE_VALID_STATES
ODI Package
B1_PKG_CD_DAMAGE_ASMT_STATUS
ETL View
B1_ D_DAMAGE_ASMT_STATUS_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DAMAGE_ASMT_
STATUS_KEY
Damage Assessment Status Dimension Surrogate Key
Populated from the B1_DAMAGE_ASMT_STATUS_SEQ sequence.
Natural Keys
SRC_STATE_KEY
State Key
TE_VALID_STATES.STATE_KEY
Attributes
STATE_NAME
State Name
TE_VALID_STATES.STATE_NAME
STATE_DESCR
State Description
TE_VALID_STATES.DESCRIPTION
ALARM_IND
Alarm
TE_VALID_STATES.ALARM
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Damage Part
Captures the damage parts that can be listed in a damage report.
Properties
Property
Value
Target Table
CD_DAMAGE_PART
Table Type
Dimension
SCD Type
Type 2
DAMAGE_PARTS
ODI Package
B1_PKG_CD_DAMAGE_PART
ETL View
B1_ D_DAMAGE_PART_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DAMAGE_PART_KEY
Damage Part Dimension Surrogate Key
Populated from the B1_DAMAGE_PART_SEQ sequence.
Natural Keys
SRC_PART_ID
Damage Part ID
DAMAGE_PARTS.PART_ID
Attributes
PART_CODE
Damage Part Code
DAMAGE_PARTS.CODE
PART_NAME
Damage Part Name
DAMAGE_PARTS.PART_NAME
PART_TYPE
Damage Part Type
DAMAGE_PARTS.TYPE
PART_PARENT
Damage Part Parent
DAMAGE_PARTS.
PARENT
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Damage Type
Captures the damage types that a damage report can be associated with.
Properties
Property
Value
Target Table
CD_DAMAGE_TYPE
Table Type
Dimension
SCD Type
Type 2
DAMAGE_TYPES
ODI Package
B1_PKG_CD_DAMAGE_TYPE
ETL View
B1_ D_DAMAGE_TYPE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DAMAGE_TYPE_KEY
Damage Type Dimension Surrogate Key
Populated with the sequence from B1_DAMAGE_TYPE_SEQ.
Natural Keys
SRC_DAMAGE_TYPE_ID
Damage Type ID
DAMAGE_TYPES.TYPE_ID
Attributes
DAMAGE_TYPE_NAME
Damage Type Name
DAMAGE_TYPES.TYPE_NAME
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Device Dimension
Stores device records from the Network Management System source database table NETWORK_COMPONENTS.
Properties
Property
Value
Target Table
CD_DEVICE
Table Type
Dimension
SCD Type
Type 2
NETWORK_COMPONENTS
ODI Package
B1_PKG_CD_DEVICE
ETL View
B1_D_DEVICE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DEVICE_KEY
Device Dimension Surrogate Key
Populated with the sequence from SPL_DEVICE_SEQ.NEXT VAL.
Natural Keys
SRC_DEVICE_CLS
Device Class
NETWORK_COMPONENTS.H_CLS
SRC_DEVICE_IDX
Device Index
NETWORK_COMPONENTS.H_IDX
Attributes
DEVICE_NAME
Device Name
NETWORK_COMPONENTS.NAME
DEVICE_TYPE_CD
Device Type Code
CLASSES.C_TYPE
DEVICE_TYPE_DESCR
Device Type Description
CLASSES.C_TYPE
DEVICE_CLASS_CD
Device Class Code
CLASSES.C_NAME
DEVICE_CLASS_DESCR
Device Class Description
CLASSES.C_DESC
ACTIVE_IND
Active Indicator
NETWORK_COMPONENTS.ACTIVE
VOLTAGE
Voltage
NETWORK_COMPONENTS.VOLTAGE
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
EFF_START_DTTM
EFF_END_DTTM
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Estimated Restoration Duration
Contains the bucket ranges used for grouping the estimated restoration duration.
Properties
Property
Value
Target Table
CD_EST_RST_DUR
Table Type
Dimension
SCD Type
Type 1
B1_RANGE_LOOKUP
ODI Package
B1_PKG_CD_EST_RST_DUR
ETL View
B1_D_EST_RST_DUR_VW
Fields
Target Field
Description
Source Field
Surrogate Key
EST_RST_DUR_KEY
Estimated Restoration Duration Dimension Surrogate Key
Populated with the sequence from B1_EST_RST_DUR_SEQ.NEXT_VAL.
Natural Keys
RANGE_START
Estimated Restoration Duration Start Range
B1_RANGE_LOOKUP.START_RANGE
RANGE_END
Estimated Restoration Duration End Range
B1_RANGE_LOOKUP.END_RANGE
Attributes
EST_RST_DUR_DESCR
Estimated Restoration Duration Description
B1_RANGE_LOOKUP.DESCR
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Event
Extracts event information from the Network Management System applications using the source database table JOBS.
Properties
Property
Value
Target Table
CD_EVENT
Table Type
Dimension
SCD Type
Type 1
JOBS
ODI Package
B1_PKG_CD_EVENT
ETL View
B1_D_EVENT_VW
Fields
Target Field
Description
Source Field
Surrogate Key
EVENT_KEY
Event Dimension Surrogate Key
Populated with the sequence from SPL_EVENT_SEQ.NEXT_
VAL.
Natural Keys
SRC_NBR
Number (Natural Key)
JOBS.NUMB
Attributes
EVENT_NBR
Event Number
JOBS.EVENT_IDX
DELETE_IND
Delete Indicator
Used for marking the event as deleted in the source.
EXCLUDE_REASON
Exclude Reason
PICKLIST_INFO_UPD_TR.DTR_TEXT
OPERATOR_COMMENT
Operator Comment
JOBS.OPERATOR_COMMENT
EVENT_STATE_CD
Event Status Code
JOBS.VALID_STATE_
KEY
EVENT_STATE_DESCR
Event Status Description
JOBS.ALARM_STATE
NVL(TE_VALID_STATES.DESCRIPTION, JOBS.ALARM_STATE)
X_COORDINATE
X Coordinate
JOBS.X_COORD
Y_COORDINATE
Y Coordinate
JOBS.Y_COORD
FIRST_CALL_ADDR
First Call Address
JOBS.ADDR_STREET
JOBS.ADDR_CITY
JOBS.ADDR_STREET || ',' || JOBS.ADDR_CITY
REMEDY_CD
Remedy
PICKLIST_INFO_UPD_TR.REMEDY_OM
TROUBLE_CD_LIST
Trouble Code
JOBS.TROUBLE_CODE
SCHEDULED_DEV_OM
Scheduled Device Code
PICKLIST_INFO_UPD_TR.SCHEDULED_DEV_OM
HUMAN_ELEM_OM
Human Element Code
PICKLIST_INFO_UPD_TR.HUMAN_ELEM_OM
OTHER_CAUSE_OM
Other Code
PICKLIST_INFO_UPD_TR.OTHER_CAUSE_OM
FOREIGN_INTERF_OM
Foreign Interference Code
PICKLIST_INFO_UPD_TR.FOREIGN_INTERF_OM
VEGETATION_OM
Vegetation Code
PICKLIST_INFO_UPD_TR.VEGETATION_OM
DEF_EQUIP_OM
Defense Equipment Code
PICKLIST_INFO_UPD_TR.DEF_EQUIP_OM
ADV_ENVIRON_OM
Adverse Environment Code
PICKLIST_INFO_UPD_TR.ADV_ENVIRON_OM
ADV_WEATHER_OM
Adverse Weather Code
PICKLIST_INFO_UPD_TR.ADV_WEATHER_OM
REMEDY_OM
Remedy Code
KEY_EVENT_IDX
Key Event Index
RELATED_OUTAGES.KEY_EVENT_IDX
H_CLS
Device Class
JOBS.H_CLS
H_IDX
Device Index
JOBS.H_IDX
ACTIVE_IND
Active Indicator
JOBS.ACTIVE
CITY
City
JOBS.ADDR_CITY
CALL_TYPE
Call Type
JOBS.CALL_TYPE
DISPLAY_NAME
Display Name
JOBS.DISPLAY_NAME
ESTIMATION_SRC_CD
Estimation Source
JOBS.EST_SOURCE
EVENT_CLS
Event Class
JOBS.EVENT_CLS
EVENT_IDX
Event Index
JOBS.EVENT_IDX
EXT_ID
External ID
JOBS.EXTERNAL_ID
REFRL_GRP
Referral Group
JOBS.REFERRAL_GROUP
RULE_SET
Rule Set
JOBS.RULE_SET
TRBLE_QUEUE
Trouble Queue
JOBS.TROUBLE_QUEUE
COMPLETED_BY
Completed By
JOBS.WHO_COMPLETED
ABN_IND
ABN Flag
PICKLIST_INFO_UPD_TR .ABN_FLAG
ACTION_TXT
Action Text
PICKLIST_INFO_UPD_TR.ACTION_TEXT
CLEAR_IND
Clear Flag
PICKLIST_INFO_UPD_TR.CLEAR_FLAG
CTRL_ZONE_TXT
Control Zone Text
PICKLIST_INFO_UPD_TR.CONTROL_ZONE_TEXT
DEVICE_TXT
Device Text
PICKLIST_INFO_UPD_TR.DEVICE_TEXT
EXCP_IND
Exception Flag
PICKLIST_INFO_UPD_TR.EXCEPTION_FLAG
FAILURE_OM
Failure Cause
PICKLIST_INFO_UPD_TR.FAILURE_OM
FEEDER_TXT
Feeder Text
PICKLIST_INFO_UPD_TR.FEEDER_TEXT
INTERRUPT_DEV_OM
Interruption Dev OM
PICKLIST_INFO_UPD_TR.INTERRUPT_DEV_OM
SYSTEM_OM
System OM
PICKLIST_INFO_UPD_TR.SYSTEM_OM
TYPE_OM
Type OM
PICKLIST_INFO_UPD_TR.TYPE_OM
CAUSE_OM
Cause OM
PICKLIST_INFO_UPD_TR.CAUSE_OM
ESTIMATED_OUT_OM
Estimated Out OM
PICKLIST_INFO_UPD_TR.EST_OUT_OM
PRIMARY_CAUSE_OM
Primary Cause Category
PICKLIST_INFO_UPD_TR .PRIMARY_CAUSE_OM
STATUS_CD
Status
JOBS.STATUS
EVENT_STATE_NAME
Event State Name
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UDF11_CD
UDF11_DESCR
UDF12_CD
UDF12_DESCR
UDF13_CD
UDF13_DESCR
UDF14_CD
UDF14_DESCR
UDF15_CD
UDF15_DESCR
UDF16_CD
UDF16_DESCR
UDF17_CD
UDF17_DESCR
UDF18_CD
UDF18_DESCR
UDF19_CD
UDF19_DESCR
UDF20_CD
UDF20_DESCR
UDF21_CD
UDF21_DESCR
UDF22_CD
UDF22_DESCR
UDF23_CD
UDF23_DESCR
UDF24_CD
UDF24_DESCR
UDF25_CD
UDF25_DESCR
UDF26_CD
UDF26_DESCR
UDF27_CD
UDF27_DESCR
UDF28_CD
UDF28_DESCR
UDF29_CD
UDF29_DESCR
UDF30_CD
UDF30_DESCR
UDF31_CD
User Defined Field 31 Code
UDF31_DESCR
User Defined Field 31 Description
UDF32_CD
User Defined Field 32 Code
UDF32_DESCR
User Defined Field 32 Description
UDF33_CD
User Defined Field 33 Code
UDF33_DESCR
User Defined Field 33 Description
UDF34_CD
User Defined Field 34 Code
UDF34_DESCR
User Defined Field 34 Description
UDF35_CD
User Defined Field 35 Code
UDF35_DESCR
User Defined Field 35 Description
UDF36_CD
User Defined Field 36 Code
UDF36_DESCR
User Defined Field 36 Description
UDF37_CD
User Defined Field 37 Code
UDF37_DESCR
User Defined Field 37 Description
UDF38_CD
User Defined Field 38 Code
UDF38_DESCR
User Defined Field 38 Description
UDF39_CD
User Defined Field 39 Code
UDF39_DESCR
User Defined Field 39 Description
UDF40_CD
User Defined Field 40 Code
UDF40_DESCR
User Defined Field 40 Description
SORT_COL_1
Sort Column 1
JOBS.SORT_COL_1
SORT_COL_2
Sort Column 2
JOBS.SORT_COL_2
SORT_COL_3
Sort Column 3
JOBS.SORT_COL_3
SORT_COL_4
Sort Column 4
JOBS.SORT_COL_4
SORT_COL_5
Sort Column 5
JOBS.SORT_COL_5
SORT_COL_6
Sort Column 6
JOBS.SORT_COL_6
SORT_COL_7
Sort Column 7
JOBS.SORT_COL_7
SORT_COL_8
Sort Column 8
JOBS.SORT_COL_8
SORT_COL_9
Sort Column 9
JOBS.SORT_COL_9
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Event Status
Extracts various statuses of events in the TE_VALID_STATES table from the Network Management System database.
Properties
Property
Value
Target Table
CD_EVENT_STATUS
Table Type
Dimension
SCD Type
Type 1
TE_STATUSES A
ODI Package
B1_PKG_CD_EVENT_STATUS
ETL View
B1_D_EVENT_STATUS_VW
Fields
Target Field
Description
Source Field
Surrogate Key
EVENT_STATUS_KEY
Event Status Dimension Surrogate Key
Populated with the sequence from SPL_EVENT_STATUS_SEQ.NEXT_VAL
Natural Keys
SRC_STATUS
Status (Natural Key)
TE_STATUSES.TRANS_STATUS
Attributes
EVENT_STATUS_CD
Event Status Code
TE_STATUSES.DESCRIPTION
Populated with “-” if null.
EVENT_STATUS_DESCR
GROUP_CD
Group Code
TE_STATUS_GROUPS. GROUP_NAME
GROUP_DESCR
Group Description
TE_STATUS_GROUPS. DESCRIPTION
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Exclusion Detail
Captures exclusion period details of a storm from the source system.
Properties
Property
Value
Target Table
CD_EXCL_DETAIL
Table Type
Dimension
SCD Type
Type 1
STORMMAN_STORMS
ODI Package
B1_PKG_CD_EXCL_DETAIL
ETL View
B1_D_ EXCL_DETAIL_VW
Fields
Target Field
Description
Source Field
Surrogate Key
EXCL_DETAIL_KEY
Excludable Storm Dimension Surrogate Key
Populated from the B1_EXCL_DETAIL_SEQ sequence.
Natural Keys
SRC_NCG_ID
Strom Level NCG
STORMMAN_STORMS.ZONE_IDX
SRC_STORM_NAME
Storm Name
STORMMAN_STORMS.STORM_NAME
Attributes
SRC_STORM_NAME_SFX
Storm Name Suffix
STORMMAN_STORMS.STORM_DATE
EXCL_PERIOD_
COMMENTS
Exclusion Period Comments
STORMMAN_STORMS.EX_STORM_COMMENT
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Feeder
Extracts feeder and corresponding substation information from the FEEDERS table.
Properties
Property
Value
Target Table
CD_FEEDER
Table Type
Dimension
SCD Type
Type 2
FEEDERS
ODI Package
B1_PKG_CD_FEEDER
ETL View
B1_D_FEEDER_VW
Fields
Target Field
Description
Source Field
Surrogate Key
FEEDER_KEY
Feeder Duration Dimension Surrogate Key
Populated with the sequence from SPL_FEEDER_SEQ.NEXT_VAL.
Natural Keys
SRC_FEEDER_IDX
Feeder Index
FEEDERS.H_IDX
SRC_FEEDER_CLS
Feeder Class
FEEDERS.H_CLS
Attributes
FEEDER_NAME
Feeder Name
FEEDERS.FEEDER_NAME
FEEDERS.H_CLS
FEEDERS.H_IDX
Use the feeder name if available. Else, use the combination of class and index.
SUBSTN_CD
Substation Code
FEEDERS.SUBSTATION_NAME
SUBSTN_DESCR
Substation Name
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
EFF_START_DTTM
EFF_END_DTTM
FEEDERS.DEATH
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Major Event Snapshot Type
Holds three static values to be used for classifying the type of snapshot data being captured in the City and Control Zone Outage facts.
Note: This dimension holds static data inserted by the initial setup procedure.
Properties
Property
Value
Target Table
CD_MAJ_ EVT _SNAP_TYPE
Table Type
Dimension
SCD Type
Type 1
n/a
ODI Package
n/a
ETL View
n/a
Fields
Target Field
Description
Source Field
Surrogate Key
SNAP_TYPE_CD
Snapshot Type Dimension Surrogate Key
Populated with one of the static values below:
BLUE_SKY - If the Begin DTTM falls outside the exclusion period of the STORM (storm does not have any impact).
MAJ_EVT - If the Begin DTTM falls within the exclusion period (storm has an impact).
ALL - MAJOR EVENT + BLUE SKY
Natural Keys
Attributes
SNAP_TYPE_DESCR
Snapshot Type Description
There are no user defined attributes in this dimension.
There are no data load attributes in this dimension.
Meter
Extracts meter ID and meter type details from CU_METERS table in the Network Management System source database.
Properties
Property
Value
Target Table
CD_METER
Table Type
Dimension
SCD Type
Type 2
CU_METERS
ODI Package
B1_PKG_CD_METER
ETL View
B1_D_METER_VW
Fields
Target Field
Description
Source Field
Surrogate Key
METER_KEY
Meter Dimension Surrogate Key
Populated with the sequence from SPL_METER_SEQ.NEXT_VAL.
Natural Keys
SRC_METER_ID
Meter ID
CU_METERS.METER_ID
Attributes
METER_INFO
Meter Number
CU_METERS.METER_
NO
METER_TYPE_CD
Meter Type Code
CU_METERS. METER_TYPE
AMR_ENABLED_IND
AMR Enabled Indicator
CU_METERS. METER_AMR_ENABLED
MANUFACTURER_
NAME
Manufacturer Name
CU_METERS. METER_MANUFACTURER
METER_NBR
Meter Number
CU_METERS. METER_NO
NBR_PHASES
Number of Phases
CU_METERS. METER_PHASES
RATE_CD
Rate Code
CU_METERS. METER_RATE_CODE
SERIAL_NBR
Serial Number
CU_METERS. METER_SERIAL_NUMBER
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
EFF_START_DTTM
EFF_END_DTTM
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Network Premise
Captures additional information of service locations such as the criticality types based on the priority indicators defined on service locations from the source system.
Properties
Property
Value
Target Table
CD_NETWORK_PREM
Table Type
Dimension
SCD Type
Type 2
ODI Package
B1_PKG_CD_NETWRORK_PREM
ETL View
B1_D_NETWRORK_PREM_VW
Fields
Target Field
Description
Source Field
Surrogate Key
NETWORK_PREM_KEY
Network Premise Dimension Surrogate Key
Populated from the B1_NETWORK_PREM_SEQ sequence.
Natural Keys
SRC_NETWORK_PREM_
ID
Source Network Premise ID
CU_SERVICE_LOCATIONS.SERV_LOC_ID
Attributes
PRIORITY_A_IND
A Priority
CU_SERVICE_LOCATIONS.SERV_A_PRIORITY
PRIORITY_B_IND
B Priority
CU_SERVICE_LOCATIONS.SERV_B_PRIORITY
PRIORITY_C_IND
Critical Priority
CU_SERVICE_LOCATIONS.SERV_C_PRIORITY
PRIORITY_D_IND
Medical Priority
CU_SERVICE_LOCATIONS.SERV_D_PRIORITY
PRIORITY_E_IND
Entertainment Priority
CU_SERVICE_LOCATIONS.SERV_E_PRIORITY
PRIORITY_F_IND
Fire Priority
CU_SERVICE_LOCATIONS.SERV_F_PRIORITY
PRIORITY_G_IND
Government Priority
CU_SERVICE_LOCATIONS.SERV_G_PRIORITY
PRIORITY_H_IND
Hospital Priority
CU_SERVICE_LOCATIONS.SERV_H_PRIORITY
PRIORITY_I_IND
I Priority
CU_SERVICE_LOCATIONS.SERV_I_PRIORITY
PRIORITY_J_IND
J Priority
CU_SERVICE_LOCATIONS.SERV_J_PRIORITY
PRIORITY_K_IND
Key Priority
CU_SERVICE_LOCATIONS.SERV_K_PRIORITY
PRIORITY_L_IND
Life Support Priority
CU_SERVICE_LOCATIONS.SERV_L_PRIORITY
PRIORITY_M_IND
Manufacturing Priority
CU_SERVICE_LOCATIONS.SERV_M_PRIORITY
PRIORITY_N_IND
Nursing Home Priority
CU_SERVICE_LOCATIONS.SERV_N_PRIORITY
PRIORITY_O_IND
O Priority
CU_SERVICE_LOCATIONS.SERV_O_PRIORITY
PRIORITY_P_IND
Police Priority
CU_SERVICE_LOCATIONS.SERV_P_PRIORITY
PRIORITY_Q_IND
Q Priority
CU_SERVICE_LOCATIONS.SERV_Q_PRIORITY
PRIORITY_R_IND
R Priority
CU_SERVICE_LOCATIONS.SERV_R_PRIORITY
PRIORITY_S_IND
Sensitive Priority
CU_SERVICE_LOCATIONS.SERV_S_PRIORITY
PRIORITY_T_IND
Transportation Priority
CU_SERVICE_LOCATIONS.SERV_T_PRIORITY
PRIORITY_U_IND
U Priority
CU_SERVICE_LOCATIONS.SERV_U_PRIORITY
PRIORITY_V_IND
V Priority
CU_SERVICE_LOCATIONS.SERV_V_PRIORITY
PRIORITY_W_IND
W Priority
CU_SERVICE_LOCATIONS.SERV_W_PRIORITY
PRIORITY_X_IND
X Priority
CU_SERVICE_LOCATIONS.SERV_X_PRIORITY
PRIORITY_Y_IND
Y Priority
CU_SERVICE_LOCATIONS.SERV_Y_PRIORITY
PRIORITY_Z_IND
911 Priority
CU_SERVICE_LOCATIONS.SERV_Z_PRIORITY
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
EFF_START_DTTM
EFF_END_DTTM
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Outage Duration
Extracts the outage duration age bucket information.
Properties
Property
Value
Target Table
CD_OUTG_DUR
Table Type
Dimension
SCD Type
Type 1
ODI Package
B1_PKG_CD_OUTG_DUR
ETL View
B1_D_OUTG_DUR_VW
Fields
Target Field
Description
Source Field
Surrogate Key
OUTG_DUR_KEY
Outage Duration Dimension Surrogate Key
Populated from the B1_OUTG_DUR_SEQ sequence.
Natural Keys
RANGE_START
Start Range
B1_RANGE_LOOKUP.
START_RANGE
RANGE_END
End Range
B1_RANGE_LOOKUP.
END_RANGE
Attributes
OUTG_DUR_DESCR
Outage Duration Description
B1_RANGE_LOOKUP.
DESCR
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Outage Duration Deviation
Contains bucket ranges used for grouping the deviation between estimated and actual outage duration.
Properties
Property
Value
Target Table
CD_DURATION_DEVIATION
Table Type
Dimension
SCD Type
Type 1
B1_RANGE_LOOKUP
ODI Package
B1_PKG_CD_DURATION_DEVIATION
ETL View
B1_D_DURATION_DEVIATION_VW
Fields
Target Field
Description
Source Field
Surrogate Key
DURATION_DEVIATION_KEY
Estimated VS Actual Duration Dimension Surrogate Key
Populated with the sequence from B1_DURATION_DEVIATION_SEQ.NEXT_VAL.
Natural Keys
RANGE_START
Duration Deviation Start Range
RANGE_END
Outage Duration Deviation End Range
Attributes
DURATION_DEVIATION_DESCR
Outage Duration Deviation Description
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UPDATE_DTTM
Update Date/Time
DATA_LOAD_DTTM
Data Load Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Phase
Extracts phase data from the Network Management System source system with all related attributes.
Properties
Property
Value
Target Table
CD_PHASE
Table Type
Dimension
SCD Type
Type 2
PHASE_BITMAP_LOOKUP
ODI Package
B1_PKG_CD_PHASE
ETL View
B1_D_PHASE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
PHASE_KEY
Phase Dimension Surrogate Key
Populated with the sequence from SPL_PHASE_SEQ.NEXT_VAL.
Natural Keys
SRC_PHASE_ID
Phase ID
PHASE_BITMAP_LOOKUP.PHASE_BITS
Attributes
PHASE_CD
PHASE_BITMAP_LOOKUP.PHASE_STRING
PHASE_DESCR
Phase
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
EFF_START_DTTM
EFF_END_DTTM
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Storm
Extracts storm specific data from the Network Management System with all related attributes.
Properties
Property
Value
Target Table
CD_STORM
Table Type
Dimension
SCD Type
Type 1
STORMMAN_STORMS
ODI Package
B1_PKG_CD_STORM
ETL View
B1_D_STORM_VW
Fields
Target Field
Description
Source Field
Surrogate Key
STORM_KEY
Populated with the sequence from SPL_STORM_SEQ.
Natural Keys
SRC_STORM_NAME
Storm Name
STORMMAN_STORMS.
STORM_NAME
SRC_STORM_NAME_SFX
Storm Name Suffix
STORMMAN_STORMS.
STORM_DATE
SRC_NCG_ID
Storm Control Zone
STORMMAN_STORMS.
ZONE_IDX
Attributes
STORM_TYPE_CD
Storm Type Code
STORMMAN_STORMS.
STORM_TYPE
STORM_TYPE_DESCR
Storm Type Description
STORMMAN_STORM_
TYPES.STORM_TYPE_
NAME
STORM_LEVEL_CD
Storm Level Code
STORMMAN_STORMS.
STORM_LEVEL
STORM_LEVEL_DESCR
Storm Level Description
STORMMAN_STORMS.STORM_LEVEL
STORM_START_DTTM
Date/Time the Storm Started
STORMMAN_STORMS.STORM_START
STORM_END_DTTM
Date/Time the Storm Ended
STORMMAN_STORMS.STORM_END
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.VALUE
JOB_NBR
Job Number
Storm Outage Type
Extracts the storm outage type data from Network Management System with all related attributes.
Properties
Property
Value
Target Table
CD_STORM_OUTAGE_TYPE
Table Type
Dimension
SCD Type
Type 1
STORMMAN_OUTAGE_TYPES
ODI Package
B1_PKG_CD_STORM_OUTAGE_TYPE
ETL View
B1_D_STORM_OUTAGE_TYPE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
STORM_OUTAGE_TYPE_KEY
Storm Outage Type Dimension Surrogate Key
Populated with the sequence from SPL_STORM_OUTAGE_TYPE_SEQ.NEXT_VAL.
Natural Keys
SRC_OUTAGE_TYPE
Outage Type
STORMMAN_OUTAGE_TYPES.OUTAGE_TYPE
Attributes
OUTAGE_TYPE_CD
Outage Type Code
OUTAGE_TYPE_DESCR
Outage Type Description
STORMMAN_OUTAGE_TYPES.OUTAGE_TYPE_NAME
If null, this is populated with “-”.
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Supply Node Lookup
Extracts the distinct service point (premise, person, and meter) information, along with the device they are attached to.
Note: This dimension is no longer referenced as part of any fact ETL. It is used only for reports.
Properties
Property
Value
Target Table
CD_SNL
Table Type
Dimension
SCD Type
Type 2
CES_CUSTOMERS_HISTORY
ODI Package
B1_PKG_CD_SNL
ETL View
B1_D_SNL_VW
Fields
Target Field
Description
Source Field
Surrogate Key
SNL_KEY
Supply Node Lookup Dimension Surrogate Key
Populated with the sequence from SPL_SNL_SEQ.NEXT_VAL.
Natural Keys
SRC_METER_ID
Meter ID (Natural Key)
CES_CUSTOMERS_HISTORY.METER_ID
SRC_PERSON_ID
Person ID (Natural Key)
CES_CUSTOMERS_HISTORY.CUST_ID
SRC_PREMISE_ID
Premise ID (Natural Key)
CES_CUSTOMERS_HISTORY.SERV_LOC_ID
SRC_ACCOUNT_ID
Account ID
CES_CUSTOMERS_HISTORY.ACCOUNT_NUMBER
SRC_ADDR_ID
Address
Attributes
DEVICE_ID
Device ID
CES_CUSTOMERS_HISTORY.NEW_DEVICE_ID
FEEDER_ID
Feeder ID
CES_CUSTOMERS_HISTORY.FEEDER_ID
NCG_ID
NCG ID
CES_CUSTOMERS_HISTORY.NEW_NCG
DEVICE_CLS
Device Class
CES_CUSTOMERS_HISTORY.NEW_H_CLS
DEVICE_IDX
Device Index
CES_CUSTOMERS_HISTORY.NEW_H_IDX
DATA_LOAD_DTTM
Data Load Date/Time
EFF_START_DTTM
CES_CUSTOMERS_HISTORY.BIRTH
EFF_END_DTTM
CES_CUSTOMERS_HISTORY.DEATH
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan
Extracts switch plan data from the Network Management System with all related attributes.
Properties
Property
Value
Target Table
CD_SW_PLAN
Table Type
Dimension
SCD Type
Type 1
SWMAN_SHEET
ODI Package
B1_PKG_CD_SW_PLAN
ETL View
B1_D_SW_PLAN_VW
Fields
Target Field
Description
Source Field
Surrogate Key
SW_PLAN_KEY
Switch Plan Dimension Surrogate Key
Populated with the sequence from SPL_SW_PLAN_SEQ.
Natural Keys
SRC_SW_PLAN_CLS
Switch Plan Class
SWMAN_SHEET.SWITCH_SHEET_CLS
SRC_SW_PLAN_IDX
Switch Plan Index
SWMAN_SHEET.SWITCH_SHEET_IDX
Attributes
CHARGE_NBR1
Charge Number 1
SWMAN_SHEET.CHARGENUMBER1
CHARGE_NBR2
Charge Number 2
SWMAN_SHEET.CHARGENUMBER2
CHARGE_NBR3
Charge Number 3
SWMAN_SHEET.CHARGENUMBER3
DESCR
Description
SWMAN_SHEET.DESCRIPTION
DEVICE_ALIAS
Device Alias
SWMAN_SHEET. DEVICE_ALIAS
INS_USER
Inserted User
SWMAN_SHEET.INSERT_USER
LOCATION
Location
SWMAN_SHEET.LOCATION
OFFICE
Office
SWMAN_SHEET.OFFICE
REQUESTED_CUST_
NAME
Requested Customer Name
SWMAN_SHEET.CUSTOMERREQUESTEDNAME
REQUESTED_CUST_
PHONE_NBR
Requested Customer Phone Number
SWMAN_SHEET.CUSTOMERREQUESTEDPHONENUMBER
SW_SHEET_TYPE
Switch Sheet Type
SWMAN_SHEET_CLS. SWITCH_SHEET_TYPE
SW_SHEET_TYPE_
DESCR
Switch Sheet Type Description
SWMAN_SHEET_CLS.DESCRIPTION
OWNER
Owner
SWMAN_SHEET.OWNER
CREW_WILL_SWITCH_
IND
Crew Will Switch Indicator
SWMAN_SHEET. CREWWILLSWITCH
CREW_WILL_RST_IND
Crew Will Restore Indicator
SWMAN_SHEET.CREWWILLRESTORE
GROUNDS_REQUIRED_
IND
Grounds Required Indicator
SWMAN_SHEET.GROUNDSREQUIRED
SHEET_ID
Sheet ID
SWMAN_SHEET.SEQ_SHEET_ID
VERIFY_IND
Verify Indicator
SWMAN_SHEET.MB_EDIT
VOLTAGE
Voltage
SWMAN_SHEET.VOLTAGE
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
UDF6_CD
UDF6_DESCR
UDF7_CD
UDF7_DESCR
UDF8_CD
UDF8_DESCR
UDF9_CD
UDF9_DESCR
UDF10_CD
UDF10_DESCR
UDF11_CD
UDF11_DESCR
UDF12_CD
UDF12_DESCR
UDF13_CD
UDF13_DESCR
UDF14_CD
UDF14_DESCR
UDF15_CD
UDF15_DESCR
UDF16_CD
UDF16_DESCR
UDF17_CD
UDF17_DESCR
UDF18_CD
UDF18_DESCR
UDF19_CD
UDF19_DESCR
UDF20_CD
UDF20_DESCR
UDF21_CD
UDF21_DESCR
UDF22_CD
UDF22_DESCR
UDF23_CD
UDF23_DESCR
UDF24_CD
UDF24_DESCR
UDF25_CD
UDF25_DESCR
UDF26_CD
UDF26_DESCR
UDF27_CD
UDF27_DESCR
UDF28_CD
UDF28_DESCR
UDF29_CD
UDF29_DESCR
UDF30_CD
UDF30_DESCR
UDF31_CD
UDF31_DESCR
UDF32_CD
UDF32_DESCR
UDF33_CD
UDF33_DESCR
UDF34_CD
UDF34_DESCR
UDF35_CD
UDF35_DESCR
UDF36_CD
UDF36_DESCR
UDF37_CD
UDF37_DESCR
UDF38_CD
UDF38_DESCR
UDF39_CD
UDF39_DESCR
UDF40_CD
UDF40_DESCR
UDF41_CD
User Defined Field 41 Code
UDF41_DESCR
User Defined Field 41 Description
UDF42_CD
User Defined Field 42 Code
UDF42_DESCR
User Defined Field 42 Description
UDF43_CD
User Defined Field 43 Code
UDF43_DESCR
User Defined Field 43 Description
UDF44_CD
User Defined Field 44 Code
UDF44_DESCR
User Defined Field 44 Description
UDF45_CD
User Defined Field 45 Code
UDF45_DESCR
User Defined Field 45 Description
UDF46_CD
User Defined Field 46 Code
UDF46_DESCR
User Defined Field 46 Description
UDF47_CD
User Defined Field 47 Code
UDF47_DESCR
User Defined Field 47 Description
UDF48_CD
User Defined Field 48 Code
UDF48_DESCR
User Defined Field 48 Description
UDF49_CD
User Defined Field 49 Code
UDF49_DESCR
User Defined Field 49 Description
UDF50_CD
User Defined Field 50 Code
UDF50_DESCR
User Defined Field 50 Description
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan Jobs Relation
Holds the relation between the switch plan and jobs in the Network Management System. This entity acts as a bridge table that provides the relation between switch plan and jobs, as well as jobs and switch plan.
Note that this dimension is not referenced in any of the facts.
Properties
Property
Value
Target Table
CD_SWP_JOBS
Table Type
Dimension
SCD Type
Type 1
JOBS
SWITCH_SHEET_OUTAGE_EVENTS
ODI Package
n/a
ETL View
B1_ D_SWP_JOBS_VW
Fields
Target Field
Description
Source Field
Surrogate Key
SWP_JOBS_KEY
Switch Plan Jobs Dimension Surrogate Key
Populated with the sequence from B1_SWP_JOBS_SEQ.
Natural Keys
SWITCH_SHEET_CLS
Switch Sheet CLS
JOBS.SWSHEET_CLS
SWITCH_SHEET_OUTAGE_EVENTS.SWITCH_SHEET_CLS
SWITCH_SHEET_IDX
Switch Sheet IDX
JOBS.SWSHEET_IDX
SWITCH_SHEET_OUTAGE_EVENTS.SWITCH_SHEET_IDX
Attributes
ASSOC_TYPE
Association Type
ASSOC_NAME
Association Name
There are no user defined attributes in this table.
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
TE_VALID_STATES.UPDATE_DTTM
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan State
Properties
Property
Value
Target Table
CD_SW_PLAN_STATE
Table Type
Dimension
SCD Type
Type 1
TE_VALID_STATES
ODI Package
B1_PKG_CD_SW_PLAN_STATE
ETL View
B1_D_SW_PLAN_STATE_VW
Fields
Target Field
Description
Source Field
Surrogate Key
SW_PLAN_STATE_KEY
Switch Plan State Dimension Surrogate Key
Populated with the sequence from SPL_SW_PLAN_STATE_SEQ.NEXT_VAL.
Natural Keys
SRC_STATE_KEY
Switch Plan State Key
Attributes
STATE_CD
Switch Plan State Code
STATE_DESCR
Switch Plan State
UDF1_CD
UDF1_DESCR
UDF2_CD
UDF2_DESCR
UDF3_CD
UDF3_DESCR
UDF4_CD
UDF4_DESCR
UDF5_CD
UDF5_DESCR
DATA_LOAD_DTTM
Data Load Date/Time
UPDATE_DTTM
Update Date/Time
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
