Property | Details |
Description | This analysis shows the number of devices whose warranty would expire in the next 15 months. |
Purpose | This analysis shows how many devices are going to expire in the next 15 months. Business users need to take appropriate measures, such as replacing those devices, prevent them from failures, etc, and ensure the devices are compliant. |
Representation | The bar graph shows the number of devices nearing their expiration dates. The X-axis represents the month. The Y-axis represents the count of devices with expiring warranty. Hover over the bars for respective values. The table shows the number of devices with expiring warranty in a particular month. It also displays the device type, manufacturer, and model for each of the device. |
Drill Down | The graph drills down to the Warranty Details dashboard page for more specific details. The Devices with Expiring Warranty column link drills down to the Warranty Details dashboard page for more specific details. |
Source Object | Operational Device Fact |
OAS Subject Area | ODM - Operational Device |
Metrics | Devices Expiring |
Description | All services performed on devices, such as inspection service, maintenance service, etc, are captured in Oracle Utilities Operational Device Management as “service histories”. This analysis shows the trend in service history inspections for previous 15 months. Success Rate = (Number of Passed Inspections / Total Number of Inspections) * 100 |
Purpose | This analysis helps the business users to understand the trend in the number of device inspections that are being carried out successfully. If there is a decline in the number of successful inspections, then it would indicate a need to take corrective action against a particular type of device or manufacturer. |
Representation | The bar graph shows the number of inspections recorded in each month, in the previous 15 months. It also shows the number of inspections that passed in a particular month. The X-axis represents the month. The Y-axis represents the service histories. Hover over the bars for specific values. The table shows the total inspections recorded in a month, for the previous 15 months. Also, it displays the inspections that passed, failed, and the success rate for each month. The Month Year column link and the X-axis broadcasts the month details to the Top 10 Device Types with Highest Success Rates and Top 10 Manufacturers with Highest Success Rates analyses on the same dashboard page. |
Drill Down | No drill down |
Source Object | Service History Fact |
OAS Subject Area | ODM - Service History |
Metrics | Total Inspections, Success Rate |
Description | This analysis shows the top 10 device types with the highest rate of successful inspections. The data is based on the month selected in the Inspection History Trend analysis. |
Purpose | Business users can identify the best performing device types. They can recommend the utility company to utilize more of these types of devices to avoid any usage issues. |
Representation | The Month Year drop down filters the data for the success rates in the respective month. The table shows the total number of inspections carried out on the devices grouped by their device type, in the selected month. Also, it displays the number of inspections that passed, failed, and the success rate for each device type. Rank = Rank (Success Rate) |
Description | This analysis shows the top 10 device types with highest rate of successful inspections. The data is based on the month selected in the Inspection History Trend analysis. |
Purpose | Business users can identify the manufacturers whose devices are performing well. They can recommend the utility company to utilize more of these types of devices to avoid any usage issues. |
Representation | The Month Year drop down filters the data for the success rates in the respective month. The table shows the total number of inspections carried out on the devices grouped by their manufacturer, in the selected month. Also, it displays the number of inspections that passed, failed, and the success rate for each manufacturer. Rank = Rank (Success Rate) |
Description | This analysis provides an insight into the geographic distribution of various types of firmware versions installed across devices. It has both spatial and non-spatial representation of the data. The data is shown till the last sync date (the date when the data was last loaded into the system). |
Purpose | Business users can view the device volumes for each firmware version across various geographic areas. In situations where a particular area has a lot of devices with an older firmware version, necessary steps can be taken to ensure that the latest firmware version is installed. |
Representation | The View By drop down slices the data by different types of firmware. The color-coded region on the map shows the postal code where the selected firmware type is installed. The postal code shows the master-detail implementation in the pie chart and table. The pie chart shows the distribution of various firmware versions as a percentage of total number of devices. The data is shown for the postal code selected on the map and for the selected firmware type. The Postal Code drop down lists the various postal codes on the map. The table shows the distribution of various firmware versions and the number of devices using the firmware version The data is shown for the postal code selected on the map and the selected firmware type. |
Metrics | Devices |
Description | This analysis shows a list of first 100 devices with expiring warranties sorted in the ascending order of their expiration dates. The data is displayed for the selected month. |
Purpose | The devices at the top of the list are the ones nearing their expiration dates. Business users can identify such devices and take necessary measures. |
Representation | The table displays the type of device, its manufacturer, model number, location, its parent location hierarchy, and expiration date for each of the devices. |
Drill Down | The Device column link drills back to the Asset page and the Location column link drills back to the Location page in the Oracle Utilities Operational Device Management system. |
Metrics | No measures |
