Demand Day Usage Module
The Demand Day Usage module educates customers about how much energy they use during peak hours on the day in which their demand hour occurred. The module encourages them to shift tasks to off-peak hours to lower their demand and save money.
Design
This image shows an example of the Demand Day Usage module:
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option | Input Value |
Color and Chart Alignment Oracle strongly recommends that the colors and charts for this module, the Hourly Usage module, and the Demand 101 module all use the same colors, and are aligned to show the customer the visual connection between each hour’s price and the customer’s usage during each hour. |
Required Choose one of the following: Use default colors. Work with your Delivery Team to specify other colors. |
Hashing Display The module can be configured to display hashing behind the peak period. Default: Display hashing in the chart. |
Required Choose one of the following: Display hashing. Do not display hashing. |
Peak Time and Demand Hour Names You can designate the name of peak and off-peak ranges in the legend, including how many dollar signs ($) are displayed for each. Default values include:
Note that the values used here must be the same as the values used in the Demand 101 module. |
Required Choose one of the following: Use the default names. Use the following names: |
To see how this module fits into the overall user experience, see Design and Configuration: Demand Rate Coach Emails.
