A Calculation Rule with a Discount for Being on Autopay
Customer has Autopay
This rule will look as follows:
Seq |
Field to Compare |
Comparison Method |
If TRUE |
If FALSE |
If Insufficient Data |
10 |
Algorithm: check if customer has Autopay |
= Y |
Apply Rule |
Do Not Apply Rule |
Do Not Apply Rule |
The criterion calls an algorithm that performs a logical comparison.
Field to Compare. We chose a "field to compare" algorithm that checks if the account associated with the bill segment is on Autopay. If an autopay setup exists, then it returns a value of Y. If not, however, it returns N
Comparison Method and Results. We simply compare the value returned by the algorithm to Y and indicate the appropriate response. If the condition is true, the calculation rule is applied. If the condition is false or insufficient data, the calculation rule is skipped.
Refer to CI_CHK_APAY for more information about this algorithm.
