Maintaining Asset Replication
You use the Asset Replication portal is used to display and maintain asset replication activities.
You can access the portal from Menu > Asset Management > Asset Replication. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Asset Replication: This zone displays the basic attributes of the asset replication activity.
  • Completion Event: This zone displays a list of completion events related to the asset replication activity.
