Defining General Ledger Divisions
There are two types of Divisions referenced in the system: a CIS Division and a GL Division. This is a rather powerful structure, but it can be confusing.
  • General Ledger divisions typically comprise individual entities (e.g., companies) in your general ledger. You must set up a GL division for each such entity. The GL division's sole purpose in the system is to define the accounting period associated with financial transactions linked to service agreements associated with the GL division (service agreements are associated with GL divisions via their SA type). The system cares about accounting periods in order to prevent a user from booking moneys to closed periods. It also uses accounting periods when it produces the flat file that contains the consolidated journal entry that is interfaced to your general ledger (refer to The GL Interface for more information).
When determining how many GL Divisions you need, be sure to consider your general ledger and how your chart-of-accounts is structured. You will typically have one GL division for each "company" in your general ledger.
  • A CIS division is typically associated with a jurisdiction. The definition of a jurisdiction is a geographic-oriented entity with unique business rules. For example, if you conduct business in California and Nevada, and each state has different collection rules, you will need a separate jurisdiction for each state. You must set up a CIS division for each jurisdiction in which you conduct business.
Fastpath:
Refer to Setting Up CIS Divisions for information about CIS Divisions.
To define a general ledger division, select Admin > General > General Ledger Division.
Description of Page
Enter a unique GL Division for the general ledger division.
Enter a Description of this general ledger division.
Define the accounting Calendar ID that controls how to convert an FT's accounting date into an accounting period. Refer to Defining Accounting Calendars for more information.
You may define a Currency Code for the GL division. Note that the system does not use this currency code.
