Setting Up Fieldwork Cancellation Reasons
Description of Page
Enter a Cancel Reason and Description for every field activity request cancellation reason.
Only use System Default on those reason codes that are placed on field activity requests that are automatically canceled by the system. The following table lists the valid values and the condition where this cancel reason is used.
System Default
System Condition
Cut Process canceled
Placed on field activity requests that are canceled when a Cut Process is canceled.
SA Start/Stop canceled
Placed on field activity requests that are canceled when a pending start/stop is canceled.
Severance Process canceled
Placed on field activity requests that are canceled when a severance process is canceled.
Required values. You must have one reason code defined for each of the System Default values that corresponds to an event that may occur in your implementation.
