Required Relationship Types and Billing
When the system attempts to create a bill segment for a service agreement whose SA type has Required relationship types, it checks if all such relationships are defined for the service agreement. If not, a bill segment error will be generated.
The reason this restriction exists is to handle the situation when your required relationship types change over time. For example, assume on your first day of production you only need energy suppliers defined on electric service agreements. After several months, gas deregulates. When this happens, you will need to change your control tables to indicate that your gas SA types require an energy supplier. If you don't write a default program to update your existing gas service agreements, billing will complain.
