Other Considerations For Interfacing Info to a Third Party
Because event information is extracted to a third party, you must consider how to handle adjustments to the event amount. For example, if your event is generated based on the creation of a bill segment, what should happen if that bill segment is cancelled?
You may want to prevent these types of events from getting canceled. Validation like this may be added via a user exit or using an event cancellation algorithm.
Sample Algorithms. The product does not provide any base algorithms to prevent an event from being canceled.
You should allow negative event amounts to be created so that this information may also be sent to the third party's system.
