Defining Configuration Types
You use the Configuration Type portal to display and maintain configuration types.
Refer to Understanding Configuration Types for more information.
You can access the portal by selecting Admin,, then Asset Management, then Configuration Type.
- Configuration Type List: This zone lists all configuration type records. Broadcast a record to display the details of the selected record.
- Configuration Type : This zone provides information about the selected configuration type.
