Designing Overdue Process Templates and Event Types
The following table shows a sample overdue process template for one of the rules in the Residential / North cell in the previous section's matrix.
 Overdue Process Template  |
 Overdue Event Type  |
 When Triggered  |
 Accelerated overdue process for residential customers  |
 Old debt letter  |
 At inception of process  |
 Cut active service agreements  |
 10 days after inception  |
 Reduce customer's credit rating  |
 10 days after inception (i.e., at the same time the cut process is created)  |
 Write down small debt  |
 0 days after completion of the cut process(es)  |
 Refer debt to collection agent  |
 0 days after attempting the small write down (this means that either the small write-down or the agency referral will take place as if the write-down is successful, the bill's FTs will be matched to balanced match events and the overdue process will stop)  |
 Cancel collection agent referral  |
 45 days after referral  |
 Write-off debt  |
 0 days after collection agent cancellation  |
You should create a similar table for each of the distinct overdue process templates in your matrix.
At this point, you've designed the distinct overdue process templates. Next, you'll need to design the algorithms that control their overdue processes:
- A template's Calculate Unpaid and Original Amount algorithm calculates the original and unpaid amounts of the objects being collected by a process. These values are used throughout the overdue processing module.
 - A template's Cancel Criteria algorithm is executed to determine if a process should be cancelled. Refer to How Are Overdue Processes Cancelled for the details.
 - A template's Cancel Logic algorithm is executed to cancel a process. Refer to How Are Overdue Processes Cancelled for the details. Please note that the logic embodied in this type of algorithm can be sophisticated because it is responsible for stopping an ongoing process's activities (e.g., this could involve cancelling field activities or cases). Cancellation algorithms are also responsible for inserting log entry(s).
 - A template's Hold Event Activation algorithm is invoked to determine if the Overdue / Cut Event Manager should suspend the activation of the process's events.
 - A template's Information algorithm is invoked to construct the override "info string".
Next, extract each unique event type from the above table:
 Action  |
 Old debt letter  |
 Create a customer contact  |
 Cut active service agreement(s)  |
 Start a cut process for every active SA with an unpaid FT on the bill  |
 Insert an account credit rating history record  |
 Create write-down adjustments if unpaid debt is less than $x  |
 Create a collection agency referral  |
 Cancel the collection agency referral  |
 Write off unpaid debt  |
 Create adjustments to write-off unpaid debt  |
At this point, you know the distinct event types. Next, you'll need to design the algorithms that control the lifecycle of each event type:
- The event type's  Event Activation algorithm(s) are executed by
the  Overdue / Cut Event Manager on its trigger date.
The following points describe the logic embodied in such an algorithm:
- The activity that happens on the trigger date (e.g., creation of a customer contact, To Do, etc.). Refer to Overdue Events Can Do Many Things for the details.
 - Whether the event is transitioned into the Waiting or Complete state when it's triggered. Refer to Some Events Can Wait for the details.
 - How the log entry(s) associated with event activation will be constructed. The base-package algorithms allow you to control the verbiage in the log entry by defining the desired message number on the algorithm. This means that you may have to set up new messages. Refer to Activating Events Should Add A Log Entry for the details.
 - The event type's  Cancel Logic algorithm(s) are invoked when  an
event is cancelled.  The following points describe the logic
- If the event is allowed to be canceled. This logic may be necessary if some conditions prevent events of this type from canceling. For example, you may want to prevent an event from canceling when there are later dependent events that aren't canceled.
 - Any ancillary actions that take place during cancellation.
 - How the log entry(s) associated with event cancellation will be constructed.
 - The event type's Monitor Waiting Event algorithm(s) are invoked to monitor a waiting event. These algorithms are responsible for transitioning a Waiting event to Complete if the object on which it's waiting is complete.
 - The event type's Event Information algorithm is invoked to construct the override "info string".
Once you've designed each event type's algorithms, you're ready to design your cut processes.
