Consumption Extract Requests - Setup Steps
Example Setup Steps
Setting up consumption extracts involves the following steps:
  1. Create Consumption Request Types: you should create a consumption request type for each unique type of request required by your implementation.
  2. Create Consumption Extract Types: you should create a consumption extract type for each unique combination of output details (target UOM, target interval size, TOU map/template) and measurement selection criteria.
  3. Add the "Create General Process Record if IMD is Historical Correction" historical correction algorithm as an Enter algorithm on the Finalized state of the initial measurement business objects.
  4. Add the "Create General Process Record for Re-derived Values" historical correction algorithm as an Enter algorithm on the Finalized state on the measurement business object.
  5. Create and submit initial load consumption extract requests for each consumption extract type you created earlier.
  6. Set up batch processes for daily extract requests and historical corrections. Batch processing for consumption extracts should include the following:
    1. The Create Daily Consumption Extract Requests (D2-CRERQ) batch control should be configured to run on a regular (i.e. daily) schedule to create ongoing consumption extract requests.
    2. The Request Monitor (Deferred) (F1-SUBRQ) batch control should be used to monitor for pending requests and transition them to the "Submit Job" state.
    3. Historical corrections consumption extract batch controls (based on D2-IDEHC, one for each consumption extract type), should be configured to run on a regular basis to check for and create historical correction extracts.
